chucktrue556Jack KlarichHarley Freewheeler /...Rear shock adjustment
ZZMACH12Jack KlarichHarley Tri GlideSTOCK HARLEY ECM MAP with DynoJet
ctdair9Jack KlarichHarley Tri GlideHot Rotors After New Pads
rhino 212Jack KlarichGeneral DiscussionRainey day thought's ¶¶¶
ctdair9ctdairHarley Tri GlideHot Rotors After New Pads
rhino 212rhino 2General DiscussionRainey day thought's ¶¶¶
ZZMACH12ZZMACH1Harley Tri GlideSTOCK HARLEY ECM MAP with DynoJet
ctdair9ROAD DOGHarley Tri GlideHot Rotors After New Pads
rhino 2121dn5upGeneral DiscussionRainey day thought's ¶¶¶
ZZMACH14ZZMACH1Harley Tri GlideElectric Fans on 2014 Tri Glide
Davep10SullyNew Member Introduct...Hello from the mountains
rhino 212Phu CatGeneral DiscussionRainey day thought's ¶¶¶
ZZMACH14ol' schoolHarley Tri GlideElectric Fans on 2014 Tri Glide
hardwickbv3KoolbreezeHarley Tri GlideGot a Code P0152 Engine Running Ric...
Davep10DavepNew Member Introduct...Hello from the mountains
Davep10woodyNew Member Introduct...Hello from the mountains
dthorn6Jack KlarichHarley Tri Glide2024 Tri Glide front axle nut torqu...
Davep10Jack KlarichNew Member Introduct...Hello from the mountains
Davep10ol' schoolNew Member Introduct...Hello from the mountains
Tritek1TritekLehman TrikeAvoid buying a Lehman?
ZZMACH14Rmitchell55Harley Tri GlideElectric Fans on 2014 Tri Glide
Davep10trike ladyNew Member Introduct...Hello from the mountains
Bonsai11Marc HNew Member Introduct...New member from Texas
Davep10Marc HNew Member Introduct...Hello from the mountains
Bonsai11ZammyNew Member Introduct...New member from Texas
Davep10ZammyNew Member Introduct...Hello from the mountains
chucktrue556ZammyHarley Freewheeler /...Rear shock adjustment
Bonsai11Uncle FesterNew Member Introduct...New member from Texas
Davep10Uncle FesterNew Member Introduct...Hello from the mountains
ZZMACH14rhino 2Harley Tri GlideElectric Fans on 2014 Tri Glide
dthorn6dthornHarley Tri Glide2024 Tri Glide front axle nut torqu...
ctdair9MykneesbehurtinHarley Tri GlideHot Rotors After New Pads
chucktrue556rhino 2Harley Freewheeler /...Rear shock adjustment
chucktrue556JTJerseyHarley Freewheeler /...Rear shock adjustment
chucktrue556ROAD DOGHarley Freewheeler /...Rear shock adjustment
ctdair914TGHarley Tri GlideHot Rotors After New Pads
Sunman7pwhoeverHonda TrikesF1 Warning Light
Davep6DavepHarley Tri GlideTRI GLIDE AIR FILTER QUESTION
Sunman7GoldWingrGregHonda TrikesF1 Warning Light
chucktrue556chucktrue55Harley Freewheeler /...Rear shock adjustment
Davep10rhino 2New Member Introduct...Hello from the mountains
Bonsai11Papa ZookNew Member Introduct...New member from Texas
Bonsai11SullyNew Member Introduct...New member from Texas
Bonsai11BonsaiNew Member Introduct...New member from Texas
hardwickbv3Jack KlarichHarley Tri GlideGot a Code P0152 Engine Running Ric...
DrCrazyTrain5Jack KlarichHarley Freewheeler /...True Dual Header
Bonsai11Jack KlarichNew Member Introduct...New member from Texas
gfaltersack8Jack KlarichHarley Tri GlideDK Customs remote oil filter kit in...
kj5ix32ADSavareseHonda TrikesMotor Trike Service Manual Finished
gfaltersack8Old Road DogHarley Tri GlideDK Customs remote oil filter kit in...
Davep6Old Road DogHarley Tri GlideTRI GLIDE AIR FILTER QUESTION
ctdair9Old Road DogHarley Tri GlideHot Rotors After New Pads
Bonsai11ol' schoolNew Member Introduct...New member from Texas
Sunman7rhino 2Honda TrikesF1 Warning Light
Papa Zook1Papa ZookHarley Tri Glide2024 Harley Trikes Lineup - Laidlaw...
