Phu Cat1Phu CatGeneral DiscussionIs there a TV commercial
Speed Bleeders
Likes Likes:  17
Thanks Thanks:  1
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 55
Thread: Better Performance?
    100+ Posts 1 triker's Avatar
    Dec 2018
    Hempstead,tx,Waller County
    Default Better Performance?
    Has anyone been successful or tried to obtain more hp and tq from their Stallion?
    # 796
    450+ Posts rocket1lf's Avatar
    Dec 2013
    Hot Arizona, USA
    I spoke with a Dyno shop last year about trying to get more HP and gas mileage. He did hooked it up to a computer and said he could get a little more mileage out of it and some more HP and torque. All the charts and graphs he was looking at were Greek to me. He sold the shop last month, but still comes in to work on Fords. I'm going to see him again on Monday. Stand by. Rick
    Stallion #378
    Suzuki Burgman 650
    Dec 2018
    That would be good, hope it work out .Thanks for your effort.
    I went over to the Ford Ranger forum and found a lot of info on how to increase hp on the 2.3 eng.
    # 796
    Dec 2013
    Hot Arizona, USA
    Unless it rains, I have an appointment on Jan 26. I'm curious to see how close it is to the 155hp claim. Rick
    Stallion #378
    Suzuki Burgman 650
    200+ Posts
    Feb 2017
    Arp, TX - USA
    Heck, even I'm curious about the outcome of this!
    Previously attempts at doing this haven't been successful and I can't recall who it was, but one of the Stallion owners went as far as sending their pcm to Rousch to do some tuning & was told they no longer had the programming information for the Stallion and couldn't help them.
    Granted technology has come a ways since then and the ability to "piggyback" & break into pcm's to "recode" has become more accessible than it was in previous years.
    Be sure and share the results with us!
    1000+ Posts tomg's Avatar
    Oct 2009
    Titusville, Florida
    Back when I purchased my Stallion, I was told that they had Roush reprogramed the ecm for at least the 2009 year. Tomg
    Dec 2013
    Hot Arizona, USA
    I just got back and here is the lowdown. The timing was set like a pick-up for hauling a load. It was set at 8 degrees. He reset it up to a max of 22 degrees at my request. He said it could have gone higher, but at 26 degrees and max RPM, it started to ping just a little bit, so I decided to go more conservative. It was also running very lean at low and midrange RPM so he adjusted that.
    Here are my observations on a short 80 mile ride afterword. It has more throttle response from a stop and rolling in the 40-60 mph area. I did this adjustment because it kept dropping gears going up little inclines and hills. I checked all these readings at 70 mph and on cruise control so I could get a steady reading. Before, on a 2-3 degree incline, it would drop out of overdrive to keep up at 70 mph. Now it doesn't do that. It just stays in overdrive. Before on a 5-6 degree climb, it would not only drop out of overdrive, it would also drop a gear and the rpm would go up to 3700-3900 rpm's to hold 70 mph. Now it will drop out of overdrive, but won't drop and gear and the rpm will be at 2950.
    I will know more about gas mileage next week when I go on our usual Saturday 15-200 mile breakfast ride. He said it should remain the same or get a little better.
    So far, I'm happy.
    For those of you that can read this thing, here is the chart. He couldn't get a torque reading because his machine couldn't get a good rpm reading. As you can see, there is about a 30% increase in HP in the midrange. The old tune was very up and down in this area because of the way the timing was set and the lean fuel mixture. It is much smoother now. This is at the rear wheels. Add about 20% to get the HP at the crank.
    Stallion #378
    Suzuki Burgman 650
    Dec 2018
    Wow, that was a good hp increase, I'm thinking the tq was pretty good as well according to your description of the power feel uphill and how it reacts. Also by using premium unleaded will be a plus in making more power if you had regular gas. I will definitely do this as well. Thanks. The average charge now for dyno tuning in my area is about $700.00
    # 796
    Dec 2013
    Hot Arizona, USA
    Quote Originally Posted by 1 triker View Post
    $475.00 here and $100.00 of that went to the program license, so the shop got $375.00. That tune was running on 87 octane gas.
