Gernerwa10Jack KlarichNew Member Introduct...New Member from Bellingham, WA
Gernerwa10trike ladyNew Member Introduct...New Member from Bellingham, WA
Gernerwa10GorillaNew Member Introduct...New Member from Bellingham, WA
Gernerwa10rhino 2New Member Introduct...New Member from Bellingham, WA
Gernerwa10Marc HNew Member Introduct...New Member from Bellingham, WA
Gernerwa10Uncle FesterNew Member Introduct...New Member from Bellingham, WA
Gernerwa10ZammyNew Member Introduct...New Member from Bellingham, WA
Gernerwa10hardwickbvNew Member Introduct...New Member from Bellingham, WA
Gernerwa10ol' schoolNew Member Introduct...New Member from Bellingham, WA
Gernerwa10GernerwaNew Member Introduct...New Member from Bellingham, WA
Speed Bleeders
Too Pa Pa Zook
Thanks Thanks:  1
Results 1 to 4 of 4
Thread: Auxiliary gas tank
    Jan 2019
    Tallahassee, FL USA
    Default Auxiliary gas tank
    The pump in the auxiliary gas tank only pumps for a few minutes and then shuts off. After 5-10 minutes it again will pump but only for a short time. I keep only 3 gallons in the auxiliary tank for emergencies only and tried to transfer it today. No way will it pump what is in the tank. Gauge on "E" but no red light yet. Do I have to wait until the red light comes on? Has anyone else experienced this? Thanks,
    Ken
  2. Roadsmith banner
  3. #2
    Jan 2019
    Tallahassee, FL USA
    Quote Originally Posted by Kens03red View Post
    Ken
    Please disregard this post as I have found the problem. I disconnected the auxiliary fuel pump and found that the auxiliary gas tank is partially stopped up thereby allowing only a trickle of gas to drain out to the fuel pump. Pump would shut off when it had no gas in the line. I shot compressed air up the drain line into the tank and the gas drained as it should — moments later it was again stopped up. Several attempts later same result. Tried compressed air into the filler tube but still could not blow the obstruction out.
    My only recourse now seems to be the removal of the tank - ugh!! I If I ever get it figured out, I’ll post the results. Thanks for looking.
  4. #3
    May 2018
    Angleton, Texas
    You might try pumping out all the fuel left in the tank while using air pressure to force the plug into the tank body.
  5. #4
    Jan 2019
    Tallahassee, FL USA
    Quote Originally Posted by radismukes View Post
    Thanks for your thoughts. I have now used compressed air to removed all of the gas from the tank. Mike at Roadsmith suggested that I remove the outlet connection at the tank to possibly find the obstruction. However, when I attempted to unscrew the connector, it would twist but not come out. I am afraid that it may now be stripped. To remove the tank, I have to remove the rear trunk and then remove the entire body to get to the tank. Not a pleasant thought. 😟
  1. Gas in the auxiliary tank is not moving
    By ChefNYC in forum Roadsmith Trikes
    Owners Forum
    Last Post: 07-10-2018, 03:09 PM
  2. Auxiliary gas tank stopped working
    By skipg in forum Roadsmith Trikes
    Owners Forum
    Last Post: 10-13-2014, 09:58 PM
  3. New auxiliary tank system
    By Carbon_One in forum Yamaha Trikes
    Last Post: 08-29-2013, 02:52 PM
  4. Leaky auxiliary gas tank :(
    By MarciaG in forum Honda Trikes
    Last Post: 05-26-2012, 08:24 AM
  5. Auxiliary Gas Tank
    By philmcc in forum General Discussion
    Last Post: 07-08-2011, 04:03 PM
