Likes Likes:  1
Results 1 to 5 of 5
Thread: Reverse
    100+ Posts M2102's Avatar
    Pontiac, Illinois
    Default Reverse
    Earlier today after changing my air filter when I backed it into a shed it wouldn’t pull over a 1” curb. Had to put foot down and push a little. Reverse has occasionally not ended at first attempt. Hit button couple times then engages. Could it bea cable adjustment would fix the problem. I know the engaging issue would straighten out.
    TIA
    mike
  2. Roadsmith banner
  3. #2
    Sep 2012
    Lakeland, FL
    Several days without a reply, but I think someone will come along with the cable adjustment info, or if you get desperate, do a search on this forum, just google it. I've seen it done, but I would not want to mess it up trying to explain. My RS is a bit weak on the reverse, but no problem, I try not to put a strain on the starter and usually back it up dismounted if I get into a situation, or just give it an 'assist' push back. Some would ask "why", guess I'm just paranoid about starter failure, but that's just me.
  4. #3
    If it was fairly chilly that might of affected it ... my 06 will "act" weird if it's cold. Also you need t remember that the reverse is pushing more weight than it was intended to push.
    i do think the adjustment would help, especially with the engagement.
  5. #4
    Pontiac, Illinois
    Default Reverse
    When I was 2wheels before tricking it was no problem reversing. It did occaisionly not fully engage. When it does I spray the coils that work the reverse and it’s good to go for about 2-4 weeks or longer. I’m sure an adjustment on the cable would help. Not sure if I want to do it myself though. Have to do some reasearch on the how to for it.
  6. #5
    Quote Originally Posted by M2102 View Post
    Always a good plan ... lets you asses weather the job is in your wheelhouse ... there are several jobs I won't attack ... mainly do to specialty tools or just the need for help. I did a steering head bearing on an 03 last year ... never do that again ... trying to hold the bike and torque the head was quite the experience. Of course .. while doing that I realized that the side stand was bent and allowing the bike to lean way more than it needed too, which didn't help when I was yanking on the torque wrench. LOL
  1. Reverse Or No Reverse?
    By GETRDONE in forum Harley Trike Conversions
    Last Post: 09-05-2015, 07:37 PM
  2. new reverse trike
    By Trike Man in forum Home Built Trikes
    Last Post: 10-31-2012, 08:25 AM
  3. Some of my fave "reverse trikes"
    By mkparker in forum Home Built Trikes
    Last Post: 01-09-2011, 05:53 PM
  4. questions on reverse
    By WEB in forum Harley Trike Conversions
    Last Post: 06-01-2008, 08:54 AM
  5. Reverse trikes past and future...
    By ben721364 in forum Other Brands Trikes
    Last Post: 02-24-2008, 06:00 PM