    Stallion #378
    Suzuki Burgman 650
    Oct 2009
    Titusville, Florida
    Numbers and price sound good! If I weren't going to buy a new trike, I would invest in the dyno tune. The next owner might be interested though . Don't forget to post your mileage. Now I get 30-32 mpg here in Florida but, when I'm on out of state trips it always jumps up from 3-8 more mpg as those states don't have as many additives in their fuel blends! I actually got 44 mpg in Arkansas with no ethanol regular gas! Tomg
    Dec 2013
    Hot Arizona, USA
    I was getting 30mpg on the breakfast rides on Saturday morning up and down to 6500 feet and back. I never got over 35mpg with it on trips, but I was usually traveling 75-80mph and going up and down hills in Arizona, Utah and Colorado.
    Here's a picture of it strapped down on the Dyno.
    Stallion #378
    Suzuki Burgman 650
    250+ Posts
    Dec 2010
    oly,wa
    Good morning
    results show what a good tune can achieve. I am curious tho on how the timing was changed, I thought it was only accessable through ecm. so you can access ecm and change other parameters also. I was under the impression you could not reset any parameters with the roush chip
    Dragon
    Dec 2013
    Hot Arizona, USA
    Good morning
    Dragon
    Yes you can. He was able to access the computer and when he found out he could do that, he had to buy a license to be able to get the program to change it. The license was $99.00 and that was included in the $475.00 for reprogramming the ECM. He was able to change anything he wanted at that time. If I feel something isn't the way I want it, he said he could meet me anywhere with his laptop and he could adjust the ECM. Rick
    Stallion #378
    Suzuki Burgman 650
    250+ Posts
    Dec 2010
    oly,wa
    Thanks, did he have to access the ecm through a special cable, take off the front cover and then plug in? this sounds very interesting, can a dumb nerd like me get a license and learn the process
    Dragon
    Dec 2013
    Hot Arizona, USA
    Dragon
    He plugged into the OBD II port under the hood. I have no idea how he gained access and where he got the program. Rick
    Stallion #378
    Suzuki Burgman 650
    Dec 2018
    Good morningresults show what a good tune can achieve. I am curious tho on how the timing was changed, I thought it was only accessable through ecm. so you can access ecm and change other parameters also. I was under the impression you could not reset any parameters with the roush chipDragon
    I heard something about the chip being installed, is this a piggy-back chip plugged into the ECM?
    # 796
    Dec 2013
    Hot Arizona, USA
    No chip or external programmer was needed to be installed. Did it with just a computer plugged in to the OBD II port.
    Stallion #378
    Suzuki Burgman 650
    Dec 2018
    Quote Originally Posted by rocket1lf View Post
    Sorry, but I meant someone said there were Stallions with the Roush chip plugged into the OBD II port when they bought them.
    # 796
  19. #19
    Oct 2009
    Titusville, Florida
    When I purchased my Stallion, we were told that Roush had tuned the ecm, nothing about any chip, just refining the installed ecm. Tomg
  20. #20
    250+ Posts
    Dec 2010
    oly,wa
    Good morning
    Rick can you ask your friend about license, from what Richard said rouch does not have the stallion information any longer so who did he get his from. basically sounds like the ecu was flashed. interested in your mileage, has it improved.
    Thank You
    Dragon
  1. speaker covers from Performance Machine
    By morrishuckeba in forum General Discussion
    Last Post: 08-14-2011, 05:49 PM
  2. Cool air performance
    By Greydog in forum Harley Trike Conversions
    Last Post: 11-10-2010, 11:19 PM
  3. Poor Performance?
    By TimNeill in forum Harley Trike Conversions
    Last Post: 09-21-2010, 02:54 PM
  4. PM (Performance machine) TG Brakes Installed
    By PopDukes in forum Harley Tri Glide
    Last Post: 04-28-2010, 11:21 PM
