Likes Likes:  9
Results 1 to 8 of 8
Thread: How to remove corrosion and polish front wheel. HELP ME Please.
    70+ Posts
    Nov 2018
    San Angelo, TX, USA
    Lightbulb How to remove corrosion and polish front wheel. HELP ME Please.
    Hello,
    I just got my 2006 VTX 1800 trike a couple of weeks ago, purchased from a dealer in WI, I live in Texas.
    In going thru my new steed I found the front wheel to have really heavily corrosion on the aluminum.
    So far I have tried laying down on the ground and used aluminum polish, all that has given me is just shiny corrosion on the aluminum.
    I have thought of pulling the front wheel but I would like to have better than Shiny Corrosion if I'm to do that.
    There has to be someone out there who knows how to fix this issue.
    Thank you, in advance,
    David Hilton Ret. ETC/SS
    If your interested I did post in the newbie introduce yourself (Howdy from San Angelo Texas)
    I had that problem on my 11 T/G.....I Had to use fine emery paper but it never looked like new, Once raw Aluminum gets corroded past a certain point its almost impossible to bring it back to new...I ended up rattle painting them black then clear coat shiny over that.......With my 17 T/G I clear coated them shiny as soon as i bought the Trike home before they could corrode....
    If it pitted you will not have much luck
    Other wise try Bar Keepers Friend and a Magic Eraser
    Dec 2013
    Clarion PA USA
    Zepher Pro-40 Polish and a Mothers 12" extended Powerball on a cordless drill it really takes the work out of recovering as much as possible of the shine. My front wheel was sad when Shiney came to us and it took some work but it is nice now. Travel safe Fred
Size:  162.7 KBName:  DSC00270.JPG
Size:  162.5 KBName:  DSC00130.JPG
Size:  161.9 KBName:  DSC01010.JPG
    Dec 2013
    Clarion PA USA
    Check out the Company's website Zypher has an entire line of products that can be applied to restoring the finish to wheels. It is interesting what the right products and also the correct tools will do. Fred
    Jun 2010
    Indianapolis, In.
    http://search.socialdownloadr.com/se...E390319994D96E
    A lot of wheel restoration companies at above link.
    Most have the proper equipment and knowledge to make alloy wheels look better than new!
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Dave, That’s a nice front wheel on your trike , but they are a PIA to clean.
    Just a suggestion being it’s winter, Remove the wheel , remove the brake disc. Scotch brite the wheel the best you can using fine grit. It will take ya a while to get it the way you want. Then rattle can a few coats of rustoleum clear.
    When cleaning , NEVER use aluminum wheel cleaner , just fantastic or 409 type stuff.
    Or remove tire and have it powder coated your color of choice. Chrome color is available.
    Good luck.
    Sep 2016
    Springfield, Mass. USA
    +2 on using "Bar keeper's Friend" a tube/bottle is found at Home Depot... my front wheels were kinda pitted, and not looking good, well I was introduced to a bottle of this stuff..I tell you it works very well.....Once clean I use wax on the rim, and it stays nice and clean! This stuff is very cheap in price, not at all expensive. Which helps also..
  1. Help Remove OEM muffler (2016 Freewheeler)
    By SGMJRamos in forum Harley Freewheeler / Road Glide 3
    Last Post: 02-20-2020, 03:19 PM
  2. jacking up to remove the front tire.
    By Duck in forum Honda Trikes
    Last Post: 06-19-2019, 06:31 PM
  3. Help with which panel would be easiest to remove
    By 56chevy in forum Indian Trikes
    Last Post: 10-25-2017, 04:53 AM
  4. Seeking Advice re: Jacking trike to remove front wheel
    By Robert53 in forum Harley Tri Glide
    Last Post: 04-09-2017, 08:20 PM
  5. Cleaning and polish/wax?
    By Big_Steve in forum Detailing
    Last Post: 05-31-2010, 07:53 PM
