SSpoon11hogmemberisoldNew Member Introduct...Hello from VA
SSpoon11ol' schoolNew Member Introduct...Hello from VA
SSpoon11Marc HNew Member Introduct...Hello from VA
SSpoon11ZammyNew Member Introduct...Hello from VA
SSpoon11Uncle FesterNew Member Introduct...Hello from VA
SSpoon11rhino 2New Member Introduct...Hello from VA
SSpoon11trike ladyNew Member Introduct...Hello from VA
SSpoon11SullyNew Member Introduct...Hello from VA
SSpoon11Jack KlarichNew Member Introduct...Hello from VA
SSpoon11GorillaNew Member Introduct...Hello from VA
SSpoon11SSpoonNew Member Introduct...Hello from VA
Thanks Thanks:  4
Results 1 to 8 of 8
Thread: Stallion front axle seal
    20+ Posts T.C.'s Avatar
    May 2008
    LONG ISLAND
    Unhappy Stallion front axle seal
    Damaged inner wheel bearing seals #11353
    seal seems too small in circumference and when inserting the axle i hits and damages the seal and will not pass through. Anyone have info or suggestions on how to install the seals and wheel bearings. A diagram or sketch? So far two bike shops have been unable to
    fix the problem. It has been out of service since
    nov 2027 . It is a 2008 Stallion # 377
    1000+ Posts tomg's Avatar
    Oct 2009
    Titusville, Florida
    Quote Originally Posted by T.C. View Post
    It's not the seal, it's the outer edge of the axle. It needs to be slightly beveled on the outer edge so it slides thru the seal. Grease the axle before putting it in. This works, I know! Tomg
    +1 on Tom's reply. if you take the take the whole assembly apart you will what Tom is talking about. Making sure that the axle is WELL lubed and smooth. Careful alignment will get it in.
    300+ Posts
    Signal Mountain Tn
    To deal with the problem you have encountered, I had a dummy axle made which is exactly the length of the thickness of the wheel w/seals and bearings. I can assemble
    the bearings and seals with the dummy axle in place, roll the wheel into position, then use the oem axle to push the dummy axle through.
    May 2008
    LONG ISLAND
    Default Bearing seal
    Thanks for the reply’s. Using a dummy axel sounds good but have no idea who could make me one. Not even sure if I have right parts. Can you sketch how to assemble. Is this correct sequence and parts - inner seal cr 1135 - bearing 32006- race- seal national 470025. Starts with inner seal and works out.
    So far damaged two inner seals trying to mount the wheel. Have ordered replacements again .
    300+ Posts
    Signal Mountain Tn
    I think you have the sequence correct.
    Apr 2015
    Rosedale, Indiana US
    I just went through the same issue, destroying seals. I was able to get it together by putting the axle through the inner seal first, setting the hub / rotor on the wheel, then slide the other hub onto the axle. Once together, the axle will slide side to side to get it on the bike. With the axle through the inner seal first, you don't knock the spring off or tear the seal. Just grease the crap out of the axle first.
    Nov 2020
    Fort Myers
    Default parts list for front end.
    I found this list of parts for front, rebuild.
    FRONT LEFT HUB ASSEMBLY PARTS TMFS-00030
    No. Description QTY PER HUB UNIVERSAL PART #
    MTGH-0433A E-CLIPS 5/8 BOWED 10
    TMFS-00420 FRONT CALIPER BRKT SNAP RING 1
    TMGH-00650 5/8 SPRING/WAVE WASHER 20
    TMBR-00240 FRONT BRAKE CALIPER 1
    TMBR-00270 FRONT BRAKE CALIPER BRKT LEFT 1
    TMBR-00300 FRONT BRAKE ROTOR 1
    TMBR-00310 FRONT CALIPER PAD RETAINER 1
    TMBR-00320 FRONT BRAKE CALIPER BRKT BEAR 2 $11.50 each 6814-2RS, 70mm X 90mm X 10mm 123 bearings. 1 646-712-9672
    MTBR-0182A FLOATER PIN-BRAKE ROTOR 10
    TMFS-00170 FRONT HUB (FOR INNER SEAL) 1
    TMFS-00180 FRONT HUB OUTER SEAL 1 CR14939 OR NAT470625 1.5" X 2.22" X .313" measurements
    TMFS-00190 FRONT HUB INNER SEAL 1 CR 11353 OR 472644 (NATIONAL OR TIMKEN) 1.125" X 2.047" X .313"
    TMFS-00210 FRONT AXLE BEARING 1 HR32006XJ - NSK $18.38 each
    MTGH-0434A FRONT BRAKE ROTOR WASHER 5/8 10
    TMGH-01286 9/16 SAE FLAT WASHER Z/P 2
    FRONT RIGHT HUB ASSEMBLY PARTS TMFS-00020
    TMBR-00290 FRONT BRAKE CALIPER BRKT RIGHT 1
    TMBR-00320 FRONT BRAKE CALIPER BRKT BEAR 2 6814-2RS
    TMFS-00190 FRONT HUB INNER SEAL 1 CR11353 OR NAT472644
    Rear Brake parts, Ford 500
    The bearings are from France so there is $24 shipping
  1. Harley motor to VW trans axel
    By BIBS in forum VW Powered Trikes
    Last Post: 10-29-2021, 07:03 AM
  2. Replies: 12
    Last Post: 04-11-2015, 05:33 PM
  3. Shortened swing axels and oil leak from axel ends
    By Trike in forum VW Powered Trikes
    Last Post: 06-05-2014, 08:18 PM
  4. roadsmith axel nut
    By nootron1 in forum Roadsmith Trikes
    Owners Forum
    Last Post: 03-27-2013, 07:34 AM
  5. My Champion rear axel oil leak
    By saab9k in forum Champion Trike
    Last Post: 08-23-2012, 10:47 AM
