14TG3Jack KlarichHarley Tri GlideInstallation of a new Fuel Filter &...
14TG3TrampasHarley Tri GlideInstallation of a new Fuel Filter &...
14TG314TGHarley Tri GlideInstallation of a new Fuel Filter &...
Likes Likes:  3
Thanks Thanks:  1
Results 1 to 11 of 11
Thread: Aux tank plumbing? GL1800
    200+ Posts Pooch's Avatar
    Aug 2017
    USA
    Default Aux tank plumbing? GL1800
    I've been looking and can't seem to find out exactly how you hook up the fuel line to the main tank from an aux. tank. I know you need a 90 degree bulkhead fitting and a check valve(aux tank lower than stock tank) but is the sending plate drilled and tapped, or just drilled and the fitting screwed in? Anyone done this? TIA
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Quote Originally Posted by Pooch View Post
    Jim,
    What tank are you using? On the Roadsmith, the aux tank feeds fuel to the main tank via a fitting that they supply that looks like this. You drill a hole into the top of the sending unit plate, insert their fitting and screw the supplied nut on the bottom:
    Name:  aux tank1.jpg
    Name:  aux tank2.jpg
    Name:  aux tank3.jpg
    Aug 2017
    USA
    Jim,
    Name:  aux tank1.jpg
    Name:  aux tank2.jpg
    Name:  aux tank3.jpg
    I'm using the stock tank, aux tank has electric fuel pump and a vented cap.
    Aug 2017
    USA
    Papa Zook, what are the sizes of those fittings into the main tank?
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Jim, I haven't put a caliper on one to be sure and Roadsmith doesn't list the size in their instructions that I can find, but the hose RS provides is gonna be right at or exactly 7/16" OD and the specs I get online for that size fuel hose show a 11.1 mm ID per the Gates fuel hose guide on O'Riley's HERE . I do know the hole that is drilled into the sending unit plate is 7/16" to accommodate the threaded fitting. Mike at Roadsmith can probably give you the particulars if you want to call him.
    Aug 2017
    USA
    Thanks, may do that.
    10+ Posts Glen773's Avatar
    Mar 2020
    Alexandria, KY USA
    How big of a tank and where are you going to put it?
    Norm has started working on my Endeavor, so it shouldn't be long now.
    Aug 2017
    USA
    The measurements indicate it will be close to 5 gallons, trying to get pictures posted. It will replace the storage area in the front.
    Mar 2020
    Alexandria, KY USA
    Mar 2020
    Alexandria, KY USA
    Default Ride
    This has nothing to do with this thread, but I couldn't PM you about it.
    What do you set the ride at the back wheel? Norm said to leave it at 25, highest setting. The wife said it's to hard at that. I lowered it to 20 and she is happier, but said it was still hard riding. I used to have it at 8 to 10, and she liked it there. It also feels better at a lower setting. It doesn't feel like it is wandering or rocking side to side so much.
    2002 Goldwing Endeavor Trike.
    50+ Posts Deplorable's Avatar
    Nov 2021
    Hereford, AZ USA
    Default Aux Fuel Tank
    Pooch,Sorry to bring up an old thread. I would be interested in more info for an Aux tank for the front of my Endeavor Trike.Was the tank fabricated to fit or did you find one somewhere on the after market?Any indo would be appreciated.
  1. GL1800 Champion conversion w/AUX GAS TANK?
    By wiredgeorge in forum Honda Trikes
    Last Post: 08-27-2018, 01:21 PM
  2. CSC Aux fuel tank and GL1800
    By Rreffner in forum Honda Trikes
    Last Post: 08-05-2016, 11:00 AM
  3. What seat fits GL1800, CSC w/aux tank
    By lectric in forum Honda Trikes
    Last Post: 11-11-2010, 02:26 PM
  4. exaust, and aux fuel tank
    By hammwill in forum General Discussion
    Last Post: 11-19-2008, 09:25 PM
