BigN693GorillaEnabled TrikersFull length floorboards
Likes Likes:  2
Results 1 to 5 of 5
Thread: Trunk light modification help.
    5+ Posts Quietthunder's Avatar
    May 2018
    Kodak, Tennessee, USA
    Default Trunk light modification help.
    I have a 2017 'Wing' and want to change the outer brake light to a brake/running light like the inside lamps. Here is the problem. The plug, the ones that connect to the bulb receptacle, (this bulb receptacle has the standard 3 flat pit connectors), has only 2 wires, brake and ground. I have to connect a center wire for the running lights to work. I would like to use the OEM Honda horse shoe connector to complete this job. I cant find the part number from Honda (shocking), and can't find it on line... HELP!!!!
    20+ Posts MAMPORRERO's Avatar
    May 2018
    HIALEAH,FLORIDA,USA
    HI GEORGE YOU NEED this GL1800 Trunk Light Jumper Wires (EC08012). I BUY THEM IN CYCLEMAX.
    May 2018
    HIALEAH,FLORIDA,USA
    Price: $6.50
    Item: EC08012 Electrical Connection (in stock)
    This is a set of trunk light jumper wires. This kit is mady by Electrical Connection and is designed to utilize the extra filament in the outside bulbs of the trunk lights. On later years of Goldwing GL1800's, Honda disconnected the power to the running light filament in the two outside trunk lights. This kit puts the power back to those bulbs so that all four trunk light bulbs operate as running lights. This kit is made in the USA with OEM connectors and Mil-Spec taps for an easy install. Installation instructions are included and this will fit all Goldwing GL1800's.
    GL1800 Trunk Light Jumper Wires (EC08012)Price: $6.50Item: EC08012 Electrical Connection (in stock)This is a set of trunk light jumper wires. This kit is mady by Electrical Connection and is designed to utilize the extra filament in the outside bulbs of the trunk lights. On later years of Goldwing GL1800's, Honda disconnected the power to the running light filament in the two outside trunk lights. This kit puts the power back to those bulbs so that all four trunk light bulbs operate as running lights. This kit is made in the USA with OEM connectors and Mil-Spec taps for an easy install. Installation instructions are included and this will fit all Goldwing GL1800's.
    Apr 2010
    Shenandoah Valley of Virginia
    The change in brightness from nothing to lit up brake light …
    … is maybe somewhat greater than the change from lit running light to brake light.
    Maybe even being more noticeable.
    May 2018
    HIALEAH,FLORIDA,USA
    It is remarkable as well as those that work from factory
  1. Battery Access Modification
    By symplysimon in forum Stallion Trikes
    Last Post: 09-02-2021, 08:26 PM
  2. Trunk light modification.
    By Quietthunder in forum New Member Introductions
    Last Post: 09-07-2018, 06:08 PM
  3. Replies: 3
    Last Post: 03-01-2015, 12:16 AM
  4. Brake modification(disabled triker)
    By trikerAL in forum General Discussion
    Last Post: 02-22-2013, 12:34 PM
  5. Footwell Inserts/Modification
    Last Post: 10-26-2008, 11:31 AM