Bonsai11rhino 2New Member Introduct...New member from Texas
Bonsai11GorillaNew Member Introduct...New member from Texas
Rawhideken1714TGHarley Tri Glide2024 Tri glide
kj5ix32trike ladyHonda TrikesMotor Trike Service Manual Finished
Bonsai11trike ladyNew Member Introduct...New member from Texas
Sunman7BowdenTrikeHonda TrikesF1 Warning Light
LD-Ordie10Marc HNew Member Introduct...Newbie from the Mojave Desert
ADSavarese13ZammyNew Member Introduct...New member from FL
DrCrazyTrain5rhino 2Harley Freewheeler /...True Dual Header
LD-Ordie10ZammyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie10Uncle FesterNew Member Introduct...Newbie from the Mojave Desert
DrCrazyTrain5Ron BaxterHarley Freewheeler /...True Dual Header
Burnerboy10rhino 2Can Am Spyder Trike...How many of you ride a Can Am spyde...
DK Custom Products362PosseRiderHarley Tri GlideWhat did you do to Your Tri-Glide T...
Davep6rhino 2Harley Tri GlideTRI GLIDE AIR FILTER QUESTION
Sunman8PuckoachHarley Freewheeler /...Value of 2015 Freewheeler
dthorn6rhino 2Harley Tri Glide2024 Tri Glide front axle nut torqu...
gfaltersack8rhino 2Harley Tri GlideDK Customs remote oil filter kit in...
gfaltersack8gfaltersackHarley Tri GlideDK Customs remote oil filter kit in...
hardwickbv3hardwickbvHarley Tri GlideGot a Code P0152 Engine Running Ric...
dthorn6Papa ZookHarley Tri Glide2024 Tri Glide front axle nut torqu...
SSpoon14cycle7447New Member Introduct...Hello from VA
Richard D12CorkeykHarley Trike Convers..."Himsl Praying Mantis" Sh...
gfaltersack8ISP-FLHarley Tri GlideDK Customs remote oil filter kit in...
LD-Ordie10ol' schoolNew Member Introduct...Newbie from the Mojave Desert
Rawhideken17KoolbreezeHarley Tri Glide2024 Tri glide
LD-Ordie10trike ladyNew Member Introduct...Newbie from the Mojave Desert
Davep6KoolbreezeHarley Tri GlideTRI GLIDE AIR FILTER QUESTION
LD-Ordie10GorillaNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie10rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie10SullyNew Member Introduct...Newbie from the Mojave Desert
ADSavarese13SullyNew Member Introduct...New member from FL
Davep6Jack KlarichHarley Tri GlideTRI GLIDE AIR FILTER QUESTION
LD-Ordie10Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
Rawhideken17LD-OrdieHarley Tri Glide2024 Tri glide
ADSavarese13Jack KlarichNew Member Introduct...New member from FL
ADSavarese13woodyNew Member Introduct...New member from FL
LD-Ordie10LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
ADSavarese13hardwickbvNew Member Introduct...New member from FL
SSpoon14hardwickbvNew Member Introduct...Hello from VA
ADSavarese13ol' schoolNew Member Introduct...New member from FL
Davep6New Orleans KevinHarley Tri GlideTRI GLIDE AIR FILTER QUESTION
gfaltersack8TFNCHarley Tri GlideDK Customs remote oil filter kit in...
ADSavarese13GorillaNew Member Introduct...New member from FL
ADSavarese13Marc HNew Member Introduct...New member from FL
ADSavarese13ADSavareseNew Member Introduct...New member from FL
ADSavarese13Phu CatNew Member Introduct...New member from FL
ADSavarese13trike ladyNew Member Introduct...New member from FL
ADSavarese13Uncle FesterNew Member Introduct...New member from FL
dthorn6nucsealHarley Tri Glide2024 Tri Glide front axle nut torqu...
Likes Likes:  1
Results 1 to 10 of 10
Thread: jacking up a Roadsmith HTS1800 with a conventional MC jack?
    10+ Posts Wind Therapy's Avatar
    Jul 2018
    Fredericksburg, VA, USA
    Default jacking up a Roadsmith HTS1800 with a conventional MC jack?
    I was sitting in my garage the other day, enjoying listening to the torrential downpour outside; when I noticed my partially hidden and now neglected Motorcycle Jack. I wasn't ambitious enough to dig it out of the pile it was hiding in to try it on my HTS1800 Roadsmith; but I was wondering if it might be used at the rear of the trike.
    Anybody ever try this?
    Dave Calahan
  2. Roadsmith banner
  3. #2
    Sep 2016
    Springfield, Mass. USA
    Good question here:
    I also have a two wheel'd lift that Santa Claus brought to me a few years ago, and really only used it a couple of times (sorry Santa)... BUT now that I have triked out my Goldwing, I've been using a regular three ton jack, that works quite well, I just put jack under engine, and that lifts up my front end , or I place jack under the rear and that lifts up the rear.... In Fact just yesterday I place a wheel chock in front of my front wheel, and lifted up my rear end and washed all under the rear with soap/water, planning on putting her away for the winter season soon.................. Before I do that, I give her a good waxing, all over, especially the chrome areas, call XM radio and cancel out my subscription for the winter season, change out the oil and filter, place a battery tender on the battery leads, put gas stabilizer in gas tank and then pull out my snow skies, and pray for snow!!!
