good evening folks...
i recently had put up the trike for sale, since my girl doesn't use it anymore, hurt her wrist about 3 years ago and never got around to it. anyway, the past month i wasnt' doing too well health wise, so i didn't start it, kept it on trickler...now here's what's happening:
she didn't want to start, so i jump started, she started fine, charged battery, started for a few days, kept on trickler, then a week later wouldnt start.
checked battery out, it was low 9.8, had it tested, wouldnt take a charge, so put in new battery she started up.
following day, turned key on it, no lights, fuel pump engaged...not turning over.
checked the 30 amp main fuse on top by relay, replaced it, lights came on, she started right up...
yesterday, again, wouldn't turn over, hear a click. this time though, the lights all came on, new battery was still at 12.9.
Tloday, earlier this evening, i opened up the lower fuses, switched out the ignition fuse 15, replaced 30 amp at relay, she started up.
later on tonight, i was going to take it for a ride, i turn key, have lights, fuel pump engages, hear it click, but nothing turns over...
i'm not that mechanically inclined, and also financially strapped, but wold like your help as to what it could be and how go about fixing it.
can it be the ignition switch or the starter switch???
and if so, how difficult to replace, fix or first troubleshoot...
with simple directions i'm sure i can do it or at least try it. treat me like a young kid just learning and not knowing...pls lol
i can follow some basic instructions and turn a wrench but not a mechanic by any means. i'm trying to sell it, she runs good, but need to fix this issue.
yes, i do have it in neutral and the clutch pulled in.
any and all help would be appreciated...thank you in advanced
