BigN693GorillaEnabled TrikersFull length floorboards
Likes Likes:  116
Thanks Thanks:  33
Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 61 to 80 of 109
Thread: Weird noise in clutch
  1. #61
    500+ Posts
    triwinggirl's Avatar
    Jun 2010
    Las vegas Nevada
    Default no mounting just yet.
    unfortunately i ran into a problem. things don't get my full attention until i'm working on them or installing them. i would have normally caught this and had it fixed. the wire harnesses from the tail lights too the bike were at one time spliced, right next to the connectors at the light. the splice's have 2-3 wires left holding them together. one is a dead short. these must be fixed. sorry the electronics tech in me just cant back yard this. might need new harnesses they very old the wire is very old. at least this is an indoor job.
    the damage is to great and the wires would end up short or to long and not fit. at $15 each new ones are on the way. waiting again.
    .Name:  20200914_114812_resized.jpg
  2. #62
    Quote Originally Posted by triwinggirl View Post
    i got one side of the door done, with what i have. nice double coat of light pink, no clear im out. this paint really does not need it, none of the plastic is cleared. the fenders needed the extra protection. i'm going to let the door dry before doing the other side. it has to be laid down so to not scare the paint i'm letting it dry over night. i'll do the other side in the morning.
    more to come on the fenders later.
    Attachment 91431
    If you can post a picture of the pant can; Ie The Brand...The rattle cans that i use never come out that smood and finished looking.......
  3. #63
    Thumbs up
    Good on you for getting new wiring It never pays to cut corners with wiring IMO
    I have seen electrical fires on bikes, it aint pretty
    I had a bad fire coming home from Sturgis one year on a friends bike, Scared the Hell out of me
  4. #64
    500+ Posts
    Jun 2010
    Las vegas Nevada
    its just rustoleum
    https://www.amazon.com/Rust-Oleum-32...s%2C208&sr=8-7
  5. #65
    Thanks..........
  6. #66
    500+ Posts
    Jun 2010
    Las vegas Nevada
    i finished painting the door.
  7. #67
    500+ Posts
    Jun 2010
    Las vegas Nevada
    Default a quick update
    THE WIRES ARE HERE 3 days late but finally here. the bad news is im sick, no its not covid in fact my test from thurs last week in negative. they tested me for the antibody today. i have a bad case of sinusitis from all the smoke in the air, my sinuses can only take so much.
    .Name:  20200924_132651_HDR_resized.jpg
  8. #68
    500+ Posts
    Jun 2010
    Las vegas Nevada
    Smile
    i finished the door it's ready to install. i wont have outside help until marrow sunday. then i got doctor monday hoping to mount on tuesday. 1 step at a time the turtle wins.
  9. #69
    Thumbs up
    The paint looks good
  10. #70
    500+ Posts
    Jun 2010
    Las vegas Nevada
    Default the fenders are assembled
    the fenders are assembled all thats left is mounting. hoping tuesday.
  11. #71
    500+ Posts
    Jun 2010
    Las vegas Nevada
    Default 4fenders are on
    the fenders are on, the brackets are on the holes are drilled the fenders line up centered the side covers line up and the seat fits. bolts fit in the holes and everything still lines up. i knew i was going to need longer bolts i got those but ran out of steam before getting the final bolts in. also still need to install the door and the exhaust. then wheels. the first pic is of the wires install and tucked up. yes everything works.
Size:  241.4 KBName:  20200929_092033_HDR_resized.jpg
  12. #72
    500+ Posts
    Jun 2010
    Las vegas Nevada
    Default murphy is in charge now
    murphy is in charge now, and kicking my butt with little shit. first i had mounting bolt issues and went to home depot twice. i thought the old bolts i had would fit, no i did not check( damn brain injuries). so i got those done and the fenders mounted. i went to mount the exhaust, i had bought short 3/8 bolts like all the rest for the exhaust. no i did not check them. when i went to install the 3/8 were too big so was a metric i tried. so i pulled the bolt holding the bracket and as soon as the 1/2 inch wrench fit i knew i was going back to home depot for 5/16 bolts. i got that done and the exhaust is bolted up now. the door is on. the fenders and exhaust are finished.
    so now im mounting the seat i set it on and the rear bolt holes just dont quite line up, they dont go down far enough. so i need to cut 2 more notches in the fender so the seat will fit. this is probably what broke the seat there from the other fenders, did not cut notch in old fenders. no real big deal ill have it done by end of day and get the wheels on.
    update; i cut the notches then pushed the seat all the way in. its not the notches the fenders are to high in the front. still an easy fix just cant use the nice rubber mounts. will have to thin it down and just use washers. also need 2 people cant reach the inside bolt and underside bolt with one person. so brakes on.
