Likes Likes:  19
Thanks Thanks:  5
Results 1 to 20 of 27
Thread: Servi car help
    Jan 2019
    Caldwell Texas USA
    Default Servi car help
    I have a servi car and don't know much. I am trying to to find out the year so I have a starting point. I think it had a 1000cc ironhead motor. The serial number is in the motor but I can't find anything on the web sights that I have searched.
    Darrell......Welcome To Trike-Talk............
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Darrell, welcome to Trike Talk from West Virginia.
    Jim Murphy
    Iron Butt Rider 2001
    Just Killing Time...
    paws's Avatar
    Kerrville, TX U.S.A
    Darrell... welcome to TrikeTalk from west Texas!
    There have been a few postings about people wanting info on the Servi-Car.
    You might try a "search" on TrikeTalk to see what you come up with.
    Here's a link I found to a post just this last June. Particularly look at Posts #2 and #3 when it opens.
    Also, when I clicked on the link provided for the manual it took a good 30 seconds to fully load the manual. If you don't wait for it to load and start scrolling down all you will see are blank pages... hope this helps.
    https://www.triketalk.com/forum/thre...or-52-Servicar
    Welcome to Trike Talk
    30+ Posts Lance65's Avatar
    Dec 2016
    cleveland ohio 44119
    Default Re Servi car help
    Trikes didn't come with 1000cc ironhead motors (as far as I know) . If it has a ironhead motor then it's been modified with a sportster motor . Post a picture then someone can help you figure out what exactly you have . Do you have a title for it?
    Over the years I have built several (3) 'sportster' trikes and 2 panhead trikes. They were all built with swingarm frames but used no shocks . I built them to bolt together and be able to go back to 2 wheels . All had the original drum brake rear axles .
    Lance
    Quote Originally Posted by Lance65 View Post
    Lance
    Servi cars were side valve 45 cubic engines ( Flatheads, cast iron) 750 cc
    Meme Master
    Jan 2014
    Farmington, NH USA
    Welcome to TT Darrell.
    Harley used engine serial#'s exclusively to ID their bikes/trikes until 1968?, when they began stamping VIN's on their frames.
    What are the first 4~5 #'s stamped on your engine? That should help to confirm what you have if it has a HD factory case.
    To "transplant" a bigger engine into a Servi-Car frame would take quite a bit of work, but it's been done before!
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    Jack you are 99% correct,i say 99% because HD made 3 Knuckle powered shaft drive servi cars for the Canadian military.Info courtesy of Wheels thru Time Museum.
  11. #10
    I have a photo of that HD also made a mini tank for Canada powered by knuclehead engines Thanks for the post
  12. #11
    1 of 17 built Knuclehead shaft drive Servicar
  13. #12
    500+ Posts
    Apr 2016
    Vero Beach, Florida
    Man, would I LOVE to be at WTT when Dale fires this puppy up as you know he runs everything in the museum at some time during the year!
  14. #13
    Jan 2019
    Alexandria
    Default What exactly is it you need to know about the Servi-Car?
    Quote Originally Posted by Older than dirt View Post
    There were only 2 types of Servi-Car rearends made. One was a mechanical brake setup and later they built one with Hydraulic Drums. I have modified the Hydraulic rearend to work on numerous swingarm Harley frames. Mods including Disk Brakes, etc. I am pretty sure I have the Servi-Car manual somewhere on one of my computers. But again, it will only cover the flathead engine and the rear section. Message me if you want it or have any other questions.
  15. #14
    80+ Posts dmillsr3's Avatar
    Jun 2016
    Double Oak, TX, USA
    Default Are you sure about the size
    30mm are available https://www.amazon.com/Mikuni-Carbur.../dp/B005CXBW1G
    but the 30mm might be small for the 45ci. I ran a 36 or 38 (i don't remember which) on a 750cc Trident engine back in the 70s and it was fine for that.
    Disregard this post. I was mistakenly responding to an old post on putting mikuni on Servicar and then mistakenly posted on this thread instead. Hadn't finished my coffee when I did this.
    Shade Tree Conversion
  16. #15
    Welcome to the Gang from Western Colorado.
  17. DKCustoms postbit
  18. #16
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Welcome to Trike Talk. As someone already stated ,if motor is original, serial # is stamped on left side bottom of jugs. Year is there. Find that & also post a picture of your HD
  19. #17
    450+ Posts irmagoo's Avatar
    Dec 2012
    washington il.
    i just learned something thanks for posting
    mike
    mike aka magoo
    hd sidecar rig/building v6 supercharged trike
    "even a blind squirrel finds a nut once in awhile"
  20. #18
    Aug 2015
    ft worth
    Cool
    last yr for vin was 69 on the engine, i have one, 1970 was first year for frame vin
  21. #19
    Aug 2015
    ft worth
    Cool
    Quote Originally Posted by SmartAceWoLf View Post
    mechanical rear end is more narrow than the later hyd unit, i have one, housing only
  22. #20
    20+ Posts
    Jan 2018
    australia
    this is mine
  1. Need a Mikuni for a Servi-Car HELP!
    By Papa Jack in forum Home Built Trikes
    Last Post: 04-15-2017, 07:47 AM
  2. 1951 servi car rebuild - engine is done!
    By 1fangtooth in forum Harley Trike Conversions
    Last Post: 12-17-2010, 06:47 AM
  3. 1951 servi car - tackling the clutch assy
    Last Post: 12-07-2010, 10:23 PM
  4. 1951 Harley Servi-car rebuild
    Last Post: 12-01-2010, 05:59 PM
