Likes Likes:  29
Thanks Thanks:  7
Page 2 of 2 FirstFirst 1 2
Results 21 to 37 of 37
Thread: Last Summer I had 30 tooth installed so...
  1. #21
    Dec 2013
    Clarion PA USA
    Adjusted Drive Belt deflection needed to get a gauge to do it so I purchased one. Primed and sealed the swing arm spots where powder coat failed and also the top of shock mounts at welds where the coating blistered. There were also two areas on top of the angle iron mounts for the stiffener bars the coating failed. At Ten years old there are bound to be issues here and there. Possibly the body will go back on tomorrow, I just need to get two 12" extra heavy duty Zip ties the brand used by Electrical services those are what is used from Lehman or so they told me.
Size:  159.0 KBName:  DSC01141.JPG
  2. #22
    5750+ Posts BillR's Avatar
    Aug 2015
    Gloucester, VA
    Quote Originally Posted by Fearless View Post
    I just need to get two 12" extra heavy duty Zip ties .
    If you could get Zook or one of the moderators to PM me your address, I'll send you some.
    Bill
    R I P MANDY
  3. #23
    Dec 2013
    Clarion PA USA
    Quote Originally Posted by BillR View Post
    Thanks I went to lowes today and got 15 pack in the electrical dept. extra heavy duty thank you anyway. ride safe Fred
  4. #24
    Dec 2013
    Clarion PA USA
    Default My Luck...
    I torqued the body bolts today and the ground bolt broke it was over torqued sometime before, last bolt to finish putting the body back on. finshed painting and secured brake hoses and emergency cables to OEM placement. Wheels are cleaned and clear coated ready to go. Name:  DSC01158.JPG
Size:  151.6 KB I plan on cutting it to length degreasing and red locktite the all thread and using it... any thoughts only 12 Lb. torque on it.
  5. #25
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    What is the diameter of the bolt?
    Size Recommended Torque
    Grade 2 Grade 5 Grade 8 18-8 S/S Bronze Brass
    Coarse Fine Coarse Fine Coarse Fine Coarse Fine Coarse Fine Coarse Fine
    #4* - - - - - - 5.2 - 4.8 - 4.3 -
    #6* - - - - - - 9.6 - 8.9 - 7.9 -
    #8* - - - - - - 19.8 - 18.4 - 16.2 -
    #10* - - - - - - 22.8 31.7 21.2 29.3 18.6 25.9
    1/4" 4 4.7 6.3 7.3 9 10 6.3 7.8 5.7 7.3 5.1 6.4
    5/16" 8 9 13 14 18 20 11 11.8 10.3 10.9 8.9 9.7
    3/8" 15 17 23 26 33 37 20 22 18 20 16 18
    7/16" 24 27 37 41 52 58 31 33 29 31 26 27
    1/2" 37 41 57 64 80 90 43 45 40 42 35 37
    9/16" 53 59 82 91 115 129 57 63 53 58 47 51
    5/8" 73 83 112 128 159 180 93 104 86 96 76 85
    3/4" 125 138 200 223 282 315 128 124 104 102 118 115
    7/8" 129 144 322 355 454 501 194 193 178 178 159 158
    1" 188 210 483 541 682 764 287 289 265 240 235 212
    * Sizes from #4 to #10 are in lb-in.
    Sizes from 1/4" up are in lb-ft.
    † Fine thread figures are for 1"-14.
    Grade 2, 5, and 8 values are for slightly lubricated bolt
  6. DKCustoms postbit
  7. #26
    Dec 2013
    Clarion PA USA
    Jack it is 5/16's torques to 12 lbs. Ground on the top left body bolt and the ground web goes there also. I'm sure it will work well thanks for the chart ride a few miles for us next time out. Fred
  8. #27
    Dec 2013
    Clarion PA USA
    Default Finially completed!
    This project started as Clean the wheels on the inside and went down hill from there. Aligned the rear end straighten up the entire assembly, now there is equal spacing from the fender and tires on both sides. Purchased a Drive belt deflection gauge tool to make sure it is adjusted correctly. Finding the wiring mess that needed a male side plug not stuffed in the other side. I had never looked down in where it was placed all taped up, 2.50 cent plug fixed it. Found a loose Heim joint replaced both of those. I found small rusty spots where powder coating failed repaired those as well. New brake pads may as well do them while it so easy to get at. Adjusted and set the parking brake Also changed the rubber mounts on the mufflers in the rear, again very easy to do with body off chassis.
    What did I learn out of the escapade... Although Clean and polished paint sometimes you have to look a little deeper to really see what is really happening. The trike is 10 years old now I think I will be paying closer attention than before it still runs great looks respectable and it is paid for so I think I will keep it as long as the good Lord lets me swing a leg over it. Travel safe Fred Time to put the tools away for a week or so.
Size:  160.6 KBName:  DSC01137.JPG
Size:  162.7 KBName:  DSC01122.JPG
Size:  161.0 KBName:  DSC01124.JPG
Size:  162.8 KBName:  DSC01125.JPG
Size:  161.6 KBName:  DSC01140.JPG
Size:  162.9 KBName:  DSC01159.JPG
  9. #28
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Thumbs up
    Looks Good
  10. #29
    1500+ Posts ShapeShifter's Avatar
    Aug 2018
    SW, Arkansas, USA
    Cool Nice Work!
