Likes Likes:  17
Thanks Thanks:  1
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 21 to 40 of 55
Thread: Better Performance?
  1. #21
    450+ Posts rocket1lf's Avatar
    Dec 2013
    Hot Arizona, USA
    Good morning
    Rick can you ask your friend about license, from what Richard said rouch does not have the stallion information any longer so who did he get his from. basically sounds like the ecu was flashed. interested in your mileage, has it improved.
    Thank You
    Dragon
    It was just a local Dyno shop I took it to.
    Stallion #378
    Suzuki Burgman 650
  2. #22
    guys the 2.3 engine setup is very popular in local racing circles. I am sure he found all the data he needed on line.
  3. #23
    100+ Posts 1 triker's Avatar
    Dec 2018
    Hempstead,tx,Waller County
    True, I found that there's a lot of upgrades for making more power for the 2.3.
    # 796
  4. #24
    250+ Posts
    Dec 2010
    oly,wa
    I agree the 2.3 has been around a long time, books published on mods, ect. there is one thing these people had to start with a vin number. problem I have had is I have taken it to 3 ford dealers, and 2 hot shot tune up places only to have them say without a vin our computer cannot talk to your vehicle. it doesn't know where to look for data
    Dragon
  5. #25
    Dec 2018
    I contacted Performance Chip Tuning which has a chip for the 2.3 but can not be used if there is a Roush tune in the ECM. This is very bad news for not being able to just buy a chip.
    # 796
  6. #26
    350+ Posts Doc7402's Avatar
    Mar 2013
    Thonotoassa ,Fla ,USA
    Quote Originally Posted by tomg View Post
    Numbers and price sound good! If I weren't going to buy a new trike, I would invest in the dyno tune. The next owner might be interested though . Don't forget to post your mileage. Now I get 30-32 mpg here in Florida but, when I'm on out of state trips it always jumps up from 3-8 more mpg as those states don't have as many additives in their fuel blends! I actually got 44 mpg in Arkansas with no ethanol regular gas! Tomg
    i would be interested also on the gas milage
  7. #27
    I have a question for you Stallion owners
    What does your diagnostic port look like?
    If it is a standard OBD2 port a good scanner will spit out a VIN
  8. #28
    300+ Posts
    Signal Mountain Tn
    YEP, standard OBDII!
  9. #29
    Dec 2018
    You are so right,thanks.
    # 796
  10. #30
    Dec 2013
    Hot Arizona, USA
    Did 125 miles this morning. Got 29mpg, but went up higher so the engine was pulling harder. 98% of this trip was at 70mph or higher. It didn't seem to be laboring as hard as it used to on the hills up and down ending at about 5100 feet for breakfast. Rick
    Stallion #378
    Suzuki Burgman 650
  11. #31
    2000+ Posts trikeman's Avatar
    Oct 2010
    Jackson Tn. Madison Co.
  12. #32
    Dec 2018
    I talked to a major tuning shop and was told they could not tune my Stallion due to the Roush tune installed. In other words they can't remove it. The shop that did your tune must be really good. Maybe you can let him know there are others who want his tuning. Is it possible you can check with him to see if mail tuning possible?
    # 796
  13. #33
    1000+ Posts tomg's Avatar
    Oct 2009
    Titusville, Florida
    I could be wrong here but, I don't believe that "ALL" Stallions had the Roush ecm upgrade. I don't think the early ones and maybe the last ones were upgraded. Probably the only one to tell us would be TMS listing the serial numbers with the Roush tune. Tomg
  14. #34
    Dec 2018
    I was thinking the same thing, in fact, I'm wondering why did they find it necessary to have a Roush tune . And also, does that mean some Stallions have more hp than others? This Roush tune thing is not making very much sense. There should be a VIN# on the engine block, I'm going to look for it eventho it may be almost impossible to see it.
    # 796
  15. #35
    Oct 2009
    Titusville, Florida
    Quote Originally Posted by 1 triker View Post
    Yes they had about 5 more hp and probably wasn't worth the price for the small increase, in my opinion. I thought the original was 150 and Roush was 155, probably wrong but those numbers seem to stick in my mind from somewhere. Tomg
  16. #36
    There aren't any VIN numbers on engines...There are serial numbers...The Vehicle Identification Number is on the body/frame of the Vehicle to tell you the date of production the color of the body type of transmission and engine size [One of the # in the vin will tell you which engine you should have] and a few other bits of pertinent info..........All those Numbers on a vin plate are a non secret code...
  17. #37
    guys some tuning had to be done for the drive train package to work in the stallion. there is a large weight difference between a ford 4 x 4 ranger and the stallion.
    by the way for those who dont know the transmission is from the 4 x 4 with the tail shaft being chaged to a custom tail for the length of the drive line to work.
    tuning would be required for the shifting points to be changed at the very least. tbms probably had the orginal tune setup by rousch and then just flashed that program into the ecm during production. coding could of been added that prohibited re flashing.
    one might try one of those modules that plug into the obd11 port that allows modifing the information coming out of the ecm to change performance.
  18. #38
    Dec 2018
    Good info, one company that sell the chip said it would not work if there's a tune in the ECM.
    # 796
  19. #39
    Dec 2018
    Thanks, I found out before I went to look for it.
    # 796
  20. #40
    200+ Posts
    Feb 2017
    Arp, TX - USA
    Gorilla is "on point" with his response.
    The original HP #'s were "estimates" based on the Ranger platform since no tuning/testing had truly been done at that point.
    For those who don't quite follow the Rousch connection. ALL mileage, epa, & certification testing has to be done by a secondary company (we did not provide the mileage estimates directly). Additionally, we had "modified" the intake & muffler setup for "setup" purposes. Roush "designed" the intake & exhaust setup on the Stallion & did the tuning for the pcm for shift points, etc. Once they completed that aspect they also did the mileage & epa testing/certifications (non carb states) for TMS.
    The pcm's weren't pre-flashed or pre-tuned in the Roush facility; Roush built a "programming box" that did the flashing of the pcm's for TBMS. ALL of the Stallion pcm's from Ford were standard 170pin "non flashed" pcms; during the build process "programming box" was plugged into the obd 2 port & the key cycled on to initiate the programming of the pcm. I've attached a picture I "borrowed" from the interwebs to help give an idea of what this "box" I speak of looks like. It's essentially just like the below picture with 5 or 6 lights on it that light up as the programming is done.
  1. speaker covers from Performance Machine
    By morrishuckeba in forum General Discussion
    Last Post: 08-14-2011, 05:49 PM
  2. Cool air performance
    By Greydog in forum Harley Trike Conversions
    Last Post: 11-10-2010, 11:19 PM
  3. Poor Performance?
    By TimNeill in forum Harley Trike Conversions
    Last Post: 09-21-2010, 02:54 PM
  4. PM (Performance machine) TG Brakes Installed
    By PopDukes in forum Harley Tri Glide
    Last Post: 04-28-2010, 11:21 PM
