Gernerwa10Jack KlarichNew Member Introduct...New Member from Bellingham, WA
Gernerwa10trike ladyNew Member Introduct...New Member from Bellingham, WA
Gernerwa10GorillaNew Member Introduct...New Member from Bellingham, WA
Gernerwa10rhino 2New Member Introduct...New Member from Bellingham, WA
Gernerwa10Marc HNew Member Introduct...New Member from Bellingham, WA
Gernerwa10Uncle FesterNew Member Introduct...New Member from Bellingham, WA
Gernerwa10ZammyNew Member Introduct...New Member from Bellingham, WA
Gernerwa10hardwickbvNew Member Introduct...New Member from Bellingham, WA
Gernerwa10ol' schoolNew Member Introduct...New Member from Bellingham, WA
Gernerwa10GernerwaNew Member Introduct...New Member from Bellingham, WA
Speed Bleeders
Too Pa Pa Zook
Likes Likes:  4
Results 1 to 7 of 7
Thread: Check valve
    4250+ Posts
    Marc H's Avatar
    Dec 2011
    Evensville,Tn.
    Default Check valve
    I always thought residual check valves were for when the master cylinder was below the calipers.What is the purpose of the one on the front cyl? 89 Goldwing w/12 or 13 Champion straight axle
    1989 GL1500 Goldwing (SOLD)
    2006 GL1800 CSC
    2000+ Posts trikeman's Avatar
    Oct 2010
    Jackson Tn. Madison Co.
    Read here
    https://www.triketalk.com/forum/thre...hman-Monarch-1
    I assume you have rear drum brakes
    4250+ Posts
    Marc H's Avatar
    Dec 2011
    Evensville,Tn.
    Mine is disk.After doing some research(even a blind finds a nut once in awhile)Its used in disk brakes systems to reduce the amount of pedal travel.
    2006 GL1800 CSC
    The disk brake one has a different lbs holding then the drum. So make sure you get the correct one
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Quote Originally Posted by Marc H View Post
    Mark, Usually disc brakes use a 2-3 lb residual check valve so that any irregularities in the rotor runout will not push the brake pads and pistons back into the calipers. This should eliminate the need to pump the pedal to get brake pressure after riding a while not using the brakes.
    Drum brakes need it (10 lb) when the master cylinder is allowing too much fluid to return to the master cylinder, or the M/C reservoir is mounted below the brake system.
    If you use the 10 lb on disc brakes they would drag even more than they already do.
    Jim Murphy
    Iron Butt Rider 2001
    4250+ Posts
    Marc H's Avatar
    Dec 2011
    Evensville,Tn.
    Thanks Jim.I just wondered its purpose with disks.I know it sure makes bleeding this thing a pain but I finally got it and have strong brakes now.
    2006 GL1800 CSC
  1. ATTENTION A MUST CHECK * * check Radiator by pass cap
    By Doc7402 in forum Stallion Trikes
    Last Post: 07-12-2019, 09:43 PM
  2. Valve Check
    By 3 for 2 in forum Honda Trikes
    Last Post: 07-21-2017, 07:12 AM
  3. Check Valve Required
    By Lawingnutz in forum Honda Trikes
    Last Post: 02-23-2015, 09:44 PM
  4. Oil filter check valve
    By Lakeman in forum Harley Trike Conversions
    Last Post: 04-29-2012, 10:06 AM
  5. Oil Valve: Quik Valve
    By Konrad in forum Honda Trikes
    Last Post: 08-05-2011, 07:34 PM
