Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  3
Results 1 to 7 of 7
Thread: Hannigan - Honda front fork fluid and spring question
    Dec 2016
    OldLyme, CT
    Default Hannigan - Honda front fork fluid and spring question
    The bike is a 2010 GL1800 with the Hannigan kit installed.
    The forks can be a little harsh at times and I will be changing the fork fluid.
    My question is, has anyone with the same bike set up changed out the springs for something other than Progressives?
    And if you kept the Progressive springs installed what fork oil do you prefer?
    Dan
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    2
    Quote Originally Posted by Dan T View Post
    Dan
    Some of the Hannigan staff insists that Progressive springs are a must and I've disagreed with them on this since day one of becoming a Hannigan dealer 10 years ago. Progressive springs make for a much harsher ride and about half of the customers that have had me change to Progressive springs, have had me remove them and replace with the stock springs after experiencing the ride. Running a lower weight fork oil will not cure the harsh ride.
    Jun 2010
    Indianapolis, In.
    +1 on Zook's post
    What pressure are you running in the front tire?
    38psi is the sweet spot for my Wing/Hannigan w/stock springs
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    1500+ Posts
    Oct 2012
    Batavia Ohio
    Progressive's were so harsh it cost me a front fender. My installer told me in 2014 that several of his customers wanted the Progressive's OUT after riding their conversion a few months.
    950+ Posts JaysGone's Avatar
    Nov 2012
    Delray Beach Florida
    2
    Not going to be very helpful here.
    But my biggest complaint with Honda cruisers has been the front end. Having one tube a shock and one a dampner.
    Stay with the stock springs. Progressive will 101% give you a harsher ride. I had a 99 Valkyrie and tryed both progressive and went back to stock springs. I used 5. 7 10 and 15 weight oils. None helped.
    Bought the 2010 GL1800 used and same issue same setups no hope here. Im curious about the 2018 having an all new front end and what they did??
    4250+ Posts
    Marc H's Avatar
    Dec 2011
    Evensville,Tn.
    Took the Progressives out of my 1500 and went with Racetech.Personally i would go with Racetech or Traxion before Progressive and on a 1800 I would lean toward Traxion.If I were upgrading springs.
    1989 GL1500 Goldwing (SOLD)
    2006 GL1800 CSC
    100+ Posts wingit's Avatar
    Jul 2015
    Richmond Mn.
    Default went with RaceTec
    Hello friends, 03 GL1800 champ solid axle trike. I changed out the sagging progressive springs 25000 miles ago with RaceTec. I guess The RaceTec or another brand with a continuous wind of spring spacing was a better idea. IMHO owning a Tool & Die shop 40 years, the Progressive tight wind is too strong and you give up travel. My 110 Racetec haven't sagged,they are still an inch higher than the original which had 20000+ miles. I used spacers 3/4 inch, recommended 1.25" Ride is fine. Maybe 1.25" gets same ride with higher front ??? I would do this again, I can't compare with anything else but I wanted a softer ride and raised front. I hear we should change stock springs out ever 25k , thats Nuts, Imagine changing my car springs at 25k ?? Has anybody else used these with more spacers ? like over an inch they recommend ?
    Happy Day
  1. Replies: 10
    Last Post: 06-20-2016, 05:23 PM
  2. Fork seals and spring replacement
    By hisst in forum Honda Trikes
    Last Post: 02-22-2016, 11:46 AM
  3. Race Tech Fork Spring Set-Up Question
    By scribe5 in forum Honda Trikes
    Last Post: 02-16-2014, 08:15 AM
  4. Fork spring help
    By Deadeye in forum Honda Trikes
    Last Post: 08-04-2012, 11:39 PM
