Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  11
Thanks Thanks:  6
Results 1 to 18 of 18
Thread: header
    5+ Posts
    Dec 2018
    St. Charles,I'll,usa
    Default header
    want to install catless header on 2017 tri glide.Can this be done without dropping mufflers?If mufflers do need to be removed what is the best way to remove the bolts from rear hangers seem like its pretty tight back there
    450+ Posts TonkaDriver's Avatar
    Feb 2018
    Bagdad, AZ, USA
    You will need to drop the right muffler. You can get a combination wrench on the hanger bolts. A ratcheting box end wrench worked fine for me. It is 1/2 inch.
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Quote Originally Posted by TonkaDriver View Post
    That should work fine. But I'll bet getting them re-installed is a bit more of a challenge. Never done it on a trike but it is as awfully tight space. Good luck with your mod.
    300+ Posts
    Mar 2018
    Waelder, Texas
    I had to drop both mufflers but I removed the left side as an assembly with the crossover pipe. It's a tedious job getting to the bolts. I modified (a little grinding and bending) a combination wrench. Before reassembly, flip each isolator and bracket, and it will go back together much easier. BTW mine is a 2015 twin cam. I don't know if that matters. Good luck!
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    To make re installation of the mufflers easier, I put a stud in both rear holes of the mufflers
    With this it is faster IMO to get the job done
    Install a flat washer and lock washer before the nut, no need to flip the hangar or rubber insulator.
    The nut will sit higher than a bolt making it easier to tighten
  6. DKCustoms postbit
  7. #6
    Dec 2013
    Clarion PA USA
    A ratcheting box end for sure that is why I think they were invented LOL mine is a flex head sears spline type not sure what they call them but it is great for muffler hanger bolts. just sayin Fred
  8. #7
    200+ Posts Wmitz's Avatar
    Jun 2018
    Crossville, TN, USA
    Point to ponder, are you doing this for performance, sound, or less heat. From what I have read, a performance header doesn’t really help this motor that much for the cost, maybe 2-4 hp over a decatted stock pipe if your lucky. That changes with more motor enhancements. Many have decatted the stock pipe while on the, on two wheelers. I don’t know if it’s possible on the trike. They used a long drill bit for going thru walls, like $18/20 from Home Depot/Lowe’s store. You can find decatted stock headpipes on eBay around $120 or so.
  9. #8
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Smile
    That's a great idea. The voice of experience.
  10. #9
    1000+ Posts Texan's Avatar
    Jun 2013
    Texas
    Just turn it upside down and do it.....bolts are easy to get to. While out it ya might clean the bottom a little.
    AND don't ask !!!
    8~\o
    "Anybody can become an American but ya have to be born a TEXAN"
    "Ya know I haven't been everywhere but it's on my bucket list"
  11. #10
    250+ Posts
    Feb 2016
    Pelham AL USA
    Unhappy OH ME!
    Sorry about that. Looks like right lower and fender might be on the concrete. BUT, I got to ask.....how did you do that? Ramps involved?
    16 TGU Mysterious Red / Velocity Red. FM Ceramic Head pipe and FM E-Series tunable exhaust. PV Target Tune-AT WB Tuner. DK Outlaw 606 AC with EBS, Ward’s FCS fans. DK Custom Oil filter/Cooler relocation kit, Comfort Lift and 14 inch shocks. DK tank lift, wind deflectors, floorboard extenders, and tour pak relocator. Chrome TGU wheels. Bad Ass Lights tail lights. Lighted controls and Krome Works 2+2 narrow handle bars.
  12. #11
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Quote Originally Posted by MDF48 View Post
    He said 'don't ask.' But inquiring minds want to know. Next question: how did you get it back up on its wheels. Looks expensive for sure.
  13. #12
    1500+ Posts ShapeShifter's Avatar
    Aug 2018
    SW, Arkansas, USA
    .... got to ask.....how did you do that? Ramps involved?
    Quote Originally Posted by ultrafxr View Post
    Samantha Stevens! Bewitching images?
    2016 Tri Glide Billet Silver w/Pinstripes ["Hi-Yo, Silver! Away!"]
    • "There is so much good in the worst of us, and so much bad in the best of us, that it ill behooves any of us to find fault with the rest of us." ..... James Truslow Adams
    • 2nd BN 33rd Armor "The Tiger Battalion" "1972 - 1974"
  14. #13
    Jun 2013
    Texas
    Believe it or not, not a scratch on it. There were a bunch of boxes to the right of my bike. Eased over on the boxes.
    What happened. Was jacking it up to work on the exhaust mounting for my V&H slipons. I have two different floor jacks. The normal every day pump it 15 times and a NASCAR aluminum jack that you pump twice and it all the way up. Forgot which jack I was using when I tried to raise it to up jack stand under the side frame tubing. Thought just one more pump and it's where I needed it, with barely one little pump The trike just eased over on it right side. Duh !!!Lucky I'd put those boxes there earlier. My neighbor came over and we just eased it back up right. I was totally surprised the only this I had to do is re-just the mirror.
    8~\0
  15. #14
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Smile
    Texan you must be living right for that to have happened and no damage . . . and more importantly no injury. Thanks for posting the photo and the explanation.
  16. #15
    Aug 2018
    SW, Arkansas, USA
    Quote Originally Posted by Texan View Post
    Believe it or not, not a scratch on it. There were a bunch of boxes to the right of my bike. Eased over on the boxes......
    8~\0
    You my friend were truly blessed. I would never have been so fortunate under similar circumstances.
  17. DKCustoms postbit
  18. #16
    5+ Posts
    Dec 2018
    what size bolt holds slip on to hangers?thanks
  19. #17
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by Bruce51 View Post
    5/16th USS coarse thread
  20. #18
    70+ Posts RAHRAHJR's Avatar
    Sep 2017
    GLEN ROCK, PA
    There is two ways I have decatted our stock pipes.
    First was to cut it open at the stock welds from the inside face (motor side) only 1/2 way around then across, cut, chisel, grind scrape etc until cleaned out, then have a good welder weld it back together.
    My second one (the 2018 Trike) I used long drill bits, spade bits and hole saws from the end. I think the long and larger bits from Harbor Freight worked best.
    From my experience, the first one was better and easier but you need to know a welder.
  1. Vance & Hines Header Wrap Kit
    By IBTRIKED in forum Harley Trike Conversions
    Last Post: 04-05-2012, 03:21 PM
  2. The easiest way to remove the Header?
    By M.A.T. in forum Harley Trike Conversions
    Last Post: 04-04-2012, 08:36 AM
  3. Header pipe
    By gbsb in forum Harley Trike Conversions
    Last Post: 12-09-2011, 03:50 PM
  4. New "Catless" Header
    By TNTriker in forum Harley Trike Conversions
    Last Post: 07-06-2011, 04:30 PM
  5. 2010 Stock Header
    By joesin in forum Harley Tri Glide
    Last Post: 10-17-2010, 05:22 PM
