Likes Likes:  1
Thanks Thanks:  2
Results 1 to 5 of 5
Thread: My 2019 Front wheel losing air.
    250+ Posts
    Nov 2012
    Bradenton, FL.
    Default My 2019 Front wheel losing air.
    Porous wheel HD has a new one coming for me in 2 to 3 weeks. Just passing it on.
    2019 Red and Silver Tri Glide
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Quote Originally Posted by hddocfl View Post
    Sorry to hear that. I am curious, what inspection did they do to determine that is was not a bad tire, a tire/bead seal problem or a faulty valve stem?
    Leaky wheels are more common than 1 thinks
    WE would mark the leak area on the wheel with a grease pen after the dunk tank
    Some wheel/ tires would take as much as 50lbs of air to leak
    Once we removed the tire we would scuff the inside of the wheel and apply silicone gasket sealer, problem solved in most applications
    It is a FRUSTRATING job
    250+ Posts
    Nov 2012
    Bradenton, FL.
    I found the leak in the wheel in a tank of water, very slight leak but would have to add air twice a week, the leak was at were the spoke and rim were cast in between two spokes at the rim hard to spot and very slight leak tire and bead are good.
    Dec 2013
    Clarion PA USA
    Motor Co. should make good on that leaker or will they. just sayin... Ride safe Fred
  1. Replies: 11
    Last Post: 11-06-2014, 05:35 AM
  2. Questions.. Losing oil/funky oil pressure
    By classicfins in forum VW Powered Trikes
    Last Post: 10-09-2012, 04:31 PM
  3. she is losing her shine
    By adaptolife in forum Harley Trike Conversions
    Last Post: 08-11-2012, 09:13 PM
