Phu Cat3cScjhbGeneral DiscussionIs there a TV commercial
Phu Cat3trike ladyGeneral DiscussionIs there a TV commercial
Phu Cat3Phu CatGeneral DiscussionIs there a TV commercial
Likes Likes:  1
Thanks Thanks:  1
Results 1 to 14 of 14
Thread: Wiring Question
    100+ Posts sonny8l3's Avatar
    Oct 2014
    Livingston (Colyell ), Louisiana, USA
    Default Wiring Question
    Hello, I have 4 prong relay that was on the scooter when I bought it. The wiring looked like 9 want to be mechanics wired it during a heck of a week long party. I rewired by copying what was there and cleaning it up with better connections and wire. It had one relay for the horn, I did away with it. The one that is left has gone out 3 times in the last 2 years and I think it's going bad again. I want it gone. One prong goes to the battery, one is grounded to the frame, one goes to power my fuse block, and the last one goes to the ignition switch. The switch is off of an older Freightliner. I figure I can run the one from the battery direct to power the fuse block. The one that is grounded to the frame I can just scrap. My problem is the one that goes to the switch. I figure that there is only one hot wire going to the switch. If I take the wire off the relay, I don't know how to get power to the switch. I'm guessing that only one prong on the switch is supposed to be constant hot. Since I'm mechanically declined and it took me 42 hours, for real, to rewire it, I'm a bit spooked about screwing this up. I'd be grateful for any info. Thanks for your time.
    The first thing I would do is confirm the power to the switch with your original set up
    2nd, check the switch for power to any other connections on the back of switch in start mode
    This will give you a starting point
    IMO fuse a hot wire from the battery to your switch, try it to see if it starts
    The ground you had with the relay I would return to a common frame ground just for safety Bad Ju Ju happens with out grounds
    I would also fuse the horn just because
    Good Luck
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    You do not "Have to" have relays. But the entire load will be going through the switch (headlight switch, ect). So the switch itself must be capable of handling the amperage required.
    Typically a fuse box is powered off with the key switch and has a separated circuit not on the key for critical emergency items such as head lights and emergency flashers.
    I would not leave an entire fuse box fully powered on all the time. You can power it with the key switch if it will handle the amperage. If not then you need a master power relay. Your description sounds like that was what the original guy was trying to do.
    I use generic standard format industrial relays and contact bases. Most everything on a relay because none of my motorcycle switches will handle the amp load. I also turn off the headlight along with the fuse box with a master relay as I have no "off" for the headlight (always on when key is on).
    Some good info from the net.
    http://trikerdon.50megs.com/vwtrikewire_1.htm
    https://www.triketalk.com/forum/thre...g-for-vw-trike
    Oct 2014
    Thanks y'all. Knowing that I am mechanically declined, I think I KNOW the simple basic stuff. Then I ask what I think is probably a simple question and get what sounds like a simple answer. Then I realize that I know even less than I thought. I obviously still have some work to do. Thanks for your time
    100+ Posts
    Sep 2016
    Sitka, Alaska USA
    i understand what you are trying to do. I think it might make it easier if you found schematics of the relays in question and saw how the control and load circuits work. there are standard pin assignments for relays. Once you understand those there is no mystery to what is happening through them. You might decide they are a good idea, once understood and sorted.
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    I see the Panasonic ones except for the highest amperage one.
    https://www.alliedelec.com/view/sear...motive%20relay
    And modular bases that all hook together. But the connectors are a separate item......and you have to have the special crimped pliers to put them on.
    https://www.alliedelec.com/product/c...5-fw/70102789/
    But I have just soldered them before I had an electronics shop.
    Bases.
    Assembly.
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Ebay 50 amp relay example.
    A single relay and the wired connector for it.
    https://rover.ebay.com/rover/0/0/0?m...2F251951378796
    Come to think of it .. ..I probably have some similar to this in my left overs.
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
Size:  456.7 KBSonny... you may want to install a cutoff switch like this one (red handle) to cut all power when needed or to stop unwanted current drain. good info on the relays, I'm using at least 5 for various functions, and using about 6 more for a homemade turn signal system. there are cheap to buy and easy to use. Its worth your time to learn about them.
    Oct 2014
    Thanks for all the info. y'all. Another VW triker came by and we figured out how to by pass the relay for now. And we found an original wire from the starter to the key switch that was bad. Hopefully things will get better now. I've been looking at the relay info. but it is still way over my head. Eventually I will run across someone that knows them well enough to sit down and explain it in terms that are simple enough for the mechanically declined. I would like to put some in the system because they sound like a good safety net.
    5+ Posts End of the Trail Customs's Avatar
    Sep 2018
    Richland
    Default Carburetor wiring...
    I have a 30/31 pict single port carb... one side has the electronic choke with a wire coming off of it. The other side has a wire coming off underneath the fuel inlet... can someone tell me what this second wire is, where it goes and is it necessary to run?
    Quote Originally Posted by End of the Trail Customs View Post
    Its been a long time since i played with VW's...1975?...If i remember correctly it is a fuel shutoff ....Like a solenoid [plunger] that when the power is cut off to it will close off the fuel flow...
    Sep 2018
    Richland
    THANK YOU! That wire would plug into the posative on the coil then?
    450+ Posts
    Mar 2018
    Fernley
    Not sure, but does sound about right. I would do a test, put a clip lead from source to solenoid, see if you hear it working as you should hear it open and close. Hope all works out for your ride.
  1. Aluma MCTXL wiring question.
    By Keystone in forum Trailers / Campers
    Last Post: 06-08-2015, 11:06 AM
  2. Question regarding trunk wiring / GL1800
    By rmrc51 in forum Honda Trikes
    Last Post: 06-05-2013, 12:10 PM
  3. CSC trike kit wiring question
    By Folksinger in forum Honda Trikes
    Last Post: 05-01-2013, 09:03 AM
  4. Have Voyager trailer wiring question
    By krazybob in forum Outrigger Style Trikes
    Last Post: 05-02-2012, 09:34 AM
  5. trailer wiring question
    By Southern Man in forum Trailers / Campers
    Last Post: 05-24-2011, 08:54 PM
