ctdair7Jack KlarichHarley Tri GlideHot Rotors After New Pads
Phu Cat2trike ladyGeneral DiscussionIs there a TV commercial
Phu Cat2Phu CatGeneral DiscussionIs there a TV commercial
Speed Bleeders
Likes Likes:  1
Results 1 to 4 of 4
Thread: Can It Be Done, How Difficult?
    100+ Posts sonny8l3's Avatar
    Oct 2014
    Livingston (Colyell ), Louisiana, USA
    Default Can It Be Done, How Difficult?
    Hello, Could a lower tree, with the pivot pin attached, be attached to a lathe and machined down? Example: Nomad tripple tree and machine the pivot pin down to fit an '84 Yamaha Virago, cut it to length, and match the head bolt thread. Some times it's scarry what a mechanically declined mind will come up with at 2am. Thanks for your time
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    Possible....at least somewhat at least.
    The main problem I see is that most of the jap bike pivot pins are made of tubing that is just enough thickness for the bike it goes on. It is very likely it does not have enough metal thickness to be strong enough after you reduce the diameter.
    I would do some measuring and run a few numbers and make the call over whether enough strength is left or not.
    Have you been to All Balls?
    https://www.allballsracing.com
    Maybe they have conversion bearing that do not need a major re-machine.
    The only way I have done it is by swapping out the entire stem. But this involves machining and welding.
    850+ Posts vwbug72501's Avatar
    Apr 2015
    Batesville, AR. 72501
    Ditto on the All Balls Racing. As long as the new pivot is longer than the old pivot, all you have to do is make a spacer to take up the length difference. Easy-Peasey!
    Oct 2014
    Hello, I didn't know that the pin is hollow. That does make a heck of a difference. Thanks y'all.
  1. Replies: 2
    Last Post: 09-10-2018, 03:47 PM
  2. Replies: 10
    Last Post: 11-04-2013, 09:50 AM
  3. It was a difficult build
    By PhilGilbert in forum Suzuki - Kawasaki Trikes
    Last Post: 09-19-2011, 07:32 PM
