Likes Likes:  4
Results 1 to 6 of 6
Thread: Rear Shock Reservoir removal
    20+ Posts TTNW's Avatar
    User ID
    26735
    Jun 2017
    Spokane, WA USA
    Default Rear Shock Reservoir removal
    Hey folks:
    I have a 2007 GL1800 with a Monarch II installed. I need to remove the shock reservoir to clean and fill it up. It doesn't start the preload till around 12 in the dial. I know what needs to be done, but I'm wondering if anyone here has had to work on this. It looks to me as though I will have to remove the right wheel and attack this thing from under the trike. Just wondering if anyone has any thoughts on this.
    Thanks in advance...
    Chuck
    Lehman / Champion Guru
    Lee H. Mann's Avatar
    User ID
    4486
    Martinsburg, WV
    Chuck, I can only answer what I have read on the subject. I have never removed one with the body on. If you send a pix, since I don't have one here, I might be able to determine if it can be removed through the front without disconnecting the line. You will need to fill it prior to install since you have no access after it is installed.
    Jim Murphy
    Lehman Tech since 1998
    Champion Tech since 2005
    Lehman & Champion Dealer Owner Operator
    Iron Butt Rider 2001
    User ID
    26735
    Jun 2017
    Spokane, WA USA
    Hey Jim
    Well, not able to get you picture yet, but I can tell you that I can't get to the mounting bolts. Guess maybe I answered my own question. But if I can get info from others. That may help.
    Thank you sir for all your help... You're the best.
    Chick
    500+ Posts Mick's Avatar
    User ID
    25
    Feb 2008
    Midwest
    Chuck I have an 07 Monarch II and I did this about 2 1/2 years ago.What I wound up doing was zeroing the shock on the panel and then putting the trike up on Jackstands. You have to remove the right rear wheel to access the shock. Its on the inside wall of the body on the frame behind the wheel. You kinda have to work partially in the wheel well for a bit. I wound up also having to get a breaker bar to loosen the mounting bolts for the shock to the frame. You can unplug the shock but remember before loosening and removing the hydraulic line to mark which direction the line is mounted on the shock. Before refilling it I took a philips head screwdriver and made sure the piston was bottomed inside of the hydraulic cylinder. I dumped out all of the old oil and refilled it with regular hydraulic jack oil. It took me a couple of hours and I wasnt in any hurry. My shock was almost like yours. It would start at 11.
    User ID
    26735
    Jun 2017
    Spokane, WA USA
    Quote Originally Posted by Mick View Post
    Well, I got the unit unbolted and got a real education. Looks like I'll have to remove the fuel tank to get it out to work on it. I guess while that is the case, I'll look at replacing the spring too. If it's NOT the HD spring the should have been installed when the kit was installed. Darn the bad luck...
    Chuck
    User ID
    4486
    Martinsburg, WV
    Quote Originally Posted by TTNW View Post
    Chuck
    Chuck, If you are just servicing the pre-load pump, you can just disconnect the line at the pump and re-route the line when you install it. You don't need to drop the shock. You can use a vacuum pump to remove the old fluid from the jack (and hose) on the shock. Use brake-kleen to rinse it out several times. After cleaning the pump, pre-fill the line before connecting to the pump. You will have to raise and lower the line to get all of the air out before filling the reservoir.
    Jim Murphy
  1. Rear Brake reservoir 98 GW Motortrike where is it?
    By Big Tom in forum Honda Trikes
    Last Post: 10-22-2018, 08:33 PM
  2. CSC Viper Rear Brake Fluid Reservoir
    By Tony8 in forum California Sidecar Trikes
    Owners Forum
    Last Post: 04-15-2018, 11:53 AM
  3. Freewheeler Brake Reservoir Relocation and other "Clean Up"
    By Free Bird in forum Harley Freewheeler
    Last Post: 04-04-2018, 07:29 AM
  4. Rear brake master cylinder reservoir idea
    By Dirtydan in forum Victory Trikes
    Last Post: 08-03-2016, 09:40 PM
  5. Tr-Glide rear shock options with shock lift mount.
    By rick1201 in forum Harley Tri Glide
    Last Post: 02-12-2016, 01:50 AM
Bookmarks
