Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  5
Results 1 to 9 of 9
Thread: My winter project.
    Dec 2018
    Davisin mi us
    Default My winter project.
    33500+ Posts
    David357's Avatar
    May 2015
    Hobe Sound, FL.
    Nice looking trike, Bill.
    What are your winter plans for the trike?
    Dec 2018
    Davisin mi us
    Quote Originally Posted by David357 View Post
    I want to refit it to me. Have to move the clutch and brake pedals forward a lot. Would like to add a foot throttle. The throttle is like a light switch, on or off! I was told the trike has a 1600cc engine that has been bored out to a 1776 plus it has a radical cam in it. At about 40mph in high gear it takes off like a surface to air missile. First time it did it, I was thinking it was going to be a clean up for the old Maytag! Possible repaint and who knows what else after I get into it.
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    What carbs and cam?
    A big cam and a single carb do not get along very well. It would be real lopey and mushy weak until the cam timing comes in.......by then you would be out of carb to do anything with it.
    If you know or can figure out what is actually in the engine.....I believe we can help you get the drivability up and more predictable.
    Dec 2018
    Davisin mi us
    What carbs and cam?
    That's what it has, a single, single barrel carb and most likely a big cam. It sounds somewhat like a loping v8 at idle, runs smooth, but when it hits around 40, oh my!
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Do you know what it has for heads? Stock?
    It sounds like you have a miss match of performance parts.
    Dec 2018
    Davisin mi us
    This is exactly what we are going to find out! I need to change out the clutch too. It's a race clutch and it's either on or off. I will let everyone know what I find out as I go along. Are there any markings on the cam which would be visible when pulling the cover off. I was told it might have a big cam in it. The guy that I bought it from said he had hotted the valves. I've never heard that term before but I have a feeling that means big.
    850+ Posts vwbug72501's Avatar
    Apr 2015
    Batesville, AR. 72501
    Problem with VW engine is that you have to completely tear down the engine, split the cases to access the cam. You might be able to pull the oil pump and see if there are any markings visible through the hole on the end of the cam. I'd recommend taking time to read over the VW trike threads especially Snu's Tech, tech, tech thread. There are several books and small specialty tools that you will need to work on the engine that are mentioned in these post. Post pictures as you disassemble and somebody should be able to help.
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Cam stamped on the end.
    You can see it once oil pump is removed.
    Can not do anything with it until fully disassembled though.
  1. Winter Project
    By scuba1954 in forum Harley Tri Glide
    Last Post: 08-30-2019, 11:23 PM
  2. Thinkin about a 124/126 CI motor for a winter project for my trike
    By Sloride in forum Harley Trike Conversions
    Last Post: 11-13-2015, 07:29 AM
  3. Winter Project
    By SEABILL in forum Honda Trikes
    Last Post: 02-12-2014, 01:12 PM
  4. My winter project
    By TeNn in forum Accessories
    Last Post: 06-01-2011, 02:58 PM
  5. Last Years Project
    By bdn56 in forum General Discussion
    Last Post: 02-11-2009, 10:30 AM
