Likes Likes:  1
Results 1 to 11 of 11
Thread: Advice and questions about front tire
    300+ Posts paid4c4's Avatar
    Mar 2016
    Crestview Hills, KY, USA
    Default Advice and questions about front tire
    We have a 2012 Honda Goldwing, California Side Car Trike with 7,400 miles. I am the second owner purchasing June, 2017 after seeing an advertisement on this forum. I bought it from the original owner who purchased it new and had it triked. I inspect the trike a couple of times a year checking fluids, lug nuts, etc. While inspecting this week I noticed the front tire is really getting worn. The ridge which goes all the way around the center of the tire is very thin. I check the air pressure monthly and have only had to air one time. My question is this type of wear normal? What should I replace it with? The miles on the bike are from two caring older owners who haven't been particularly hard on the trike. Opinions and suggestions are welcome.
    Thank You;
    33500+ Posts
    David357's Avatar
    May 2015
    Hobe Sound, FL.
    Hi Bill,
    There is a Trike Talk forum dedicated to nothing but tires, wheels, brakes and front ends.
    Hopefully, this thread will help provide you some useful information.
    Here is the link to connect you there directly:
    https://www.triketalk.com/forum/foru...akes-Front-End
    I use an Avon Trike tire and enjoy the performance from the tire. I replace the tire at about 9 to 10 K miles.
    80+ Posts 6X3's Avatar
    Nov 2014
    Lincoln, Nebraska
    Default Avon Cobra Trike
    9K???? I got 22K on my last one. Still okay, but close to the wear bars.
    33500+ Posts
    David357's Avatar
    May 2015
    Hobe Sound, FL.
    Quote Originally Posted by 6X3 View Post
    Mileage will vary from rider to rider, road surface conditions, twisty mountain roads, riding style, loaded weight, tire pressure and many other factors.
    Mar 2011
    mountain home,ar. USA
    Quote Originally Posted by paid4c4 View Post
    Thank You;
    1. you didn't state what tire you have now and what pressure you are running. That will help us determine if this wear is unusual. Also, I notice you are in Ky. Do you routinely ride on curvy roads riding two-up?
    2. There are three primary tires used by GW trike riders: Michelin MPA and Battleax BT-45. Both are rear sport bike tires, bias ply and normally use 40-42 psi. The third choice is the Avon Cobra Trike front tire and it is a radial. I think the Avon gives better ride and handling. I live and ride in the Arkansas twisties and routinely get 10-13 k miles per tire. Flatlanders do much better but then I'm probably having more fun.
    Anyway, hope this helps. If you can give us some more info maybe we can give you better info.
    If the answer is yes to the
    Sep 2012
    Lakeland, FL
    Good stuff Mike, thanks, I've probably read most, but a refresher. I'm a Cobra user now, but not so sure I'll repeat, might go with the MPA since I've been there, done that with BT45 (rear) and Cobra. Can't complain about the BT45, it's less dollars, probably more miles, and I can't feel much difference in the ride in that and the Cobra.
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Bridgestone has the new Battlecruise H50 now & I just found it for $109 + free shipping & Bridgestone has a $30 rebate till the end of the month(I Believe)
    $79 for a front tire for my Freewheeler is an attractive price.
    Apr 2010
    Shenandoah Valley of Virginia
    Quote Originally Posted by David357 View Post
    Hi Bill,There is a Trike Talk forum dedicated to nothing but tires, wheels, brakes and front ends.
    For real?
    Apr 2010
    I see I replied to a thread there in / about July '16 …. it is easily forgotten.
    2000+ Posts trikeman's Avatar
    Oct 2010
    Jackson Tn. Madison Co.
    It’s called Part-Timers Disease
  1. Avon AV-71 Front Trike Tire - anyone using this tire???
    By dadztoy in forum Outrigger Style Trikes
    Last Post: 02-16-2024, 04:24 PM
  2. Seeking Advice re: Jacking trike to remove front wheel
    By Robert53 in forum Harley Tri Glide
    Last Post: 04-09-2017, 08:20 PM
  3. tire size for rear tire on front? 2007 goldwing trike
  4. Rear shocks and front springs questions
    By Lakota in forum VW Powered Trikes
    Last Post: 04-18-2013, 11:37 AM
  5. Front Tire questions
    By SJR in forum Harley Trike Conversions
    Last Post: 06-18-2011, 11:21 AM
