Likes Likes:  2
Results 1 to 16 of 16
Thread: condensation on chrome
    20+ Posts
    Sep 2015
    snow hill
    Default condensation on chrome
    i really need help to prevent condensation on chrome,especially on the side covers. i keep my 2018 freewheeler in a garage without heat,on a concrete floor. this is really bad,,,,,,,,,,help would be so much appreciated. thanks for some advice. happy new year to all.,,,,,,,,,,,,,
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    The only way your gona combat the issue , is heated garage. With all the rain this year/season , when I open my garage door the moist air just creates condensation on everything. Try a dehumidifier. As it will work even with out heat .
    90+ Posts Gray Biker's Avatar
    Sep 2018
    Sperry Iowa USA
    The only way I can see is leave a window open or run a vent to keep the temp the same inside the garage as it is outside . I have same problem in my motorcycle side. When it gets cool in there and it warms up outside and gets more humid it collects on any thing thats colder... I fix it by opening the door and letting the temp equalize. Usually only happens after a long cold snap then it warms up some and gets foggy... Best way is heat the area its in. Fan blowing to circulate the air would help some. But if its cooler that the humid air, your going to have condensation.
    550+ Posts
    TwoBye's Avatar
    Feb 2014
    Washington C. H.
    When I had my woodshop I used to combat the moisture problem on all my cast iron surfaces (table saws, jointer, planer, band saws, etc) as they would literally rust overnight. Heat always works but is not always reasonable. I found that moving air was almost as good as heat. I placed a small (and cheap) fan up in one corner of the shop mounted to the ceiling. I'm in Ohio so we are familiar with extreme cold and miserable heat and humidity. Good luck with your battles!
    ... Made the journey (from 2 to 3 wheels) now enjoying the ride ...
    Brad [TwoBye]
    20+ Posts
    Sep 2015
    snow hill
    Default thanks for the advice
    thank you all for the ideas. don't have heat,but definitly will try the others.
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    This reminds me I didn't spray the chrome on my bikes yet. I usually mix atf and mineral spirits until I can get it to come out of a spray bottle. Then spray all the chrome. Makes a mess of course, but no rust. Washes off pretty easy come spring time. I'd be interested in a real fix.
    Less Chrome..........
    Theres an Old Bikers saying....
    Run it might, But Shine it must......
    How about some damp rid around the trike?
    Apr 2015
    Batesville, AR. 72501
    I've read about these but have no experience with them: https://www.carbag.com/
    It seems that if you can build up a sealed storage area in your garage with Visquene (heavy plastic) and use one or more desiccant packs inside it, you'd be OK. The packs are usually "rechargeable" by putting them in the oven for a period of time to "dry" them out. Once dry they stay good if stored in a ziplock bag. Make sure the storage area has a plastic covered floor also (not concrete, etc. floor).
    Here's another one: https://extremevehicleprotection.com/
    I Googled ziplock bags for cars.
    Apr 2015
    Just remembered another thing. You can use a 60 - 100 watt light bulb inside the "bag" that will probably generate enough heat to burn off the humidity. Just make sure it doesn't contact anything burnable. This way you don't have to heat the whole garage.
    300+ Posts
    florissant
    I keep a 100 watt drop light laying beside the bike all winter and have done so for years without any problems. It's just enough heat to drive away any moisture. Maybe even lay 2 down. This can be done on a concrete floor only. If it's sunny out i will open the back door so the sun can shine in though the screen door and warm things up a bit, even if it's 0 out.
    hardheaded
    Sep 2016
    Springfield, Mass. USA
    I put a rug under my bike (concrete floor / unheated garage also) and wipe some WD40 on all your chrome....OR .... A good coat of wax....
    2250+ Posts
    Ocala, Florida
    Keep in mind, no matter what fuel you burn, it's going to give of moisture as a by product. I learned the hard way too using a 50,000 BTU kerosene heater in the dead cold of winter to work in the garage. The air compressor, drill press and radial arm saw all got rust on them.
    PC
    Beware of liberals posing as Americans.
    You could go to a store that sells to ranchers and farmers (tractor Supply) ... they have rubber pads that lock together ... get enough to park your trike over .. should help stem the moister coming from the floor. Probably only need four. That would make it 72" by 96".
    Here's a link
    https://www.tractorsupply.com/tsc/pr...lite-mat?rfk=1
    Sep 2016
    Here's a link
    OR just go to a rug store and purchase a rug remnant, (a size that fits the length of your bike) that's what I did, I believe it's working (don't know for sure till this spring when the hibernation period is over.. BUT then again I did wax the heck of all my chrome , before hugging it and saying my final good bye to my bike before closing the garage door...
  16. Roadsmith banner
  17. #16
    Sep 2012
    Lakeland, FL
    Sounds to me like the rug remnant would work and should be an economical purchase at any carpet store. I'd be giving that a try before I forked out the big bucks.
  1. Seat condensation
    By cooltech in forum General Discussion
    Last Post: 08-29-2013, 04:35 PM
  2. Goldwing Trile condensation
    By Three_a in forum Honda Trikes
    Last Post: 03-14-2013, 11:41 PM
  3. Chrome plated plastic
    By John Luciano in forum General Discussion
    Last Post: 12-21-2008, 09:07 AM
  4. Need Review - Show Chrome LED Tail Lights
    By patriot in forum Accessories
    Last Post: 08-11-2008, 09:51 AM
  5. Chrome vs Stock Wheels
    By QC Goldwinger in forum Accessories
    Last Post: 04-20-2008, 11:32 PM
