Results 1 to 11 of 11
Thread: Trailering a power wheelchair?
    100+ Posts dwiht's Avatar
    Apr 2008
    Billings, MT
    Default Trailering a power wheelchair?
    Anyone have any suggestions on a trailer to haul a power wheelchair? I am hoping to continue riding and bring my chair with me. Thanks. I was thinking of a Harbor Freight trailer but am concerned about the suspension having too much bounce. The chair only weighs 245 poounds. Thanks for the help.
    Tour Master Trikerjim's Avatar
    Feb 2008
    Jemison,Alabama
    you may want to catch up with Wheels and ask his advice. I know he's got the rack on his trike to carry his chair, but a power chair may present a different problem. But I bet he's tried or knows of other systems. Good luck and ride safe....
    "Making it home on our Wing and a Prayer"
    Jemison, Alabama
    GWRRA chapter: AL-Z
    '06 GL-1800 Motor-Trike 2+2 & '09 Aluma MCT
    [SIGPIC][/SIGPIC]
    200+ Posts FBTRIKE's Avatar
    Nov 2008
    Pine Colorado
    Default Re: Trailering a power wheelchair?
    dwhit......any luck with the trailer question?
    If your handy with hand tools you could always buy a harbour frieght trailer,. Take off the leaf springs, purchase a set of mini torsion axles. These can be bought weld on or bolt on. Place them on top of the frame, that will it, giving it a low center of gravity (important if chair sits rather high, will also aid in loading) Trailer will be considerably lower than with leaf springs......If too low you can put them under the frame to raise the height but it will still be lower then with the leafs. The individual torsion axles will give a very good ride due to being independent and can be purchased weight specific. (they operate better than leafs with lighter loads)
    I realise this may seem a little wasteful, but would probably be cheaper than having a trailer built from scratch. If your not confident doing the work a decent fab shop could make the changes very easily.
    Good luck OR....... tell me what you already did.....
    In memory of my brother Steve....
    Nov 2008
    Pine Colorado
    Don't know if I should add this but, I hope you don't think I'm ignoring your POSSIBLE limitations. However I never assume someone can't do something because of their disability. You may have friends that can help or you may just want to have it done anyway......what ever the case, Hope I haven't put my foot in my mouth......
    Ride safe......
    Road Rider - Contributing Member
    Feb 2008
    Arkansas
    Quote Originally Posted by dwiht View Post
    dwiht, Grimm provided this URL awhile back and it has some great ideas. You might check It out.
    Motorcycle Amputee
    Regardless, stay in the saddle.
    Buzzard
    Contrinuting Member
    Apr 2009
    greenfield indiana
    See if you can find a older motorcycle camper that you could buy real cheap,and then see if you could find some friends to gut it and build some kind of ramp for it.
    Apr 2008
    Billings, MT
    I bought the Harbor Freight trailer, but the springs under the axle, made some ramps that fold along side the chair, some 3/4 inch plywood for the floor and some scrap wood for sides. It works wells and tows great. Trailer is light enough that I can lift the back end up empty if in a tight place since I do not have reverse yet.
    http://i257.photobucket.com/albums/h...ilerChair1.jpg
    http://i257.photobucket.com/albums/h...ilerChair2.jpg
    http://i257.photobucket.com/albums/h...C/Trailer2.jpg
    http://i257.photobucket.com/albums/h...C/Trailer1.jpg
    http://i257.photobucket.com/albums/h...C/100_1887.jpg
    7250+ Posts Nana's Avatar
    Apr 2008
    Ohio
    Excellent! It looks great . The chair fits in there perfectly, doesn't it.
    Trike Talk Membership Map
    No matter the storm, when you are with God, there is always a rainbow waiting.
    http://i440.photobucket.com/albums/q...andana-1-1.jpg
    200+ Posts saybel's Avatar
    Nov 2008
    dwiht, congrats
    Way to go, looks like that will do the job.
    avatar - Bama, No matter what always a friend!!!!
    70+ Posts
    Feb 2009
    Tulsa, Oklahoma
    Great, glad you got it worked out. Hope it makes things go a lot easier for you.
    Okie
    Tulsa, Okla.
    40+ Posts
    Jun 2009
    lancaster pa
    i have used the same trailer to haul my sons wheelchair works great for me as well
  1. trailering trike
    By clo in forum Honda Trikes
    Last Post: 03-13-2013, 12:42 PM
  2. Trailering a Trike
    By americanbadass in forum Trailers / Campers
    Last Post: 10-07-2012, 02:34 PM
  3. Trailering
    By 87GWMomma in forum Honda Trikes
    Last Post: 11-17-2011, 02:11 PM
  4. Trailering a Stallion
    By Dean H in forum Stallion Trikes
    Last Post: 08-10-2011, 11:06 PM
  5. Wheelchair trike
    By Big_Steve in forum General Discussion
    Last Post: 10-21-2010, 09:14 PM
