LD-Ordie6trike ladyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6GorillaNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie6SullyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Likes Likes:  3
Results 1 to 11 of 11
Thread: J&S motorcycle jack for a Freewheeler?
    60+ Posts Dante221's Avatar
    Ardsley , N.Y.
    Default J&S motorcycle jack for a Freewheeler?
    Hello All
    Was wondering if anyone has used a J&S standard motorcycle jack
    to lift a Freewheeler? I have messaged J&S about this and am awaiting a reply.
    I would only lift just long enough to reposition in the garage and keep it
    VERY close to the ground
    Thanks very much
    Dante
    2018 Wicked RED Harley Freewheeler
    HOG Life member
    Jun 2010
    Indianapolis, In.
    According to a chart on the web sight. For trikes:
    Yes w/ Trike Lift – HD Tri Glide and HD Freewheeler
    *No Conversion Trikes*
    Must be the trike jack.
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Quote Originally Posted by Dante221 View Post
    Hello All
    Thanks very much
    Dante
    If thats all you need, just get 2 car dollies & a motorcycle dolly for the front.
    You can usually find used one's pretty cheap compared to new.
    Ardsley , N.Y.
    Default Yes I thought of that...
    It's just that I already have the the jack and I don't
    have the three car dollys yet.
    We'll see...
    Dante
    HOG Life member
    200+ Posts
    Nov 2010
    CALHAN COL.
    Unhappy The JACK
    Hello All
    Thanks very much
    Dante[/QUOTE]
    150+ Posts GTK's Avatar
    Oct 2018
    Hobe Sound,FL
    I use a Harbor Freight jack that I upgraded the hand pump portion of jack to 1.0 ton. Got pump at Harbor Freight then for around 20.00.Most motorcycle jack stands are made quite sturdy,but the pumps they put on them determine the lift capacities. Freewheeler would need at least a pump jack rated at 3/4 of a ton at minimum.
    Ardsley , N.Y.
    Default I believe...
    Quote Originally Posted by GTK View Post
    Gerald ,the J&S Jack has a 6 ton bottle jack and can lift 2000lbs. I'm sure the capacity is there...it's the
    shape of the underside of the trike I'm concerned about.
    I suspect I will put up the J&S for sale and use car dollies instead.
    I will wait & see what J&S says
    Thanks all!
    Dante
    HOG Life member
    Oct 2018
    Hobe Sound,FL
    Right answer, J & S two wheel jack is different than the TriGlide or Freewheeler jack per their web site. Not a cheap jack to buy.
    50+ Posts
    Apr 2018
    Ogden, Utah, USA
    It would have been nice of J+S to have a conversion kit for sale for those of us with the two wheel jack. I know, profit....money, money money. But gosh to spend $700 twice is just plain asking too much. Besides I have more chrome to buy dang it!
    Nov 2017
    Delton, MI, USA
    Default J & S Trike Jack - heads up info!
    Just for everyone's information....I actually purchased the Trike Jack thinking it would work perfectly for my 2017 Freewheeler. I did so, because I really liked the 2-wheel J & S Jack I bought previously when I owned my Softail Deluxe (awesome jack).
    But now the sad news...…..The Trike Jack did not work with my new 2017 Freewheeler! The cradle piece that elevates so that it misses hitting the emergency brake didn't clear the brake, and appeared to hit other components like exhaust crossover pipes. It was even to tight up against the fender when trying to jack it up. So, after repeatedly trying to get the J & S folks to return my calls, I had no other choice than to send the jack back to them (at my expense-which wasn't cheap) DO NOT BUY THIS J & S JACK for a Freewheeler!
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    J&S jack is crap. Had a piece break on my jack only after using twice, I emailed and called repeatedly, no answer. Finally had do my own research for the part. First and last time I will buy from them!
  1. Trike Adapter for Motorcycle Jack
    By 470004 in forum Harley Tri Glide
    Last Post: 02-24-2018, 06:05 PM
  2. The Passing of John Parham,owner of J & P Cycles & National Motorcycle Museum
    By Ayatolla of Rockin' Rolla in forum General Discussion
    Last Post: 04-28-2017, 04:26 PM
  3. Need help finding a small trailer front jack for my motorcycle trailer
    By Urlawyer in forum Harley Trike Conversions
    Last Post: 07-23-2014, 07:53 PM
  4. Motorcycle jack
    By Lakeman in forum Harley Trike Conversions
    Last Post: 08-19-2013, 07:48 PM
  5. motorcycle jack
    By JimMc in forum General Discussion
    Last Post: 07-04-2011, 07:27 PM
