Likes Likes:  5
Results 1 to 16 of 16
Thread: Rear Brake reservoir 98 GW Motortrike where is it?
    Oct 2018
    SURPRISE AZ
    Default Rear Brake reservoir 98 GW Motortrike where is it?
    OK I have nothing when I step on the pedal for the rears. The Shop manual says the reservoir is next to the battery but it's not there.I got no paperwork with this when I bought it so I'm playing hide and seek. Can anyone point me in the right direction?
    Oh yeah no rear brakes when I bought it.
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Quote Originally Posted by Big Tom View Post
    Rear brake reservoir should be located to the rear of the battery.
    Remove the right side cover.
    The lid is kinda hard to get to though.
    The GL1500 has linked brakes so you will also have to bleed the left front caliper after bleeding the rear system, provided the original converter didn't disconnect or eliminate the link to front system from the rear.
    Jim Murphy
    Iron Butt Rider 2001
    Mar 2011
    mountain home,ar. USA
    Watch this:
    Oct 2018
    SURPRISE AZ
    Yup. I know all that, see my picture to clear up the misconception. I now have a trike body covering that spot.
    Jun 2008
    Lovington, NM, U.S.A.
    Why do I have the feeling if you remove the battery it is hiding behind it. The flat metal plate along side the battery in the second pic gives me a hint.
    Retired trike builder
    Oct 2018
    SURPRISE AZ
    I was thinking that plate was structural as it is 1/4 inch thick. I was going to pull the battery today but seeing the battery box stopped me. I'll look back there tomorrow. When I find it I'll post a picture..
    Apr 2010
    Shenandoah Valley of Virginia
    They just pointed out where it's at, not that reaching it will be easy. It should be easier if battery is set aside as stated though.
    Jun 2010
    Indianapolis, In.
    OK I have nothing when I step on the pedal for the rears. The Shop manual says the reservoir is next to the battery but it's not there.I got no paperwork with this when I bought it so I'm playing hide and seek. Can anyone point me in the right direction?Oh yeah no rear brakes when I bought it.
    To speak with a Motor Trike customer service representative please call
    1-800-908-7453
    That should get you the answer you need
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    Oct 2018
    SURPRISE AZ
    1-800-908-7453
    I will call tomorrow if I don't find it behind the Battery Box today.. Thanks.
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    Can't you just follow the rubber line up from the master cylinder. It should end at the reservoir. I know sounds simple but with all the crap in the way maybe it isn't. Just a thought.
    200+ Posts
    Feb 2017
    Arp, TX - USA
    Based on the pictures you've got an oldie there. Was way before my time with the company, but on ones that old, they relocated the reservoir to the empty area where the rear tire for the motorcycle used to reside (above the differential). Why they did that I don't have any idea, but the easiest way is to either chase the bracket or follow the reservoir tube to the location.
    I'd be lying if I said it was a fun location to get to in order to add fluid, flush, or bleed your brakes. Down side is moving it back behind the battery on an already built trike would be a pain as well & would likely get air in the system & force you to flush the entire system whether you wanted to or not
    Oct 2018
    SURPRISE AZ
    And, here it is. Behind the Battery box. Gonna be fun getting the cap off with the inner fender right there..
    Martinsburg, WV
    Unbolt the reservoir and swing it out.
    Jim Murphy
    Oct 2018
    SURPRISE AZ
    Why didn't I think of that.... Too busy thinking about the dirt from the fender falling into it. Thanks for the heads up..
    Apr 2010
    2000+ Posts trikeman's Avatar
    Oct 2010
    Jackson Tn. Madison Co.
    Trike Talk is a wonderful venue and a wealth of information.
  1. CSC Viper Rear Brake Fluid Reservoir
    By Tony8 in forum California Sidecar Trikes
    Owners Forum
    Last Post: 04-15-2018, 11:53 AM
  2. Freewheeler Brake Reservoir Relocation and other "Clean Up"
    By Free Bird in forum Harley Freewheeler / Road Glide 3
    Last Post: 04-04-2018, 07:29 AM
  3. Drum to Disc Conversion for Motortrike 9" drum brake system
    By Lee H. Mann in forum Tires, Wheels, Brakes, Front End
    Last Post: 02-08-2018, 03:41 PM
  4. Rear brake master cylinder reservoir idea
    By Dirtydan in forum Victory Trikes
    Last Post: 08-03-2016, 09:40 PM
  5. Motortrike Drum Brake Rattling Info
    By FLTR2008TRIKE in forum Motor Trike
    Last Post: 08-29-2012, 06:55 PM
