Likes Likes:  20
Results 1 to 15 of 15
Thread: under ground dog fence
    900+ Posts Fowler's Avatar
    Sep 2014
    Moneta VA
    Default under ground dog fence
    If I had hair I would have pulled it all out by now.
    My 2 dogs keep getting out of fence.
    I have 3 acres all fenced but they keep finding ways out.
    3/4 of it is through wooded area
    I don't want to hurt my dogs with electrical shock but shocking them is better than them getting away.
    So with all that said I am looking into getting a underground dog fence. The difference will be that I will zip tie the wire to my real fence. From what I have read this works fine.
    What I am asking for is anyone's experiences with these types of dog fences, suggestions and so on.
    Thank you
    Bob
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Quote Originally Posted by Fowler View Post
    I tried the shock collars and underground wire [Invisible fence] on two Newfie's i had, At the time i didn't have a fence... With the Female once i put it on her she won't go outside i had to force her out... With the male he would walk over the wire and take the shock..He weighed 206 pounds.. Ive talked to a few local rescues and they said they find a lot of lost dogs with the shock collar....Once the dog breaks past the wire they won't come back though it again..
    2019 Tri-Glide.......
    Sep 2014
    Moneta VA
    That sucks man, I hope it does not turn out that way for me.
    I have fixed that fence so many times now.
    I need a new fence but wanted to wait until next spring/summer. I would put it in myself and I am not going to do it in this weather.
    Thank you
    Bob
    Just Killing Time...
    paws's Avatar
    Oct 2011
    Kerrville, TX U.S.A
    Maybe just until the weather gets better you could put up a small radius yard fence by the house that would hold them until you get your 3 acres fixed. 3 acres is a LOT of fence to keep dogs in. We had a neighbor whose dog could climb his 6 ft wood fence. He went to the feed store and bought a hot wire fencing setup for cattle and ran it across the top of his fence. That stopped the escape artist PDQ. Best of luck to you.
    Dec 2014
    Grand Junction, Co. USA
    Couple of my customers have them ... they work pretty well ... but they are medium sized dogs
  6. #6
    Gone But Not Forgotten
    Tech Contributor
    Lee H. Mann's Avatar
    Apr 2011
    Martinsburg, WV
    Fowler, I had 5 acres and there was just too much wildlife running around to keep my dog close to the house.
    I tried the underground wire and collar and it just irritated my dog's neck and he would come and go without a problem.
    This dog was born in the wild and I suspect he really never got over that.
    I tried the underground wire and it knocked the crap out of me !
    I never got to try anything else there because I moved to a much smaller lot.
    I put a board fence around the back yard, about 1/2 acre, and I used a solar with battery cattle fence wire and I would have to repair the wire almost daily because the dog would chew the wire apart (aluminum) and escape.
    After repairing the fence and wires numerous times I put a new battery in the fence system.
    He hit it one time testing it and I could hear him from inside the house.
    I believe he tested it another time but he had no further interest in it.
    Once he got used to his confines (several years) the fence had done it's job and he had lost his spirited behavior.
    Jim Murphy
    Iron Butt Rider 2001
  7. #7
    Sep 2014
    Moneta VA
    I got the dog fence installed today
    I crawled around my entire property zip tieing it to the fence.
    The I tried to test a collar but could not hear the beeps. thought is was not working so I put it to my hand. It was working!!!
    It came with a test light but it did not give the reading I thought it should
    SO
    I went around the fence every often putting the contact points to my hand. It worked every time.
    Reminds me of the days when mt father would make me hold spark plug wires
    anyway put the collars on the dogs. They yelped when the got close to the fence.
    I hope they will learn to stay away from the fence
    Thank you
    Bob
  8. #8
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Neighbor has the invisible fence, and when the pup escapes he lays in the street in front of his driveway. Knowing if he goes home he’ll get zapped
  9. #9
    paws's Avatar
    Oct 2011
    Kerrville, TX U.S.A
    Quote Originally Posted by 1dn5up View Post
    So the neighbor is going to lose the dog one way or another...either he runs away and never gets back or he gets run over while lying in the street....hmm...I think neighbor needs to put up a good yard fence.
  10. #10
    Tech Contributor
    Apr 2011
    Martinsburg, WV
    Bob, Are you using the flags ?? That might help define an area and they would associate the flags as the cause of the shock. Then the flags become a tool for later use.
    Jim Murphy
  11. #11
    Sep 2014
    Moneta VA
    yes a bunch of them
    had to buy extra
    We walked the dogs around the yard and fence, every time they got close to the fence and flags we told the no
    We will keep doing this hopefully they will learn
    Thank you
    Bob
  12. #12
    Sep 2014
    Moneta VA
    The dogs are getting used to the fence being off limits now.
    I have the warning zone set at 5 feet but they will not go that close.
    They play in the yards running all over they just avoid the fence areas.
    We take the collars off at night and lock them in the house.
    So far it is working good.
    Me myself I am still healing from crawling around my fence. Every muscle in my body hurts and I have a few scraps here and there.
    To Old To Fat
    Thank you
    Bob
  13. #13
    paws's Avatar
    Oct 2011
    Kerrville, TX U.S.A
    To Old To Fat
    GOOD for you! Glad for all that this is working out!
  14. #14
    2250+ Posts radismukes's Avatar
    May 2018
    Angleton, Texas
    To Old To Fat
    Be careful, the wife might put one around the couch..... my wife was searching the internet for one.
    “Come and Take It!” “Remember the Alamo!” “Remember Goliad!”
  15. #15
    Sep 2014
    Moneta VA
    Its been a few months now.
    The dog fence has worked great.
    They dont go to close to the fence gut they play in the yard all the time.
    we still keep the actual fence up and in good shape though
    Thank you
    Bob
  1. Replies: 9
    Last Post: 11-30-2018, 09:51 PM
  2. On the fence in Iowa
    By WildWilly in forum New Member Introductions
    Last Post: 12-04-2014, 06:51 PM
