Likes Likes:  8
Results 1 to 19 of 19
Thread: easier clutch lever
    10+ Posts
    Apr 2013
    Rome, Wi. USA
    Default easier clutch lever
    I am in no way connected to this company. I was looking for an easier way to pull the clutch on a hydraulic clutch tri-glide. I found the solution at www.softbrake.com. They sell products to make your ride fit you better. Their service is great, prices fair and made in Idaho. Check them out.
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Quote Originally Posted by B&P View Post
    In your other post you said they were made in America , Now you say Idaho....
    Which is it.......................
    2019 Tri-Glide.......
    60+ Posts
    Jan 2018
    Milton Mills NH
    FWIW I put the Oberon on, really like it, got the clutch so it starts to engage right off the handle bars.
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    I have the softbrake and they are GREAT.
    100+ Posts
    Jul 2017
    Blacksburg, Virginia
    I tried Sofbrake's and the clutch lever didn't work with other than stock hand grips. Owner got irate because I didn't mention that I didn't have stock grips when I ordered. He finally agreed to issue a refund. The brake lever works great and I'm still using it.
  6. DKCustoms postbit
  7. #6
    1500+ Posts
    Apr 2016
    Dayton Ohio
    I have HD grips but not the stock ones.I asked about after market grips and they said that there was a very simple fix if the bike would not start in gear.They said to call back and they would walk me thru it.
  8. #7
    100+ Posts
    Jul 2017
    Quote Originally Posted by Mykneesbehurtin View Post
    He is all over the board with his advice then. Totally opposite from what he told me. But I'm not surprised.
  9. #8
    950+ Posts Free Bird's Avatar
    Mar 2018
    Saint Louis
    I just received my Softbrake levers.... What is the difference between them and the stock ones????? When you sit them side by side, they are IDENTICAL?
    Did I just get Carny'd?
  10. #9
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    Quote Originally Posted by Free Bird View Post
    You should be able to see that the softbrake levers are pulled back by 1". Stack the on top each other, you will see the difference.
    HOW CAN YOU HELP THE TRIKE TALK FORUM? Become a GOLD CLUB MEMBER!
    A veteran - whether active duty, retired, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to the 'United States of America', for an amount of 'up to and including my life.'
  11. #10
    Mar 2018
    Saint Louis
    Quote Originally Posted by nucseal View Post
    I did that...that is why I am asking the question. The picture below tells that story. The Stock Lever is on top. The picture shows a little difference on the ball end, but that is just the angle of the camera. They are identical...Stock FLRT and Softbrake. This is true for both Clutch and Brake Levers
  12. #11
    300+ Posts
    Mar 2018
    Waelder, Texas
    I am using the Softbrake clutch lever only and the side by side difference was very obvious. Seems you must have received a set that have not been reshaped. Send them the pic and I'm sure they will realize the mistake and make everything right.
  13. #12
    Dec 2014
    Grand Junction, Co. USA
    I like the soft brake (foot) ... makes using the rear brakes much more natural.
  14. #13
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    Something is definitely wrong there. Mine were noticeably different when stacked. Give him a call, he will make it right. He is a good guy to work with.
  15. #14
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Your profile says you have a 2013 TG, That's not hydraulic, is it?
  16. #15
    Mar 2018
    Saint Louis
    Sent them the pictures and they said return the levers for a refund. Didn't disagree with what I was saying. I will just leave it there for us to ponder.....
  17. DKCustoms postbit
  18. #16
    Oct 2017
    St. Louis, MO USA
    Hopefully they will take care of you. I firmly believe the best way to reduce the clutch pull is with the AIM cylinder, to fix the problem.
  19. #17
    Mar 2018
    Saint Louis
    Quote Originally Posted by MDO View Post
    I am sure they will. I have the AIM slave cylinder and it is going on the trike. So should be great....
  20. #18
    1500+ Posts
    Apr 2016
    Dayton Ohio
    Can you just google AIM slave cly to research or is there a web site?
  21. #19
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    https://aim-tamachi.com/collections/...slave-cylinder
  1. Lube Your Harley Clutch Lever
    By Jack Klarich in forum Harley Freewheeler / Road Glide 3
    Last Post: 09-17-2017, 05:10 PM
  2. Clutch Lever ?
    By hddocfl in forum Harley Tri Glide
    Last Post: 05-14-2017, 07:04 AM
  3. Replies: 12
    Last Post: 05-14-2017, 03:57 AM
  4. Have I found an Adjustable Clutch Lever for 2015 Triglde
    By Byker Triker in forum Harley Tri Glide
    Last Post: 04-05-2016, 02:53 AM
  5. Clutch Lever Sensor
    By OlBandit in forum Harley Trike Conversions
    Last Post: 08-31-2012, 07:03 AM
