Likes Likes:  5
Results 1 to 13 of 13
Thread: Water getting into rear lights lens casing?
    Sep 2016
    Springfield, Mass. USA
    Default Water getting into rear lights lens casing?
    Whenever I wash my bike, (which is very often) I find water is getting into the rear light lens...I always blow dry the water off my bike to keep from leaving water marks, on the paint, after washing it .BUT I have to also blow all the water out of the bottom of the lens, quite a bit of water goes in there...(I have not rode it in the rain as of yet, but I'm quite sure water will also flow in during a rain ride as well)
    Is there suppose to be some kind of gasket between the lens and body to keep water from entering the lens??
    O' this is a 2010 Goldwing with a ROADSMITH
    Or what can you suggest, I can do to keep water from entering those rear light lens????
    Thanks in advance for any help giving!
  2. Roadsmith banner
  3. #2
    Sep 2012
    Lakeland, FL
    Ronnie, I've not had that problem with my RS and really can't make an informed recommendation. I suppose if I had the problem, I'd take a look on how to get the lens off and check the gasket for a crimp. I know it's not much, but it's all I got.
  4. #3
    Mar 2011
    mountain home,ar. USA
    Are you sure it is inside the lens? I ask because when I wash mine I always have water between the light unit and the body which comes out when I blow dry it. It looks like it is in the lens but it really isn't on mine.
  5. #4
    Sep 2016
    Quote Originally Posted by mhgoldwing View Post
    Yes, that's exactly what it does, after I wash it, I have to blow the lens to get the water out, I think I will take the lens off to see what is causing this water to get inside the red lens..
  6. #5
    Sep 2016
    Hey Bill,
    I'm going to remove the lens this morning and check to see what the problem is... I don't want to keep blowing light bulbs everytime, I ride my bike in the rain... I just may try a silicone coating around the lens, to keep it water proof.
    Jun 2010
    Indianapolis, In.
    The lens and housing are bonded together. You cannot just remove the lens. There is a flange around the outer edge of the lens which is outside of the lens to housing seal.
    I suspect this is were the water is getting trapped. It's OK to blow it out.
    If you want to remove the lamp to inspect it to see if you're really getting water intrusion in the lamp, you have to remove the whole lamp by removing the mounting nuts in the fender.
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    Well if you don't ride in the rain like you say, Then its a simple fix Just stop washing it with water..........
    Sep 2016
    I'm very OCD here, I can't go a week without givin her a good bath, and can't go a rain storm without given her a good wax job (while sitting in my garage)
    Aaaaaaaaaaaaaaaaa life is good! Shiny and clean/waxed is even better!!!
  10. Roadsmith banner
  11. #9
    +1
  12. #10
    10+ Posts Wind Therapy's Avatar
    Jul 2018
    Fredericksburg, VA, USA
    Default I'd rather be riding than cleaning . . .
    But, I do try to keep up appearances!
    Dave
  13. #11
    Sep 2016
    Quote Originally Posted by Wind Therapy View Post
    Dave
    Hi Dave,
    Yep nothing is really more satisfying then showing up for a ride with other riders with a nice clean machine..
  14. #12
    Mar 2011
    Hi Dave,
    What was the outcome? Did you find water inside the lens?
  15. #13
    Sep 2016
    Thanks for asking, I put a "bead" of silicon around the lens, and that did stop water from entering...So far so good!
  16. Roadsmith banner
  1. Viper running board turn lights broken lens
    By pwhoever in forum California Sidecar Trikes
    Owners Forum
    Last Post: 05-01-2019, 09:44 PM
  2. Replies: 14
    Last Post: 09-09-2018, 09:02 AM
  3. Considering getting into Trikes
    By Traveling Man in forum New Member Introductions
    Last Post: 10-27-2016, 07:01 AM
  4. hard getting into mechanical reverse
    By engprosinc in forum Harley Trike Conversions
    Last Post: 06-20-2013, 02:25 PM
  5. getting into neutral
    By Frang in forum Harley Trike Conversions
    Last Post: 05-06-2011, 07:48 AM
