Likes Likes:  3
Results 1 to 9 of 9
Thread: Cruise Control on VW trikes
    Sep 2018
    Joshua, Texas
    Default Cruise Control on VW trikes
    Will be buying a VW trike in the near future. Does any one know about cruise control that will work on them. I havent seen any yet that say they have it. I had it on my last two Harleys and it sure made things better. Arthritis makes my hand go numb if slow riding a lot. May have to deal with it. Figures with this wealth of knowledge on here someone would know if it can or has been done in the past. Dont know if what I buy will have a foot or a twist throttle...havent found the right one yet. Not may VW trikes in my area to look at. They seem to be everywhere except where I am....lol
    Thanks in Advance
    Big D
    450+ Posts
    Mar 2018
    Fernley
    A newer bug electrical system may have the electronic controlled cruise control in it.
    Older bugs do not have cruise control, unless some one installed a aftermarket set up.
    I just never favored cruise control on the bike, kinda thought about it on the trike, but just do not feel comfortable with the idea. Maybe just a mechanical lock into position type, something with a quick release might be fine, but I do not see the mess of wires and electronics worth it all.
    Hope you the best.
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    rostra on ebay has universal ones, that I think would be adaptable.
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    I dont think the air cooled vw had a cruise control option from the factory.
    I think there are aftermarket units and possibly even some that had dealer installed units.
    I have used the motorcycle throttle locks and been happy with that.
    Right now I have a harley style throttle with the tension thumb screw on the bottom. I just tighten it enough to hold where I leave it. The only problem with that is that it takes too much attention to set up the first time.
    Apr 2015
    Batesville, AR. 72501
    I see you are located in Texas. Better research current status of registration laws in Texas for VW (or other "homemade") trikes: https://www.triketalk.com/forum/threads/29446-Texas-Law
    Cruise control may be a moot point.
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    I have heard a lot of different stories since that old post.
    One being in how it was originally registered. With just the way it is worded making the difference.
    Others claiming even if it passes registration, if it is an obvious fab build and you are caught/questioned by the police they will pull the registration.
    Then I hear a lot of fab built trikes are being sold out of the state.
    Also hear of less trustworthy folks finding they can no longer register and selling to an unknowing buyer.
    What all is actually true and do-able in Texas......I do not know.
    Our founder here, Papa Zook, is in Texas. Maybe he has seen the laws and knows more about it all.
    450+ Posts
    Mar 2018
    Fernley
    Wow some people. Spend the money and than it can not be registered in your state, that would get me upset.
    So I just remembered a few years back I filed a non op on this trike. I better get down to DMV and get the new registration on it while I can before it is to late.
    100+ Posts
    Sep 2016
    Sitka, Alaska USA
    +1 on the universal Rostra. I've got one one my homebuilt. Works just like a car.
    100+ Posts sonny8l3's Avatar
    Oct 2014
    Livingston (Colyell ), Louisiana, USA
    Hello, I have a Vista throttle lock on trike that I took off of my Nomad and it works pretty well without costing a bunch. It is a thumb lock with a tension set nut. I tighten the nut enough that the throttle is a bit hard to turn. NOTE: if you do this, tell the mechanic or they might ride it right to be back wall expecting the throttle to shut down automaticly. It will tick them off. My trike was home built in Tx. The builder got it finished just after the Tx. law changed. He had a title for the front end and transfered it to an Ok. title. I bought it with an Ok. title. I don't know if Tx. has changed the laws to make it easier, but it would warrent a look before buying. Getting a title on a homemade any thing is La. is an ordeal.
    Thanks for your time.
  1. Cruise control problem
    By lamornawing in forum Honda Trikes
    Last Post: 03-26-2023, 02:48 PM
  2. Eat broccoli & get a free cruise control!
    By Dante221 in forum Harley Trike Conversions
    Last Post: 08-21-2011, 03:40 PM
  3. Electrical problems - horn, cruise control
    By gctrikeguy in forum Stallion Trikes
    Last Post: 07-23-2011, 07:21 PM
  4. No brake lights...no cruise control
    By ODDOMAN in forum Stallion Trikes
    Last Post: 09-24-2010, 11:38 PM
  5. cruise control issue
    By cowboy in forum General Discussion
    Last Post: 04-07-2008, 05:04 PM
