ctdair7Jack KlarichHarley Tri GlideHot Rotors After New Pads
Phu Cat2trike ladyGeneral DiscussionIs there a TV commercial
Phu Cat2Phu CatGeneral DiscussionIs there a TV commercial
Speed Bleeders
Likes Likes:  8
Page 2 of 2 FirstFirst 1 2
Results 21 to 29 of 29
Thread: Corvair powered 3 legged Iron Horse .... Front mounted if possiblie
  1. #21
    60+ Posts Trike-Man's Avatar
    Nov 2018
    Greenville, Texas
    Try looking up yamaha enduros. I think the 3r6 was a dirt bike from the early 80s.
    Ok thanks that serial number part could be off another frame or bike the tank has a chrome knight swoosh …. that reads 1300 …. I found the tank, on eBay …. Honda Shadow VTX 1300 ….. Now to find how bad my frame is ….. whole thing was $100 …. so I'm sure I got My money's worth ….
    "Peace is that brief glorious moment in history when everybody stands around reloading." …..
    Currently working on a Trike with VW trans-axle & a Corvair Motor
  2. #22
    Nov 2018
    Greenville, Texas
    there is nothing wrong w a wire weld
    but a lot of them are not even piss poor ... some cant even be called welds... pic 99 for example
    no trying to dis any one but these should be TOTALLY ground out an redone.. not just cleaned up to look pretty... you need to be safe some like below neck might be plated over to tie it all together and be safe
    lets be safe out there
    I believe they are a stick job because of all the splatter on unwielded parts, Gussets and re-enforcement plates are defiantly in the works ….. The guy that did this should have His license revoked …. The reason I can't proceed is I have a new Lincoln wire welder ….. I just don't want to weld standing in water ….. Poor bikers have poor ways …. Outdoors is My workshop …. I can see a pretty piece of Diamond plate on both sides of the neck area …..
  3. #23
    Nov 2018
    Greenville, Texas
    Duplicate
  4. #24
    750+ Posts
    Jan 2010
    east windsor ct
    Quote Originally Posted by Trike-Man View Post
    good plan
    i would imagine he had no license!
    been welding for over 40 yrs own business over 30 got a cert to do bridge work let it pass... never did any... no other licenses... got to be doing something right mostly repeat customers
  5. #25
    Nov 2018
    Greenville, Texas
    Duplicate
    good plan
    So, what I did was to grind the 1/4" plate down to a 45 degree angle …. but I in your opinion …. need to completely grind weld off, then weld the bead back …. ??? …. Welding on top of another bead won't work ? the seam on top of large gusset plate looks strong ….
  6. #26
    750+ Posts
    Jan 2010
    east windsor ct
    mostly # 99 those holes are full of crap wont be good to weld over it w/o grinding down past all the holes
    yes you can weld over weld ..
  7. #27
    Nov 2018
    Greenville, Texas
    Yeah, that's a very special area …. It's possible I cut this section off depends on when I can get the Corvair motor out and give a look to see how it will land on the frame …..
  8. #28
    Jan 2017
    Brownfield Maine
    Post Collins Corvair trike
    I have a Collins built Corvair trike that I bought in 2012. It now has a '65 110HP engine. I had the engine, trans (powerglide) and differential rebuilt. New Rochester carbs, one wire alternator, Pertronix ignition. I ripped out all the wiring and ran new color coded wires with a fuse block all in 2017. Still cheaper than some new trikes. I've done 3,000 miles, all local, since the end of April when I sprung it out of the shed. This never had a fuel gauge, the guy I bought it from suggested topping it off every hundred miles. Does anyone have any information on this trike build? Gas tank size? I use 1st gear only up to 20 MPH, second gear for all the rest. It does wheelie pretty easily.Name:  August 2018.jpg
Size:  478.8 KBName:  SAM_2226.jpg
  9. #29
    750+ Posts
    Jan 2010
    east windsor ct
    Quote Originally Posted by joek99 View Post
    nice ride u have
    i would suggest make a new thread for a post unrelated to the original one
    for the tank.. take a gallon of gas with you, ride till you are out of gas, put in the gallon, go filler up.
    then put some more miles on and figure the gas mileage then you have an idea how far you can go before you have to fill up
    course you could drain the tank at home but loose the ride
    if you can wheelie that easy. you are pretty light in the front, which makes me think the front end might want to slide some on a "spirited" ride.. while wheelies can be cool id suggest getting enough weight on the front to keep the front end on the ground before you hurt yourself or someone else
    not far from my hometown hollis center
    respects
    stace
  1. Custom Corvair
    By Shadoe in forum New Member Introductions
    Last Post: 12-14-2018, 09:54 PM
  2. Long legged Passenger
    By 520fd in forum Harley Tri Glide
    Last Post: 09-16-2018, 08:53 PM
  3. four legged friends
    By geraldlanc in forum General Discussion
    Last Post: 05-14-2012, 08:42 PM
  4. Iron Horse Frankenstein
    By Papa Zook in forum Harley Trike Conversions
    Last Post: 05-22-2011, 10:23 AM
