gfaltersack3Old Road DogHarley Tri GlideDK Customs remote oil filter kit in...
gfaltersack3DK Custom ProductsHarley Tri GlideDK Customs remote oil filter kit in...
gfaltersack3gfaltersackHarley Tri GlideDK Customs remote oil filter kit in...
Likes Likes:  4
Thanks Thanks:  1
Results 1 to 8 of 8
Thread: need help with brakes
    Jan 2011
    maiden nc
    Default need help with brakes
    can you use a master cylinder on the handle bars of a bike as the brake for the vw trike.i really don't want to use the vw master cylinder.so can i use the one on the motorcycle handle bars?
    Jan 2011
    Soutport NC USA
    Default Re: need help with brakes
    For my dads trike, he used the handle bar master to control the front brake, and a dune buggy style pedal with master to control the rears. We wired it so that either or both would activate the brake lights.
    VW Tech Expert Loner's Avatar
    Aug 2010
    Harvest, AL USA
    The handlebar master cylinders do not offer the mechanical leverage needed to operate the rear brakes, as well as not enough volume. The only solution to allow use of only the handlebar braking system is if it were assisted by some type of power steering device in line with the brakes. Rear VW brakes need minimum of a 6 to 1 leverage ratio and ideally more like an 8 to 1 ratio - and that's if using your foot to operate. Handlebar levers only offer about 3 to 1 leverage at best - good for operating a single front brake caliper, but not enough for rear brakes.
    TOI - Oregon champsman97045's Avatar
    Jul 2010
    oregon city, or usa
    I have a rewaco which uses suspended pedals and the master cylinder is mounted in the top frame under the fake tank and switches. this might be a possability for you
    50+ Posts
    Apr 2019
    Fort Myers, FL
    Quote Originally Posted by Loner View Post
    How does one ascertain leverage ratio? I have a VW system on the rear of my trike and I'm not happy with the stopping power.
    Quote Originally Posted by controlu View Post
    Read here https://www.onallcylinders.com/2016/...e-pedal-ratio/
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    Good article above.
    What brakes do you have?
    Drum?
    Disc?
    What master cylinder size?
    And I usually say 7 to 1 on the pedal itself.
    6 to 1 would be shorter throw but harder to push.
    And 8 to 1 would travel further but be easier to push.
    https://www.triketalk.com/forum/thre...a-trike/page15
    70+ Posts
    Feb 2017
    West amherst new York usa
    I was unhappy with my lack of stopping power too. That is now cured with my drums being replaced with discs from the front of a karman ghia (no emergency brake now) . Hand lever controls front brake (not always useful) rear master cylinder on the frame rail, suspended pedal, ratio greater than 7:1 braking is now great!
    If you want to know more, see the odessy of Wilma https://www.triketalk.com/forum/thre...essey-of-Wilma
  1. Abs brakes
    By beachrider in forum Harley Trike Conversions
    Last Post: 11-22-2012, 09:22 AM
  2. brakes
    By broshous in forum Harley Trike Conversions
    Last Post: 10-03-2012, 04:50 PM
  3. DFT Brakes
    By John Luciano in forum Harley Trike Conversions
    Last Post: 07-28-2011, 06:59 PM
  4. brakes
    By bootzy in forum General Discussion
    Last Post: 09-10-2010, 06:47 PM
  5. brakes
    Last Post: 08-29-2010, 03:31 PM
