14TG2TrampasHarley Tri GlideInstallation of a new Fuel Filter &...
14TG214TGHarley Tri GlideInstallation of a new Fuel Filter &...
Likes Likes:  5
Results 1 to 14 of 14
Thread: trike shut down again
    950+ Posts
    Oct 2014
    Rochester, NH, USA
    Default trike shut down again
    Going thru Hartford yesterday my trike lost power and motor shut down just like it did in Charlotte two years ago. Seems like this only happens when I'm travelling in 5th gear. In the slow stop an go travel at the exit I lost track of which gear I was in and when I got in with the flow of traffic I went into 5th gear and less then a mile down the road, my trike lost power. Luckily this time, I was in the right lane and had a very wide breakdown lane to coast to.
    seems strange that I can't ride in Overdrive (5th) but I can ride 70 mph in 4th gear for over a thousand miles. Will have it checked out this winter when I drop trike off for a few upgrades during my mechanics slow season.
    Any guesses on what the issue could be will be considered. My trike was converted from an 09 Yamaha Venture.
    Class Clown Bikerbozo's Avatar
    Jun 2010
    Coram, NY USA
    I’m thinking a neutral safety switch picking up the wrong tranny location.
    Gone But Not Forgotten
    Tech Contributor
    Lee H. Mann's Avatar
    Apr 2011
    Martinsburg, WV
    Quote Originally Posted by DblTrbl View Post
    Sounds like fuel related problem. Fuel filter, fuel line, fuel pump or gas cap vent stopped up. Fuel filter problems usually show up in high gear when demand for fuel exceeds delivery. If left unattended, the symptom will progress into the next lower gear until no fuel is allowed to pass at all.
    Jim Murphy
    Iron Butt Rider 2001
    950+ Posts
    Oct 2014
    Rochester, NH, USA
    Quote Originally Posted by Lee H. Mann View Post
    Had brand new fuel filter and fuel pump installed 10 days before my trip so that is not the issue. Will take a look at fuel line and gas cap.
    Thanks for the suggestion!
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Mechanics 101.........Go back to the last thing that you did.....
    2019 Tri-Glide.......
  6. #6
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    I would thoroughly check/test the charging/electrical system.
    It's possible that it is not putting out the proper voltage at higher RPM's, indicating a possible stator problem & or a voltage regulator issue.
  7. #7
    Dec 2014
    Grand Junction, Co. USA
    Check to see if it has a kick stand switch ... symptoms would be the same if the trike thought the stand was down, even if it's been removed (the stand).
  8. #8
    4750+ Posts
    Mar 2015
    Texas
    That wouldn't explain being able to ride in 4th for miles bu not 5th. I'd check the charging system. Like the voltage regulator but even that is questionable about the 4th and 5th thing. Is it possible to repeat the failure in 4th running the same RPM where it fails in 5th. The tach can cause failures like this too according to the dealer that worked on my Harley once. In my case my problem was only corrected with a ECM replacement. Hope you don't end up there.
    The only reason some people are still alive is it's illegal to shoot them.
    American Legion Rider
  9. #9
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Just another shot in the dark.......If it happens again , As your riding crack open the gas cap.......
  10. #10
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    What does losing power mean? Does it shutoff like you switched the ignition off? Does it seem to run normally, but you try to to turn the throttle and just won't go any faster? Does it sputter or run poorly just before it stops? Is it hard to restart or does it start immediately and run fine? If its shuts off like switch, its usually electrical. If it sputters to a stop like its struggling to go on could be a lack of fuel. When you're out on the highway trying turning the gas off. Does it replicate the condition, ie stop in the same way? Then you'll know how it runs when its running out fuel. Your mechanic will need all the info you can provide because it doesn't sound like something he can replicate on a test ride.
  11. #11
    750+ Posts
    Jan 2010
    east windsor ct
    just because its brand new doesnt mean its 100%... only means someone else hasnt owned it before....
    probably you are ok .... buuutt
  12. #12
    4750+ Posts
    Mar 2015
    Texas
    Yep, new parts can be bad right out of the box.
  13. #13
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    If the shop has a scan tool, they can check switch/ and relay functioning, plus every engine related sensor and actuator within minutes....talk a ride with the scanner hooked up and hopefully catch the problem when it happens.
    I would in this case, think the youngest technitian would be the most knowledgable and hopefully the most honest....
    forgot to add....to me, new, means (not worn out), not necessarily better or more reliable. But usually, new is better and more reliable.
  14. #14
    16500+ Posts
    ol' school's Avatar
    Sep 2015
    Mercersburg, PA
    Hope you get it figured out Dennis!
  1. Down Shifting for a slow-down
    By mgwtrike in forum Honda Trikes
    Last Post: 03-06-2016, 07:11 PM
  2. fuel shut down switch
    By Johnny Michael in forum Stallion Trikes
    Last Post: 05-26-2015, 08:17 PM
  3. rear cly. shut down
    By lboos in forum Harley Trike Conversions
    Last Post: 02-12-2013, 04:17 PM
  4. Stallion's Fuel Line Shut Off
    By Jerry126 in forum Stallion Trikes
    Last Post: 10-11-2012, 11:05 AM
  5. Temp Shut Down tonight server move
    By Papa Zook in forum General Discussion
    Last Post: 07-22-2010, 11:05 PM