    2016 Tri Glide Billet Silver w/Pinstripes ["Hi-Yo, Silver! Away!"]
    • "There is so much good in the worst of us, and so much bad in the best of us, that it ill behooves any of us to find fault with the rest of us." ..... James Truslow Adams
    • 2nd BN 33rd Armor "The Tiger Battalion" "1972 - 1974"
  11. #30
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Nice job Fred. See ya in June,I hope. Going up to Ormond Beach on the 3rd for 4 day Snowbird gathering & meet some more forum members. Then back to Sanibel for 4-5 days & a ride to Key West. Hi to Jeanne .
    2020 TriGlide Tahitian Teal aka (Hawaiian Hussy). Avon frt & Comfortred rear tires. ProAction frt & rear susp. RZ seat. DK floorboard extension & rear axle retainer kit with EBS, HD pull -back bars. Custom Dynamics front turn signals & Vent grill. All ,HD "Edge Cut " accessories.
  12. #31
    Dec 2013
    Clarion PA USA
    Default Next to last project completed
    It sure is nice to have Ole' Shiney back on the ground I was off today so... I switched out the "old LED lights for the New ones". The small LED bar I have not decided weather to keep on or take it off
    Old LightsName:  DSC01128.JPG
Size:  161.7 KBName:  DSC01173.JPG
Size:  161.8 KB Name:  DSC01173.JPG
Size:  161.8 KB New lights Name:  DSC01179.JPG
Size:  160.8 KBName:  DSC01181.JPG
Size:  160.3 KBName:  DSC01182.JPG
  13. #32
    1000+ Posts
    Aug 2016
    Des Moines IA US
    Looking pretty good there Fred, glad everything worked out as planned, I'm sure you had a few mistakes along the way and you fixed as you went, that shows what a person can do himself with proper tools and a trike supplement, one thing about it you got to see how dirty it gets underneath, LOL, to bad you can't put a shield there to protect it all from getting dirty.
    All for now Trampas
  14. #33
    Dec 2013
    Clarion PA USA
    Quote Originally Posted by Trampas View Post
    All for now Trampas
    You're correct it certainly is a learning experience. The supplement didn't say remove the Panhard lower bolt on the rear housing When adjustment is needed but common sense tells you if your moving laterially the Panhard rod must be adjusted shorter or longer depending on which way you are going. I also learned how to repair or replaced wiring connectors and adjust the little barbs on those suckers. In general it was a great experience I have a much better understanding of the entire machine. Even the fabled poorly designed parking is effective when adjusted properly and I learned how. Certainly glad I was able to get it completed, last project still to come soon I'm going to install a frame mount for the Mighty Mite Fans. Those little fellas work absolutely marvelous.... One thing is for sure I will not wait ten years to get the body off and give it a good going over possible every other year in winter. travel safe Fred
Size:  162.4 KB Name:  DSC01122.JPG
Size:  161.0 KBName:  DSC01103.JPG
Size:  162.9 KBName:  DSC01108.JPG
Size:  162.6 KBName:  DSC01179.JPG
  15. #34
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Wow Fred, you've been busy! Looking good.
    Always great to get to know your ride better. It's a nice feeling to get all those little things taken care of and back in tip-top shape.
    On your light bar...have you double checked to make sure that if the front forks fully compress it will not come in contact with your fender?
    Looks like you're ready to enjoy the good weather when it finally arrives up your way!
    www.DKCustom.com
  16. #35
    Dec 2013
    Clarion PA USA
    Good point I will check will check for clearance thank you never gave that a thought
  17. DKCustoms postbit
  18. #36
    Dec 2013
    Clarion PA USA
    Kevin thanks again I am going to rethink the driving light as I have said before PA has a limit of four lights lit at the same time they often don't enforce it but... you know what I mean. If there is room I will move it behind the forks should enough clearance.
    Travel safe Fred
  19. #37
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Travel safe Fred
    Yeah, we see a lot of dented fenders from lights and tool bags.
    Knock on wood...most of the time LEO's cut a lot of slack to HD riders that are behaving somewhat rationally.
    I've been all over the USA and a good part of Canada, never been given any trouble, even with very loud exhaust (and 7 white lights up front). I just show respect to them and in congested & residential areas.
    BUT....I understand, the world is changing around us...almost feel like I don't recognize this country sometimes.
    www.DKCustom.com
  1. Those that had 2" pull back handle bars installed......
    By Phu Cat in forum General Discussion
    Last Post: 02-09-2017, 04:02 PM
  2. Anyone had 3M clear bra installed in Massachusetts?
    By brianl in forum Honda Trikes
    Last Post: 06-10-2016, 07:31 PM
  3. RPM'S with 30 tooth change
    By VaThumper in forum Harley Trike Conversions
    Last Post: 06-29-2011, 02:19 PM
  4. changing 32 tooth front spocket to 30
    By Floyd L. Collins in forum General Discussion
    Last Post: 12-31-2010, 03:45 PM
  5. 34 Tooth Final Drive Pulley?
    By 1550vt in forum Harley Trike Conversions
    Last Post: 08-12-2010, 12:46 PM
