Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  2
Results 1 to 2 of 2
Thread: 2019 ABS braking
    Oct 2017
    Topeka, Ks
    Default 2019 ABS braking
    I understand that the brake bias on the 2019's is 30% front, 70 rear when applying just the rear brake pedal. Will the ABS system increase front bias under heavy braking when using just the rear pedal? Arthritus is slowly taking grip strength away from my right hand and limiting my ability to effectively use the front brake. My 2011 CVO Road Glide, Champion trike kit deletes the ABS feature so the front brake is pretty important. If the answer to the above question is yes then the 2019 Tri Glide is the answer to my problem, if it's no then the Can Am Spyder, which uses only the foot pedal to control both front and rear brakeing is the answer. I'd prefer the Harley but I want to keep riding.
    Thanks,
    Dwight
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    I would test ride them both & talk with the service manager about your concerns.
    My dealer does work all the time for disabled Vets & people with certain physical problems.
    I personally like the linked brakes & get by with the rear pedal 90% of the time. You can also get adjustable levers to reduce reach.
    The Can-Am is a nice vehicle, but I prefer the HD also.
  1. Braking.....
    Last Post: 04-21-2012, 06:01 PM
  2. Emergency braking
    By swodo in forum General Discussion
    Last Post: 12-02-2011, 10:43 AM
  3. Braking..."TO" or "NOT TO"
    Last Post: 08-06-2010, 04:42 PM
  4. Traction Control Braking
    By Greydog in forum General Discussion
    Last Post: 12-23-2009, 07:53 PM
  5. Poor Braking In Reverse?
    By 1550vt in forum Harley Trike Conversions
    Last Post: 06-22-2009, 06:46 AM
