Results 1 to 3 of 3
Thread: Flushing Brake system
    5+ Posts freedomrunner's Avatar
    Mar 2018
    Acton, Indiana, United States
    Default Flushing Brake system
    I have a 2008 Goldwing with a 2008 Motor Trike Spyder kit. I had the bike serviced and inspected by a Honda dealer in Ohio which suggested that I have the brake system flushed. I drove it home, about 100 miles, and made an appointment with a local dealership to have the clutch system, radiator and brake system flushed. Two days later, I picked up the bike, went for a nice ride and parked it. Several days later, I looked at the receipt and saw that it said Flush "front" brake system. My question is, can the front brake system be flushed without flushing the rear system? If so, would a Honda dealer, really flush just the front system and not touch or mention that the rear system should be flushed? Is the brake system on the MT kit designed such that a Honda dealer won't flush it?
    Thank you,
    Head Scratcher in INDY!
    Larry
    Just my thoughts from reading the trike boards over the years....The front is A Honda....
    The rear end is something else...So its out of some dealers expertise...
    Just curious why didn't you have the first dealer do it when he recommend it...
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Quote Originally Posted by freedomrunner View Post
    Thank you,
    Larry
    I would think that flushing the brake system would mean the whole brake system, front and rear.
    Unless the conversion was done less than 5 years ago, flushing the rear system should have been done.
    The systems are separate of each other and that makes it even less complicated than it was originally.
    If you had the 2012 brake recall done recently, that would have involved the rear brakes only.
    It appears there was a communication error in play here.
    Jim Murphy
    Iron Butt Rider 2001
  1. Brake flushing order? MT Conversion
    By KYBubblehead in forum Honda Trikes
    Last Post: 08-15-2019, 11:05 AM
  2. Linked Brake System Info And Explanation Of How It Works
    Last Post: 09-10-2018, 10:56 AM
  3. Linked Brake System Info And How It Works
    By Bill G in forum Harley Tri Glide
    Last Post: 06-05-2015, 03:06 PM
  4. attn. anyone installing the perf. machine stage 1 brake system(help)
    By eagle1 in forum Harley Trike Conversions
    Last Post: 02-20-2012, 10:15 AM
  5. K-Lever Brake System
    By Aussie Annie in forum Harley Trike Conversions
    Last Post: 12-13-2011, 12:30 AM