  4. #3
    Jul 2018
    Default I think I might have a MC Jack "FOR SALE" . . .
    Hi Ronnie,
    I'm just getting over knee replacement surgery (8/13/18); but as soon as I can kneel; I'm gonna try using it under the rear. If it doesn't work, I'll sell it to one of my 2-wheeler buds.
    BTW, my trike will get no rest for the foreseeable future. I commute from Fredericksburg, VA to Washington, DC and back, 5-days a week (110 miles round trip), all year 'round (except for snow and ice days, and other weather anomalies). This is my 5th Goldwing since 1998, and I'm well over a 1/2 million safe miles as the result of my weekly commute and 5 1/2 years as Sr. Chapter Director of GWRRA Chapter VA-E, Fredericksburg, VA. I also served 10 years as an MSF Instructor / Rider Coach.
    I will try to keep Wind Therapy 5.0 as clean as I can, but she picks up finely ground tire rubber from the millions of cars and trucks that travel I-95 every week, which makes for a filthy undercarriage and crud build-up under the tupperware. I can't seem to keep a respectably shiny front wheel either. But . . . I'd rather be riding than cleaning anyway!
    Dave
  5. #4
    Sep 2012
    Lakeland, FL
    I run my rear wheels up on car ramps to get to the underside, then lift the front with the jack using a wood buffer between the jack and engine contact point. My GW ground clearance is too low to get the jack and wood buffer under the machine, so I run the front tire up onto a 2x4 to give me clearance. Level the machine if I'm doing an oil change; side note, if you don't level the GW off and just jack up the front, you're facing an overfill, that's common sense, and yet.....duh! Anyway, my question, if just jacking up the rear of the machine, exactly where do you place the jack?
  6. #5
    Sep 2016
    My rear is on a jack as we speak...... Look under rear, and see a section that is flat steel, and place jack under the steel......lift's nice and easy
    Sep 2012
    Lakeland, FL
    Thanks Ronnie, I'll check, but I have the 1 1/4" slide hitch which came with the conversion, which I think covers the flat metal piece you refer to.
    Sponsor - Roadsmith Trikes
    TrikeTalk Sponsor
    Roadsmith Trikes's Avatar
    Mar 2008
    MN
    Jack points are as follows: bottom of shock tower (underneath coil-over shock), main-frame tube (2-1/2 round tube at most forward part of conversion), or the 1/4" steel plate that holds up the back of the differential (area where trailer hitch connects to chassis). Please DO NOT use the drive-shaft or differential retaining bars as jack points.
    As in doing any type of work on your trike, please take care to ensure trike is completely secure before performing any maintenance or cleaning. Use of jack stands is highly recommended.
    Mar 2011
    mountain home,ar. USA
    Quote Originally Posted by Roadsmith Trikes View Post
    Yep. To remove rear wheels the trike cannot be lifted by the shock tower lift points because that drives the axle up into the fender well and the tire can't be removed with breaking some bodywork. I lift at the 1/4" plate for one side and put jack stands under round tube.
  10. Roadsmith banner
  11. #9
    Oct 2018
    BURGAW North Carolina
    Default Raising Goldie
    What I've been doing is using 3 8x8 wood blocks cut on a long angle and I just drive up on them if I want to get under the bike, once I lifted it up with the receiver hitch but you have to put a small floor jack under one of the shock brackets or it will want to go over on one side [won't do that again] but it was a easy way to take off one tire at a time. Poor man has poor ways.
  12. #10
    Sep 2016
    Quote Originally Posted by The Breeze View Post
    +1 on your idea, I do the same! I also cut six 12inch, 2x10 boards and screwed two boards together, now they are 4inch higher, and place boards under each wheel... now I can work under trike, a bit easier! Ronnie
  1. Rear rotors- brakes 2012 gl1800 hts1800
    By bmarcia115 in forum Roadsmith Trikes
    Owners Forum
    Last Post: 09-01-2018, 03:29 PM
  2. Roadsmith HTS1800 Trunk Adjustment Video
    By Cut N Shoot Customs in forum Cut N Shoot Customs
    Last Post: 02-12-2018, 09:47 AM
  3. Roadsmith HTS1800 Trunk
    By rogerm60 in forum Honda Trikes
    Last Post: 10-25-2015, 10:11 AM
  4. Roadsmith HTS1800 Trike Owners....need opinions
    By Haste Maker in forum Honda Trikes
    Last Post: 10-02-2015, 06:45 PM
