Likes Likes:  3
Results 1 to 10 of 10
Thread: Brake light flash module
    20+ Posts
    Mar 2018
    Buckeye, AZ. USA
    Default Brake light flash module
    I have a 2013 CCT with CSC Kit. I would like to install a brake light flasher module. I have looked at the Kisan 200GW which is a universal type installation and easy to do. It looks like it would work. Will have to find the main brake wire in the harness.
    Is there a plug and play kit for the Victory? What have others done?
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    Quote Originally Posted by m-c rider View Post
    Here is one for you, plus the video how to install,
    https://www.customdynamics.com/unive...lasher?cat=161
    20+ Posts
    Mar 2018
    Buckeye, AZ. USA
    Default Tail light flasher
    Pat... Thanks for the info. I will look into that one as well.
    100+ Posts Ben_D's Avatar
    Dec 2018
    Phoenix, AZ USA
    Quote Originally Posted by nucseal View Post
    That’s the video I used to install mine. Paul is very knowledgeable when it comes to Victory.
    20+ Posts
    Mar 2018
    Buckeye, AZ. USA
    Default Brake light flasher
    Thanks; I looked at his video. Wish he was installing it so all the brake lights flash and not just the one in the truck.
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    On Victory and Indian lighting, Paul at Custom Dynamics is the go to guy. No one knows more about them than he does.
    20+ Posts
    Mar 2018
    Buckeye, AZ. USA
    Zook: Thanks, I have sent an e-mail to Custom Dynamics requesting more information about their system. I also asked them for recommendations. I am looking to do the same installation on my Victory and a friends GL1800 with CSC kit.
    If I don't hear back sometime tomorrow I'll try giving them a call.
    20+ Posts
    Mar 2018
    Buckeye, AZ. USA
    I got an answer back from Custom Dynamics. Their flasher will not work for my Victory. It will work for the GL1800.
    The problem being is the Victory running / brake / turn signal are all integrated with the CSC. Turn signal has to be seperate for
    their system. It will work for the Honda. However they cautioned about the wattage, their module is rated 84 watts max.
    Not sure what the wattage is with the CSC.
    So I think I will go with the Kisan tailBlazer 200GW for the Honda and keep looking for something else on the Victory.
    Thanks again for all your input.
    Regards
    Phil
    20+ Posts
    Mar 2018
    Buckeye, AZ. USA
    I emailed Calif. Side Car. They have installed a module of their own that converts the Victory lights ( turn signal seperate ), to the current configuration ( all 3 integrated ). CSC suggests not adding to kit configuration as it may damage the module they installed.
    So I think I will do as Pat did and just install a module for the trunk light.
    Thanks to all for your input.
    Regards
    Phil
    Jul 2023
    Granger, IN, USA
    Default Can do brake light flasher
    I make a simple plu-n-play module you can plug into the tour pack brake light to get a third, high mounted flashing brake light. It flashes four quick then four slow flashes before going solid (for each brake press). I've sold load to the XCT community and run one on the wife's XCT with CSC conversion.
  1. Replies: 2
    Last Post: 02-03-2017, 12:27 PM
  2. Replies: 3
    Last Post: 03-01-2015, 12:16 AM
  3. Pulsating/flashing brake light module;legal/illegal
    By 470004 in forum Harley Trike Conversions
    Last Post: 11-02-2014, 02:20 AM
  4. Run/Brake/Turn Module
    By wayne111 in forum Harley Trike Conversions
    Last Post: 10-21-2014, 10:47 AM
  5. HD Motor Trike Run/Brake/Turn Module
    By wayne111 in forum New Member Introductions
    Last Post: 10-20-2014, 09:23 AM
