Likes Likes:  2
Thanks Thanks:  3
Results 1 to 11 of 11
Thread: *DK Custom - NEW Report On External Breather System Flow w/ Testing Video & Results*
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Default *DK Custom - NEW Report On External Breather System Flow w/ Testing Video & Results*
    A New Testing Report on External Breather System(EBS) Air Volume/Flow
    Has Been Published on Our Site!
    A piece taken from the report-
    "When we embarked on designing our 4 Stage Catch-Can for External Breather Systems (EBS), we decided that the first order of business was to get accurate data on How Much Air passed through the stock Harley Breather Bolts, so we could design the best possible Catch-Can."
    Check out the Full Report with video of testing at the link below!
    Breather System Flow Testing, Results, & Video
    www.DKCustom.com
  2. DKCustoms postbit
  3. #2
    Very good read
    I sure would have thought the M8 with 4 valve heads would push more air
  4. #3
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Not sure what EBS You need for Your Bike?
    Check out this REPORT on Choosing the Right EBS for Your Bike!
    www.DKCustom.com
  5. #4
    950+ Posts Free Bird's Avatar
    Mar 2018
    Saint Louis
    Hi Kevin,
    I am running an S&S Teardrop Air Cleaner on my Tri. Not sure which EBS might work with it. Do you have any installs of an EBS on this AC yet?
  6. #5
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Check out this FAQ Video!
    www.DKCustom.com
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    www.DKCustom.com
    Mar 2018
    Saint Louis
    Thanks for the great Air Cleaner EBS combo! Here is how mine turned out on my 2017 M8
  9. DKCustoms postbit
  10. #8
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by Free Bird View Post
    Glad to read that you're liking your new set-up! Looks great! Thanks for sharing!
    www.DKCustom.com
  11. #9
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Hi Kevin,
    Wow! Somehow this post got missed. Apologies for the delayed response. The DIY kit is what would be required for this A/C, but again, glad you're liking your new set-up!
    www.DKCustom.com
  12. #10
    Default Question
    How often should the can be cleaned? Mine is the four stage thing.
    To be honest ... forgot it was there ... LOL ...
  13. #11
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Depending on how much oil your spitting, every 5-10 thousand miles.
    The Catch Can is easily emptied by holding the top with your fingers (or a wrench) and
    unscrewing the bottom (can) from the top. Inside you will see:
    2 pieces of Low Density foam at the bottom
    3 pieces of High Density foam on the tube
    3 vented separators between the top foam to slow down oil and water migration
    All 5 pieces of foam can be cleaned with hot soapy water...either in place, or by
    removing, then cleaning.
    www.DKCustom.com
  14. DKCustoms postbit
  1. DK Custom-Parts Info, Testing, & Results w/ Pics & Fun-to-Read Ride Reports
    By DK Custom Products in forum DK Custom Products
    Last Post: 03-07-2023, 11:42 AM
  2. Replies: 3
    Last Post: 06-10-2019, 11:17 AM
  3. ***DK Custom-*NEW & IMPROVED* Catch Can For External Breather System***
    Last Post: 11-26-2018, 10:47 AM
  4. External breather system
    By Lawless in forum Harley Tri Glide
    Last Post: 12-12-2016, 04:20 PM
