LD-Ordie2Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
ADSavarese11Jack KlarichNew Member Introduct...New member from FL
ADSavarese11woodyNew Member Introduct...New member from FL
LD-Ordie2LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
ADSavarese11hardwickbvNew Member Introduct...New member from FL
ADSavarese11ol' schoolNew Member Introduct...New member from FL
ADSavarese11GorillaNew Member Introduct...New member from FL
ADSavarese11Marc HNew Member Introduct...New member from FL
ADSavarese11ADSavareseNew Member Introduct...New member from FL
ADSavarese11Phu CatNew Member Introduct...New member from FL
ADSavarese11trike ladyNew Member Introduct...New member from FL
ADSavarese11Uncle FesterNew Member Introduct...New member from FL
ADSavarese11rhino 2New Member Introduct...New member from FL
Likes Likes:  2
Results 1 to 10 of 10
Thread: U joint
    20+ Posts
    May 2017
    Newburgh, IN 47630
    Default U joint
    I have a 2012 Gold Wing with a 2017 Trike conversion. I noticed the grease seal on the rear universal joint has came apart on one side. Can I get a new u joint locally or will I have to order it from Roadsmith? I just noticed this today so I can't call Roadsmith until tomorrow.
    Thanks,
    Willie
  2. Roadsmith banner
  3. #2
    Mar 2011
    mountain home,ar. USA
    I would call RS regardless as this may be a warranty claim or at least one they might choose to fix for you.
  4. #3
    20+ Posts
    May 2017
    Newburgh, IN 47630
    I called Mike at Roadsmith and got a part number for the U joint. Went to NAPA and picked one up. Finished installing it today and we are leaving on a trip tomorrow. The old U joint was really bad one side was completely destroyed (needle bearing ground up). I'm a little disappointed because this U joint had less than 25,000 miles on it.
    Willie
  5. #4
    Sep 2012
    Lakeland, FL
    U joints are subject to break, as most things are, my understanding is, the joints are sealed, but have zerk fittings for lube, and I do lube mine from time to time. I was always confused whether to lube them or not, believe Road Smith says it is optional, but I'm reaching into my memory and I may be wrong. In my mind, a U joint should not fail at 25K miles.
  6. #5
    Sep 2012
    Lakeland, FL
    Default U Joint Lube
    Question, best way to get that zerk fitting on the U joint in position for a shot of grease?
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Not being familiar with how the drive shaft alignment is on a roadsmith, but this I do know as universals will last if in a straight line from trans to rearend, if it is not, then it will ware prematurely from the constant bearing ware. Needle bearings are not that durable. However a constant water proof grease used when lubing will extend its life.
    Sep 2012
    Lakeland, FL
    Question remains.
    You can get u joins with fittings in the caps like this 1 from spicer
  10. Roadsmith banner
  11. #9
    May 2011
    San Angelo
    Present day MotorTrike IRS kits do have a Zerk fitting in the end of one cap. Makes greasing the front U-Joint on '06 and newer GL1800 Trikes so much easier. I don't know if they get them that way or add the Zerk in house.
    2015 GL1800/Roadsmith HTS1800
  12. #10
    Sep 2012
    Lakeland, FL
    Right Gold, was up under there this afternoon, found them both, my solution to get the zerks in position, was to look under and continue to roll the machine until they both appeared in position to fit the grease gun. Not that difficult.
  1. Which U-joint grease?
    By Mick in forum Honda Trikes
    Last Post: 12-25-2023, 08:24 AM
  2. Front yoke assembly with U-Joint
    By Jimsjinx in forum Honda Trikes
    Last Post: 04-21-2011, 08:30 PM
  3. Front U-Joint failure
    By Saltywheels in forum General Discussion
    Last Post: 03-18-2011, 03:55 PM
  4. U-joint question
    By bigbuck in forum General Discussion
    Last Post: 10-31-2010, 04:50 PM
  5. Bad U joint & drive shaft
    By wdy41 in forum General Discussion
    Last Post: 02-07-2010, 12:48 AM
