Davep3KoolbreezeHarley Tri GlideTRI GLIDE AIR FILTER QUESTION
Davep3rhino 2Harley Tri GlideTRI GLIDE AIR FILTER QUESTION
Davep3DavepHarley Tri GlideTRI GLIDE AIR FILTER QUESTION
Likes Likes:  5
Thanks Thanks:  1
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 23
Thread: Looking for a hot lead;
    Dec 2014
    Grand Junction, Co. USA
    Default Looking for a hot lead;
    I am trying to figure out where to pull switched power to run my auxiliary fuse box.
    On Helga I found a ground and hot (switched) wire nutted under the seat.
    I see there is a connection on the top left of the fuse box (oem) does anyone know it that would work?
    I'm not running anything big, charging station for phone and GoPro batteries and a SiriusXM radio. Maybe 5 amps total.
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    I bet ya Randy would know
    Dec 2014
    I'm hoping he'll chime in.
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Question, is that connection on the fuse box hot at all times
    And do you want your NEW connection hot all the time?
    Could be a battery killer if you forget to power down everything you connect here
    Just thinking out loud here
    Dec 2014
    No ... I'm looking for a switched source ... IE, only hot when ignition is on/acc.
    I thing the AC connection top left on the OEM fuse box is there right place ... can't remember where I put my shop manual ... LOL.
  6. #6
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    That is where I ran my extended fuse box from on my 06. If I remember correctly, the accessory terminals are switched. Always can check with a meter.
    HOW CAN YOU HELP THE TRIKE TALK FORUM? Become a GOLD CLUB MEMBER!
    A veteran - whether active duty, retired, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to the 'United States of America', for an amount of 'up to and including my life.'
  7. #7
    Dec 2014
    I did find my manual ... it's kind of silent on the acc terminals ... gonna have to check them with a meter. But I'm pretty sure that's where I hooked it up on the 08 trike and the 01 yellow wing.
    This getting old is for the birds ... can't remember anything.
  8. #8
    4250+ Posts
    Marc H's Avatar
    Dec 2011
    Evensville,Tn.
    Don't know about the 1800 but on a 1500 the ACC terminals are 5 amp max.You could trigger a relay that supplied power to the box with it.
    1989 GL1500 Goldwing (SOLD)
    2006 GL1800 CSC
  9. #9
  10. #10
    Dec 2014
    Quote Originally Posted by Papa Zook View Post
    It is switched. What are you going to be running off your aux fuse box?
    Two charging ports ... one for phone, one for GoPro Batteries. And a SiriusXM Radio, less than 5 amps for sure.
  11. #11
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    The aux terminals in the fuse box are rated at 5 amps. If you need more than that, there is an easy way to accomplish it by using a Centex AP-1 switch panel along with the AP-170R Relay/Wiring Kit $34.95. Connect the Centex AP-1 red wire directly to the positive battery terminal and the black wire to the negative battery terminal and the orange wire from the Relay Wiring Kit to the switched, positive terminal in the accessory fuse block. This orange wire is the relay wire. This powers up the AP-1 switch panel only when the ignition is on. This device is widely used by motorcyclists.
  12. #12
    Dec 2014
    The aux terminals in the fuse box are rated at 5 amps. If you need more than that there is an easy way to accomplish it by using a Centex AP-1 switch panel with a relay. Connect the Centex AP-1 red wire directly to the positive battery terminal and the black wire to the negative battery terminal and the orange wire to the switched, positive terminal in the accessory fuse block. This orange wire is the relay wire. This powers up the AP-1 switch panel only when the ignition is on. This device is widely used by motorcyclists.
    Good to know ... I doubt I'll need more than 5 amps.
    This is what I have been using.
    Name:  Fuse Block.jpg
    I only use 2 fuses, and they have been changed out to 2 amps.
  13. #13
    Dec 2014
    Went ahead and ordered the AP-1 ... Less limiting and much safer than the one I have. I like that it's relayed. Plus, mine's been on a "few" bikes ... LOL. Probably time to upgrade.
  14. #14
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    To be clear, you will need the AP-170R Relay/Wiring Harness to go with the AP-1 fuse panel. Two separate items.
  15. #15
    Dec 2014
    Ordered.
  16. #16
    1500+ Posts Dockem's Avatar
    Jul 2011
    Cville, IN / Leesburg, FL
    Ordered.
    Curious minds want to know "From where?"
    Thx
    Nevermind, Centech, duh....
    The human race has only one really effective weapon, and that is laughter. - Mark Twain
    People who drink light 'beer' don't like the taste of beer; they just like to pee alot. - Capital Brewery, Middleton, WI
    TOI #01585 VRCC #506 Iron Butt #10256 NRA Life Member
  17. #17
    Dec 2014
    Quote Originally Posted by Dockem View Post
    Thx
    Welp ... I was able to find the fuse box and the relay wiring on eBay for a lot less ... no shipping was the big difference .... now that I'm on a fixed income ... I gotta watch the pennies ... well at least if I plan on doing some road trips ... LOL.
  18. #18
    950+ Posts JaysGone's Avatar
    Nov 2012
    Delray Beach Florida
    Just curious.
    Where do you intend to mount the XM radio head??
    I put it all on the left side box cover. Used the aux and power connection under the box itself.
    Not a great place but only place I could think of.
    Ignore the plastic wrap on the XM head. They maybe water resistant. They aren't waterproof as I found out.
  19. #19
    Dec 2014
    I run a 8 foot cord from the BT CD thingie to the left front pocket. I plug that into to aux cord. I mount the BT CD thingie and the Sirius Radio head in the trunk ... when I want to listen to audio books on the phone, I unplug the Sirius radio and plug the phone in ... since I have a charging station in the trunk too, everything gets powered.
    I only listen to the Message, but, if I need to change the channel the remote is in the right pocket.
    Name:  CD BT Kit.jpg
  20. #20
    Nov 2012
    I lost you on the remote??
    There is a Remote for the XM head?? I didn't know of a remote from XM??
    I have to find this CD plug everyone is talking about.
    Is it in the trunk or under the seat??
    I only listen to 2 stations myself but didn't want it in the trunk. I carry too much junk already in there for me as is.
  1. tricky lives we lead.
    By oneup in forum General Discussion
    Last Post: 03-16-2015, 06:17 AM
  2. hot hot hot brings storms
    Last Post: 01-07-2014, 06:35 AM
  3. hot hot hot
    Last Post: 01-06-2014, 04:25 PM
  4. Replies: 4
    Last Post: 11-13-2013, 08:52 PM
  5. Does a trike lead--- trail---or middle?
    By Gabby Hayes in forum General Discussion
    Last Post: 02-05-2012, 11:04 AM
