SSpoon4SullyNew Member Introduct...Hello from VA
SSpoon4Jack KlarichNew Member Introduct...Hello from VA
SSpoon4GorillaNew Member Introduct...Hello from VA
SSpoon4SSpoonNew Member Introduct...Hello from VA
Likes Likes:  8
Results 1 to 7 of 7
Thread: Hot Front Tire on the Wing
    5+ Posts Cheb's Avatar
    Jul 2018
    Olympia, WA, USA
    Default Hot Front Tire on the Wing
    New issue I'm concerned about. I've had the '08 Wing with a '11 Lehman conversion for a a few weeks now and I'm noticing the front tire gets very warm after just a short ride. Not so hot that it would burn your hand but warmer than I would think. Is this just the nature of the beast and having to steer a trike? Do your trikes heat up the front tire considerably? TIA.
    All tires will heat up a little bit especially in the summer that's the work of friction ..Also you get a little bit of heat off the rotors from braking .📞
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Quote Originally Posted by Cheb View Post
    Tire heat is a good thing to a point. Running low air pressure might give you a good ride but can cause excessive heat and cause the carcass of the tire to fail. Make sure you run at least 38 psi cold pressure. I prefer 42 psi myself because the 130/70R18 tires only have a load rating of 600 lbs at 41 psi. They get that 600 lbs just riding down the road in a straight line.
    Jim Murphy
    Iron Butt Rider 2001
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    You might check to see if your front brake is dragging.
    Apr 2010
    Shenandoah Valley of Virginia
    Too much toe in.
    But seriously …. keep it near 40 psi, 38-42 and understand that your rounded MC tire will carry a lot of weight in the center of the tread and will build some heat as that area scrubs pavement and flexes.
    1250+ Posts cavie's Avatar
    Jan 2013
    Port Charlotte fl/Hinsdale MA
    If your comparing a 2 wheeler and a trike then yes the trike tire will heat up more IF you both riding in some twisties. His tire is just leaning over. Yours is fighting some resistance. be sure you running at least 40 psi. this wi give your tire longevity. I run BT 45 It has 27,000 miles on and looks brand new.
    Jun 2010
    Indianapolis, In.
    Just my .02
    Heat will build up however, what do you mean by "a short ride"? How far???
    Also on front tire pressure. I found the "sweet spot" for my Wing/Hannigan with BT45 reverse mounted, with 4.5 deg rake and stock fork parts to be 38psi. 42psi gave a "harsh" front end!!!!
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
  1. 2015 HD freewheeler. ...Hot hot!
    By tiffany in forum Harley Trike Conversions
    Last Post: 10-07-2021, 10:26 AM
  2. Hot rod tires for a front tire?
    By ea81slush in forum VW Powered Trikes
    Last Post: 08-05-2015, 06:52 AM
  3. hot tool sale get em while they are hot
    By stacebg in forum General Discussion
    Last Post: 10-13-2014, 04:46 AM
  4. hot hot hot brings storms
    By oneup in forum General Discussion
    Last Post: 01-07-2014, 06:35 AM
  5. hot hot hot
    Last Post: 01-06-2014, 04:25 PM
