Likes Likes:  1
Thanks Thanks:  1
Results 1 to 3 of 3
Thread: 2017 HD Freewheeler Balance Point
    May 2018
    Galion,Ohio,USA
    Default 2017 HD Freewheeler Balance Point
    Does anyone know where the balance point is for the freewheelers.
    I am calculating the tongue weight for my trailer.
    John.......Welcome to Trike-Talk.....I'm sure some one will chime in soon with the info you need....
    950+ Posts Free Bird's Avatar
    Mar 2018
    Saint Louis
    Per the owners manual (ref sections on lifting the bike) the balance point for the Freewheeler is located between the center of the clutch housing (you can reference the derby cover) and the the aft edge of the ignition cover on the engine. This is a crude estimation (+/- a couple of inches) but may get you close enough for trailer purposes. On my 2017 Manual the references I stated are on pages 154/155
    If you want to go for the exact measure from a datum point on the trike, the method used by pilots and A&P Mechanics to measure and calculate the center of gravity of an airplane will get you that specific point. All that process requires is a few bathroom scales, a tape measure, and some math (The web is full of simple methods for doing this). If you get stuck, I can create a reply to this post with the math and method... FAIR WARNING: It ill be a long post
  1. Discount tire won't balance 8 year old tires
    By vwbuild in forum General Discussion
    Last Post: 05-16-2015, 10:55 AM
  2. anyone using BB's in tire for balance??
    By irmagoo in forum General Discussion
    Last Post: 04-27-2015, 03:28 PM
  3. tire balance question
    By Scarecrow in forum Honda Trikes
    Last Post: 11-30-2014, 03:57 PM
  4. balance beads
    By usnraytn in forum Honda Trikes
    Last Post: 11-21-2014, 05:36 PM
  5. SS tire balance beads?
    By americanbadass in forum Tires, Wheels, Brakes, Front End
    Last Post: 01-23-2013, 09:24 PM
