Results 1 to 6 of 6
Thread: CSC lower trunk lid
    Aug 2018
    Weslaco tx usa
    Default CSC lower trunk lid
    I had a retro driveshaft kit installed a few weeks ago by a csc installer. Now the lower trunk lid will not latch unles pushed on very hard, then it will not release with lever on tour pack,I have to release it with the cable. The right side hinge was very loose, so I called csc and talked to Dwight who gave me 3 options to repair hinge. I repaired hinge which now is rigid.Still cannot get it to latch properly. The latch release on tour pack does not seem to do anything in the latch mechanism
    need some advice on what to do.
    2007 gl1800
    2007 cobra trike kit
    Apr 2010
    Shenandoah Valley of Virginia
    Mine (Lehman GTL) is tight enough that a gentle closing just catches first … or … safety notch. To close tightly, I place palm of hand against top edge and lean in. Snug but no leaks.
    Latch is adjustable.
    Just Killing Time...
    paws's Avatar
    Kerrville, TX U.S.A
    Hi David! Welcome to TrikeTalk from west Texas. I do not have an answer for you. Have you tried taking it back to the mechanic who just worked on it? Hope you are able to get this resolved soon.
    Aug 2018
    Weslaco tx usa
    Default Trunk lid
    300 miles away. I have made some adjustments, now able to get it to latch. Still unable to unlatch.
    Apr 2010
    Quote Originally Posted by Uphill View Post
    Is the cable in place?
    550+ Posts Mick's Avatar
    Feb 2008
    Midwest
    Name:  right rear mount for latch picture from front.jpg
Size:  181.8 KBName:  right rear mount for latch picture from back.jpg
Size:  182.2 KBYou might want to check out where the cable comes down from inside the upper trunk. I had an issue with my 07 Lehman the same way and it turned out the cable for some odd reason came off the latch assembly in the upper trunk and the only way I could open the lower trunk was with the emergency cable.
  1. Trunk lid fix
    By unforgivenracing in forum Honda Trikes
    Last Post: 03-05-2019, 06:13 PM
  2. Lid on lower trunk hard to latch
    By Uphill in forum Honda Trikes
    Last Post: 09-15-2018, 08:52 PM
  3. Freewheeler Trunk Lid Button/ Helps With Shutting Without Slamming Or Dropping Lid
    Last Post: 05-28-2015, 09:12 AM
  4. Finally Got the Trunk Lid Replaced
    By lgjhn in forum Honda Trikes
    Last Post: 12-19-2013, 02:40 PM
  5. Trunk Lid Extremely POOR Fit
    By CUNDEL in forum Stallion Trikes
    Last Post: 02-18-2012, 06:59 AM
