AriNV3Jack KlarichRider Safety Discuss...Maybe silly but serious question, s...
AriNV3AriNVRider Safety Discuss...Maybe silly but serious question, s...
AriNV3cycle7447Rider Safety Discuss...Maybe silly but serious question, s...
Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Grandpot9tourmanHonda TrikesFront tire?
AriNV13Marc HNew Member Introduct...New to trike
Results 1 to 5 of 5
Thread: Vw engine 'hunting'
    Aug 2018
    Warminster Wilts England
    Default Vw engine 'hunting'
    I have a 2003 Boom low with a 1600 fuel injected engine, (i believe) and a weird thing happens when any electrical item is turned on ie lights, or brake lights, the engine 'hunts' the revs go up and then immediately down constantly, and eventually the engine cuts out when on tickover, but will operate ok whilst revving, its almost like the extra load being placed on the alternator, is being over compensated while on tickover, if I hold the revs just off tickover its fine, can any of you good people shed any light on this strange phenomenon.
    Meme Master
    Jan 2014
    Farmington, NH USA
    Welcome to Trike Talk Rich.
    It does sound like it's electrical, but hard to diagnose in text. (assuming "tickover" = idle)
    If you've not done so, I'd check fuel pressure and wiring to the fuel pump.
    Can't be too difficult to pinpoint your problems, after all it's a VW!
    Good luck.
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    Hmmmm... ok
    Going by memory and having very little experience with a Boom.
    So by memory.....It is an aftermarket type ECU. Much like a megasquirt is here in the USA.
    I want to say Triject brand. With a mix of euro Ford and German Bosch parts.
    All UCU's are voltage sensitive.
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Ok back.....family stuff.
    So check for stuff draining power causing a low voltage. Possible the alternator can put out enough to get the voltage up at rpm.
    Then check wire connectors and connections. Especially battery post.
    Then check for any vacuum leaks. Such as the rubber boots on intake and any rubber tubing going to a MAP sensor.
    Aug 2018
    Default VW engine 'hunting'
    Thank you all for your good advice, i will investigate all possibilities and try and get to the bottom of it.
  1. Rear-engine vs. mid-engine...pro's/con's?
    By Gruuve in forum General Discussion
    Last Post: 02-08-2019, 04:10 PM
  2. Engine Temperature Sensor on M8 Engine
    By sjambok in forum Harley Tri Glide
    Last Post: 08-14-2017, 07:42 PM
  3. Christmas tree hunting
    By meredog in forum General Discussion
    Last Post: 12-11-2011, 07:37 PM
  4. Moose Hunting Camp..
    By champsman97045 in forum General Discussion
    Last Post: 10-09-2011, 08:12 PM
  5. Deer hunting
    By Nana in forum General Discussion
    Last Post: 03-07-2011, 04:53 PM
