ctdair7Jack KlarichHarley Tri GlideHot Rotors After New Pads
Speed Bleeders
Likes Likes:  1
Results 1 to 13 of 13
Thread: Preload Actuator
    150+ Posts Yogisan's Avatar
    Oct 2009
    Upper Marlboro MD, USA
    Default Preload Actuator
    2010 GL1800 CSC COBRA XL ~ My preload actuator doesn't engage (load on the actuator motor) until 17 on the scale. It probably needs fluid added to the actuator. Where is the actuator located on the CSC conversion?
    1000+ Posts mhgoldwing's Avatar
    Mar 2011
    mountain home,ar. USA
    Quote Originally Posted by Yogisan View Post
    See if this helps:
    http://californiasidecar.com/pdf/Cob...Trike_9-17.pdf
    Wing with Roadsmith kit, Traxxion Ak20 cartridges and Accuride System.
    07 ST 1300 for two-wheeled fun!
    Oct 2009
    I've read this before looking for the answer. I see references to the preloader, which is on the shock assembly. There is a reference to an "amp" but I have no way of knowing if that's the actuator or not. If it is, it's attached to an upper stablizer bar, wherever that is. The way it's written, the installation manual appears to assume you know your way around the CSC rear end unit.
    Thanks anyway.
    Mar 2011
    Thanks anyway.
    If this doesn't help then I would suggest you call CSC as i'm sure someone can lead you through it.
    http://californiasidecar.com/index.php/Pages/why-csc
    550+ Posts Mick's Avatar
    Feb 2008
    Midwest
    Did you look behind the right wheel on the Honda part of the frame to see if CSC kept the stock location for the actuator?
  6. #6
    Oct 2009
    Quote Originally Posted by Mick View Post
    As much as I could without jacking up the trike and pulling the wheel.
    This just popped up in the last few days and I've been busy getting the trike, trailer and other things ready to go to the Northeast TT Gathering. I took a chance that someone has been there before and could just give me a quick answer.
    I guess I'll give CSC a call when I get back.
    Thanks anyway, Mike.
  7. #7
    Gone But Not Forgotten
    Tech Contributor
    Lee H. Mann's Avatar
    Apr 2011
    Martinsburg, WV
    Yogisan, you got rid of your Jackal ??
    Jim Murphy
    Iron Butt Rider 2001
  8. #8
    Oct 2009
    Quote Originally Posted by Lee H. Mann View Post
    Not yet. I haven't put it up for sale as there are a few minor things I need to square away. There's no rush and I get it out a couple times a month just to keep it loose.
    The parking brake quit working a couple of weeks after the disc brake conversion. It wasn't impacting anything so I just went without it last season, but I have to fix it before I sell it or it won't pass MD inspection.
  9. #9
    Tech Contributor
    Apr 2011
    Martinsburg, WV
    Sounds like one of the cable locks may have slipped.
    Jim Murphy
  10. #10
    Oct 2009
    I figured it was something like that. I was setting the brake and just about the 3rd click I felt a pop and then all slack. I remembered that you told me about getting the cable holder piece on the handle extended by welding and I thought that might be it. I just haven't gotten around to pulling the handke cover to check it.
    I'm out the door right after this text for a week but I'll check it after I get back and let you know.
  11. #11
    350+ Posts pwhoever's Avatar
    Jul 2016
    Southeastern Wisconsin
    The actuator on my GL1800 CSC Viper is still in the stock location and I have no reason to believe that the Cobra would relocate that. It should be on the right side of the frame to the rear of the sidecover. Withe the conversion body on, it will probably be very difficult to access.
  12. #12
    2500+ Posts Gold Rush's Avatar
    May 2011
    San Angelo
    If you can get to it, here's how to service it. I've done three actuators using this procedure. Works very well.
    http://goldwing.eurekaboy.com/reservoirfill.htm
    Hope this helps...
    Jerry "Gold Rush" (aka: "SPOOK") San Angelo, TX
    2015 GL1800/Roadsmith HTS1800
    TOI - IBA #23804 (SS1K & BB1.5K)
    I'm like an old race horse..... I can still run the race -- Just ache more at the finish line and need more rest between outings.
  13. #13
    Oct 2009
    I took the seat off to mount air hawk seat cushions and looked for the actuator. Yep, it's in the stock position and, unless there's a secret access panel that I haven't found yet, there's no way to get to it without pulling the trunk body. I guess no one at csc ever expected the fluid to get low on the actuator. Well, it's still working (activating the preload at 17) but sometime in the future it will need a fillup. Thanks to everyone for their comments and suggestions.
  1. Voyager kit preload question
    By krazybob in forum Outrigger Style Trikes
    Last Post: 05-24-2021, 01:07 PM
  2. Adjusting Rear preload
    By Bubbleswing in forum Honda Trikes
    Last Post: 07-14-2013, 10:06 PM
  3. Preload Setting
    By MDGeorge in forum Honda Trikes
    Last Post: 05-20-2013, 05:40 PM
  4. RoadSmith ~ AccuRide or Adjustable PreLoad
    By bikerbillone in forum Roadsmith Trikes
    Owners Forum
    Last Post: 11-16-2012, 10:41 PM
  5. Lehman Monarch II rear shock actuator
    By Mick in forum Lehman Trike
    Last Post: 04-21-2012, 11:47 AM