Size:  164.2 KBName:  20200930_103435_HDR_resized.jpg
  13. #73
    500+ Posts
    Jun 2010
    Las vegas Nevada
    ive been thinking, if i lower the front and raise the rear it will bring the front curve down and back. am i correct. it also just happens i have room in the back to go up and the front is a little tight and could come down. in my head it works i think?
    update Thursday; well at least im not working today because i'm not able not because i'm waiting for parts or have no help. i got up this morning and could not move my body just had enough. i had help today but took a day off. so close and yet so far. i still wonder if i'm even going to be able to ride her i just dont think i'm strong enough anymore.
  14. #74
    500+ Posts
    Jun 2010
    Las vegas Nevada
    Default guess what i did?????
    a friend came by around 11, i was in no condition to work. but he is my most knowledgeable helper. so i went out side. we pulled the front mounts, we then put the seat on, then we respaced the front mounts with flat washers. we then tried to bolt them up, the bolts were very crooked. so i had to redrill the holes. so to recap the fenders and seat are on, now we put on the wheels, and took her off the jacks.
    YUP JOY IS ON HER WHEELS. i rode her and discovered the rear brakes need to be bled once more for air. the good news is they pump up this time so no leaks just trapped air.
Size:  344.8 KBName:  20201003_130322_resized.jpg
  15. #75
    Thumbs up
    Awesome job, very happy 4 U
  16. #76
  17. #77
    400+ Posts BrokenBackJack's Avatar
    Feb 2017
    Payson, AZ USA
    Default Good job
    You did well and congrats!
    Be careful if you back into a curb as those exhaust pipes stick out quite a ways.
    Now go out and enjoy all your hard work!
    Johnny 7
    God, Family, Country, & Green Bay Packers
    2018 Honda Goldwing DTC Touring CSC Encore Trike Kit & 2021 Polaris General XP G2 Ride Command
  18. #78
    Congrats I bet your r thrilled been a long time coming. You should be very very proud.
  19. #79
    500+ Posts
    Jun 2010
    Las vegas Nevada
    my freind that did the painting help me bleed the front calipers rear lines. these lines are fed by the long lines and are the high spot on the frame. i got better peddle but it seems we need to do the rear. this is now covered by the trunk. the only way to get to the bleeder now is to jack it back up pull the right rear tire and then i'll have limited cramped access. i still have too tie things up on the upper frame around the steering. need to remove the dash and the inserts. she runs and rides smooth. the front brakes still work great.
    thank you all i see the 24,000 + views wow thats a lot of support. it has helped me keep going, knowing there are people watching and cheering me on. lets go for an even 25,000 i still got a little work to do. she has not been on the road yet.
    oh test riding her went well, i find out how much this is going to hurt my first road trip to the store. which will include taking my walker and walking at the store. i hope i make it home.
  20. #80
    550+ Posts Mick's Avatar
    Feb 2008
    Midwest
    Does your trike still have the linked brakes from Honda?
  1. Weird, High Pitched Noise
    By Robert53 in forum Harley Tri Glide
    Last Post: 05-23-2017, 04:59 PM
  2. Weird Experience
    By FRR in forum Honda Trikes
    Last Post: 03-13-2014, 03:23 PM
  3. Looked weird to me
    By Lakeman in forum Harley Trike Conversions
    Last Post: 08-09-2013, 08:14 PM
  4. Does This Look Weird
    By Postal Trucker in forum Harley Trike Conversions
    Last Post: 07-28-2013, 01:19 PM
  5. Weird and wonderful
    By Nana in forum General Discussion
    Last Post: 10-27-2009, 11:22 PM
