AriNV3cycle7447Rider Safety Discuss...Maybe silly but serious question, s...
AriNV3Jack KlarichRider Safety Discuss...Maybe silly but serious question, s...
AriNV3AriNVRider Safety Discuss...Maybe silly but serious question, s...
B SMITH9rhino 2Harley Tri GlideTrailering Tri Glide
B SMITH9CasperHarley Tri GlideTrailering Tri Glide
Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
ken g9Old Road DogHarley Tri Glidereverse not working
AriNV13trike ladyNew Member Introduct...New to trike
AriNV13GorillaNew Member Introduct...New to trike
AriNV4GorillaCan Am Spyder Trike...I'm a total newbie ... Is the Spyde...
Likes Likes:  4
Thanks Thanks:  3
Results 1 to 16 of 16
Thread: 2008 GL1800 headlight adjustment with R/S
    60+ Posts
    Apr 2016
    Monroe, NC , Union
    Default 2008 GL1800 headlight adjustment with R/S
    Hello everyone, I just purchased a used 2008 GL 1800 with the R/S kit. The ride is awesome compared to my 2007 Suzuki c90 Lehman with the solid rear axle, I love this longer wheel base and IRS. My question for you all: can these headlights be mechanically adjusted upwards? Looking at the bike I see that with this kit and the 5.5 degree rake the front end is pointing low. Living in the country of NC I like my headlights to be a little higher than what they currently are with the headlights adjusted at their highest point. My adjuster does work so it is not the control. I was wondering if the headlight assembly can be shimmed at the bottom to raise the aim point giving me the ability to have adjustment as needed? Or is there an adjustment on the trike kit that lowers the rear?
    Thanks,
    Brian
  2. Roadsmith banner
  3. #2
    Dec 2014
    Grand Junction, Co. USA
    Although I haven't taken the head lights apart, I would suspect that maybe adding a washer or something to the bottom mounting points would do the trick. I doubt it would take much of a "shim" to get them back to where the adjuster would actually be functional again, as opposed to just being set to raise the headlights to the highest point. I'd shoot to raise them enough to where your adjuster would be in the mid point when the trike is on level ground. That would give you back some adjustment for varying loads, two up, trunk loaded, etc.
  4. #3
    30+ Posts EC145Pilot's Avatar
    Aug 2013
    Mount Dora, FL
    Default Mechanical Adjustment
    Yes, there is a mechanical adjustment. I had to do the same thing on mine.
    If you look up under the front cowling you will see two adjustments on each side. One for vertical and one for horizontal, don't remember which is which. One takes a phillips screwdriver the other is, I believe, a 10 or 12 mm socket. I use to have a picture of that, but can't find it.
    Park the trike on a level surface, approximately 20 to 25 feet away from a wall, garage door, etc....
    Measure the distance from the level surface to the center of your low-beam
    Mark that measured distance on the wall
    Place your headlight adjustment knob to the center position (on the console), notice where the low beam is shining.
    Turn the horizontal and vertical manual adjustments (Under the front cowling) to place the low beam where it should be. I placed mine about two inches below the mark on the wall. (Note: I had to cover up the headlight I was not working on to see the one I was working on and when both were adjusted, made fine adjustments to line them up.
    There is no separate adjustment for the high beam. It follows the low beam.
    Hope this helps.
    Sid
    CW4 U.S.Army (Retired)
    2010 Honda Goldwing w/Roadsmith conversion, Caliente Red
  5. #4
    Aug 2013
    Mount Dora, FL
    Default Found it!
    Sid
  6. #5
    Sep 2016
    Springfield, Mass. USA
    Thank you!
    i just learned something new myself today......I'll get out there when the hibernation season is over, (hopefully soon)
    Ronnie
  7. #6
    Jun 2010
    Indianapolis, In.
    HEADLAMP AIM PROCEDURE
    Proper headlamp aim is achieved by adjusting the upper(high) beams.
    Bike needs to be on a level floor, standing upright, loaded as you normally ride. (re, 1up-you for most), with pre load set as you ride 1up, placed 25' from a wall to the headlamp lens in front of the upper beam. I would suggest the auto adjust dial be set in the middle position for this aiming.
    Measure the distance from the floor up to the center of the upper beam bulbs. Mark this height on the wall and draw a horizontal line at this height.
    Sight a point on the wall that is on the centerline of the bike. Draw a vertical line on the wall placed on this center line.
    turn on the upper beams.
    Cover one of the headlamps.
    Use the manual adjusters accessed under the front of the fairing.
    Adjust the vertical until the hot spot of the upper beam bulb is just under the horizontal line on the wall.
    Adjust the horizontal until the upper beam hot spot is just to the right of the vertical line on the wall.
    Cover the headlamp just completed, and repeat procedure on the other headlamp.
    Make a small mark on the auto adjust panel so you can return to the 1up setting.
    Now have both headlamps uncovered and have the usual passenger you carry sit on the bike w/you, set the preload for 2up, and dial in the auto adjust dial for proper aim and mark that position on the panel by the dial. You can repeat this for loaded 1up, loaded 2up, trailer, etc.
    You get what you get for low beam aim depending on how good the headlamp design was to start with!
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
  8. #7
    Dec 2014
    How do you get to those adjustments? I can't imagine you need to pull the whole nose? I just had mine mostly apart and couldn't get to those ... LOL
    Hmmm ... maybe that's why the little piece in the middle bottom of the nose is there?
  9. #8
    Jun 2010
    Indianapolis, In.
    You access 2 of the manual adjusters behind and from underneath the fairing using a 12mm socket and 2 from above behind the fairing using a #2 phillips screw driver. You do not need to remove anything.
    Patriot Guard
    Was a LEO
  10. Roadsmith banner
  11. #9
    Dec 2014
    Quote Originally Posted by tfdeputydawg View Post
    Kewl, Learn something new every day. Never had to adjust them.
  12. #10
    3250+ Posts bikerbillone's Avatar
    Sep 2012
    Lakeland, FL
    Just gotta love this forum.
  13. #11
    60+ Posts
    Apr 2016
    Monroe, NC , Union
    Quote Originally Posted by EC145Pilot View Post
    Thank you sir, I will look into this procedure this weekend.
  14. #12
    60+ Posts
    Apr 2016
    Monroe, NC , Union
    Thanks everyone for your guidance.
  15. #13
    Sep 2016
    I "think" many of us just learned something today,,,, I did! thank you!
    Ronnie
  16. Roadsmith banner
  17. #14
    60+ Posts
    Apr 2016
    Monroe, NC , Union
    This sure helped me, thank you.
  18. #15
    60+ Posts
    Apr 2016
    Monroe, NC , Union
    Thank you all for the guidance. I was able to raise them.
  19. #16
    30+ Posts Ghost Rider 2's Avatar
    Sep 2022
    Downs, Illinois USA
    Thanks for this information. I just had my trike built and I am not happy about the headlights.
  1. Headlight Adjustment ?
    By hddocfl in forum Harley Tri Glide
    Last Post: 09-26-2017, 10:00 AM
  2. Headlight Height Adjustment
    By paid4c4 in forum Honda Trikes
    Last Post: 06-15-2016, 06:57 AM
  3. headlight Adjustment
    By jmhenrie in forum Harley Tri Glide
    Last Post: 02-28-2016, 11:26 PM
  4. Headlight adjustment
    By ArkyBubba in forum Honda Trikes
    Last Post: 02-02-2016, 10:13 AM
  5. Headlight adjustment
    By Motorcycle Mike in forum Yamaha Trikes
    Last Post: 09-14-2014, 05:05 AM
