Likes Likes:  50
Page 5 of 5 FirstFirst 1 2 3 4 5
Results 81 to 92 of 92
Thread: Some Changes to the 2019 Freewheeler
  1. #81
    200+ Posts
    Sep 2018
    Pa
    Default Routing
    What do yo think about hose down mid line of air filter,exit to front of motor to the rear of oil pressure and rear brake switch and hang sort of behind floor board frame mount
  2. #82
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by Tucci View Post
    My brother runs his that way on an Electra glide 2wheeler
  3. #83
    200+ Posts
    Sep 2018
    Pa
    Default Routing
    From the threads ive been reading it seems unanimous that a breather is a necessity. 22000 on 15 fw (live in n.e. Pa maybe get four months riding) no problems with blow by. Then again i change my oil every 4000 and wash and re oil the air filter at the same time.
  4. #84
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Have a look at this picture
  5. #85
    200+ Posts
    Sep 2018
    Pa
    Default Venting
    Is it vented back into the heads only because of e.p.a. regs?
  6. DKCustoms postbit
  7. #86
    200+ Posts
    Sep 2018
    Pa
    Default Carter 4 barrels
    As a kid in the late 60's early 70's there was a saying that the carter 4 bbl came with a pull pin on the side like a grenade because eventually it would self destruct. I guess hd has has built in self destruct items
  8. #87
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    From the heads to the air filter is how the factory vents work
  9. #88
    200+ Posts
    Sep 2018
    Pa
    Default Vent
    Pulling back thru intake. I saw the video either on fmh or dk. or somewhere. Showed in detail the routing of the oil through all the ports and channels in the heads. Can't locate video now!
  10. #89
    Dec 2013
    Clarion PA USA
    That was the way I did mine at first however it seemed to make a mess of the frame under the motor not much but noticeable. Rerouted it this summer to mid-frame seems much better. travel safe Fred
Size:  162.7 KBName:  DSC01025.JPG
  11. #90
    200+ Posts
    Sep 2018
    Pa
    Default External breather
    Is it possible to use stock air filter and stock cover with dk breather systems
  12. #91
    200+ Posts
    Sep 2018
    Pa
    Were you able to use the stock air cleaner cover. What type support plate did you use and did you need to get a different filter
  13. DKCustoms postbit
  14. #92
    200+ Posts
    Sep 2018
    Pa
    Default Breather
    10-22 on any responses, I've decided instead of trying to make it fit, I bought a vance/hines vo2 naked air cleaner kit, breather bolt system, and chrome catch can. It will take me less time hooking this up than trying to fabricate something.
  1. some changes
    By LarryA in forum Home Built Trikes
    Last Post: 01-10-2019, 08:28 PM
  2. The Great River Ride - 2019 Who's Interested
    By JohnnyB in forum Other Rallies & Rides
    Last Post: 09-06-2018, 10:01 PM
  3. Any Rumor's on the 2019's yet?
    By 520fd in forum Harley Tri Glide
    Last Post: 08-30-2018, 08:38 PM
  4. some changes going from 2 wheel to 3 wheels.
    By Hank62 in forum General Discussion
    Last Post: 04-21-2017, 11:32 AM
