14TG314TGHarley Tri GlideInstallation of a new Fuel Filter &...
14TG3Jack KlarichHarley Tri GlideInstallation of a new Fuel Filter &...
14TG3TrampasHarley Tri GlideInstallation of a new Fuel Filter &...
Likes Likes:  9
Thanks Thanks:  2
Results 1 to 14 of 14
Thread: My 2015 tri glide does not sit level.
    5+ Posts Robk's Avatar
    Nov 2018
    Enid, Oklahoma
    Default My 2015 tri glide does not sit level.
    Hi all, bought a set of DK comfort lifts and was going to install them tomorrow so I measured from ground to back fenders and the left side is 1in lower than the right side. I've thought for a while now that it was lower but just blamed it on my old poor eyesight. Guess I need to correct this problem before installing the new lift kit. I'm open for suggestions or if anyone has had this problem how did you correct it. Thanks, Robert
    Quote Originally Posted by Robk View Post
    My 11 Tri-Glide came from the factory off kilter also, And my dealer leveled it out under warrantee...The body is held on by' If i remember correctly with 4 bolts and he realigned from there ...
    Do a search that was a common problem though the years with the Tri-Glides..
    After the drive belt replacement under warranty on my 15 Tri .... my trike sat level ... the dealer had to take the body off to replace it ... only time it ever sat level ...
    HD has a whole laser alignment procedure for the axle and the body ... get it leveled before you add the comfort lifts ... especially if you have warranty left. After you put the comfort lifts on you may not have warranty anymore ... varies greatly dealer to dealer.
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Is it possible the air shock line is leaking on that side?
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Only 1 air line from the filler fitting which then Ts to feed each shock. A lead anywhere in the line(s) or either shock will deflate the entire system.
    You can beat a dead horse about it....But its a factory mis-aliment....
    Nov 2018
    Enid, Oklahoma
    Default Thanks
    Thanks all for the great information. I had no idea this was a common problem (thought I was the only one). I did take the trunk off about a month ago to install some new slip on's, did not realize it could cause this problem, so guess I created my on problem. Not sure if it was like this before I did that. I will retrace all my steps and try to correct this. Thanks again for your help and info. Robert
    500+ Posts
    Apr 2016
    Vero Beach, Florida
    I had a 2016 TGU that had a difference off the ground from side to side in the rear of the trike of about 1". At the time, I didn't feel like it was worth the hassle to bring it into the Harley dealer and have the body leveled. My current 2019 TGU is within 1/4" of each other so I am quite pleased that you cannot visually see any deviation in height while looking at the back of the trike.
    You could use these to shim the body bolts
  11. #10
    Nov 2018
    Enid, Oklahoma
    Jack, good idea with the shims, I'm going to do that. Thanks
  12. #11
    The nice thing of the alignment shims is you just have to loosen the body bolts a bit to slde them in
  13. #12
    20+ Posts
    Oct 2015
    Albany
    Default Un-level trike
    Had the same problem. I was using the rear fenders. DON'T. One fender was rotated forward by about 1/4". USE the frame to get proper measurement & I'll think you'll see the frame is ok. I just removed the fender, rat tailed out the mounting holes & now both fenders measure the same. Mine must have been "let's get out early" on a Friday bike build??!!.......jimmer
  14. #13
    Nov 2018
    Enid, Oklahoma
    Jimmer, thanks for that info, would never thought about that, I was measuring from the fenders will do some remeasuring now
  15. #14
    300+ Posts
    florissant
    Anyone have pic's and step by step procedures of using the shims to level up the bodies ? I'm going to straighten up the back of this thing no matter what. Pretty shabby assembly from the factory.
    hardheaded
  1. To Level or not to Level that is the question!
    By paid4c4 in forum Honda Trikes
    Last Post: 04-29-2019, 01:06 PM
  2. Pros/Cons 2012 Level I versus 2008 Level II
    By Skeet7373 in forum Honda Trikes
    Last Post: 10-31-2015, 05:40 AM
  3. Trike going to sit awhile
    By bigred06 in forum General Discussion
    Last Post: 02-16-2014, 08:18 PM
  4. Come in and sit down
    By champsman97045 in forum General Discussion
    Last Post: 07-09-2011, 04:09 PM
