Phu Cat2trike ladyGeneral DiscussionIs there a TV commercial
Phu Cat2Phu CatGeneral DiscussionIs there a TV commercial
Speed Bleeders
Results 1 to 5 of 5
Thread: load suspension adjustment
    30+ Posts
    Mar 2019
    Henderson NV USA
    Default load suspension adjustment
    Are the load adjustments hydraulic or air on 04 Lehman trike? I'm 6' 185lbs what seems to be rule of thumb for 1 up and 2 up? Mine just has numbers 1-15
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Rod, that is totally dependent on the springs you have and the weight of the rider/passenger.
    The Monarch II may have the OEM mono-shock spring and the standard AUX shock spring.
    You want the suspension so that it does not bottom out nor ride too hard.
    If the springs and shocks are good, adjust accordingly.
    A good set up will allow 5 on the single and 10 on the double leaving plenty of adjustment for later on.
    Read this thread:
    https://www.triketalk.com/forum/thre...-in-rear/page3
    Jim Murphy
    Iron Butt Rider 2001
    30+ Posts
    Mar 2019
    Henderson NV USA
    Read this thread:
    Is it air shock Jim ?
    Martinsburg, WV
    Quote Originally Posted by Hotrod6169 View Post
    No AIR !!!
    The control on the dash is an actuator for a hydraulic jack for pre-load pressure on the stock shock spring. There is a pump and reservoir on the right rear side of the motorcycle.
    Jim Murphy
    30+ Posts
    Mar 2019
    Henderson NV USA
    Thank you Jim
  1. Roadsmith Pre-Load Adjustment System Video
    By Cut N Shoot Customs in forum Cut N Shoot Customs
    Last Post: 01-14-2024, 07:59 AM
  2. TriGlide Suspension Upgrade By Progressive Suspension
    By JohnC in forum Harley Tri Glide
    Last Post: 02-22-2012, 05:22 PM
  3. front suspension adjustment
    By tomg in forum Stallion Trikes
    Last Post: 12-17-2011, 11:50 AM
  4. Which is best the Champion Independent Suspension or Solid Suspension.
    By glawrence7 in forum New Member Introductions
    Last Post: 11-24-2010, 12:00 AM
  5. Vibration under load
    By grillmate in forum General Discussion
    Last Post: 06-07-2010, 09:20 AM
