Speed Bleeders
Likes Likes:  26
Page 4 of 4 FirstFirst 1 2 3 4
Results 61 to 64 of 64
Thread: VW trike hydraulic clutch problems
  1. #61
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    No.... I do not think you need any more amperage than the original car did.
  2. #62
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    If you can go down in size on your alternator pulley you will gain more power from it PLUS the fan for cooling the alternator will spin faster = more cooling
    You will see more power at lower RPM also
  3. #63
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Speeding up the ratio can be handy if you spend a lot of time at idle or very low rpm.
    You would be surprised how much you can get away with on an alternator itself. Way back when working with a buddy on his hot rod (a ford guy, I was mopar), we ran out of room with a 514 stuffed in a place a 4 banger came from. Wound up making brackets and putting the alternator on the differential yoke. Worked out fine, did not charge unless moving but spun enough between stops that the batt was always charged.
  4. #64
    1+ Posts
    Jun 2018
    Crescent Ia usa
    Default Clutch question
    Did you find the problem? I have the very same problem. Same master same slave .mounted same way.
  1. Has Anyone Flushed Their Hydraulic Clutch System?
    By MDO in forum Harley Freewheeler / Road Glide 3
    Last Post: 01-31-2018, 07:01 PM
  2. Replies: 10
    Last Post: 10-10-2017, 06:53 PM
  3. Hydraulic clutch too hard to pull
    By Huelshorst in forum Harley Tri Glide
    Last Post: 03-17-2016, 11:49 AM
  4. Clutch/Tranny Proble
    By Chippego in forum Yamaha Trikes
    Last Post: 05-31-2013, 07:53 PM
  5. New Build Hydraulic Clutch/Brake Clutch Pedal Fabrication
    By usnavy8084 in forum Home Built Trikes
    Last Post: 10-21-2012, 08:18 AM
Tags for this Thread
