Likes Likes:  3
Thanks Thanks:  2
Results 1 to 16 of 16
Thread: high pitch whine 2008 GL1800
    60+ Posts
    Apr 2016
    Monroe, NC , Union
    Default high pitch whine 2008 GL1800
    Hello everyone,
    Getting use to this new to me 2008 GL1800 with 2014 R/S kit. The bike has 51,000 miles. Starting at about 40mph a high pitch whine starts, it stops at 60mph. At first I thought it might be rear tire noise. Nope, the whine stops as soon as I pull in the clutch. There is no vibration at all during acceleration or de-acceleration. Has anyone experienced this and what was done to fix it? This is the only thing I dislike about this rig. My local Honda service shop told me to first make sure all the IRS bolts are in place and tight before I take the trike to them to test ride it.
    Thank you,
  2. Roadsmith banner
  3. #2
    200+ Posts
    Feb 2017
    Arp, TX - USA
    Have you tried matching rpm's to make sure it's not a noise more related to rpm than speed? Pulling the clutch in & the noise stopping does seem consistent with it being rpm related & wasn't sure if you'd thought to try that avenue. "Alternator whine" is a fairly "common" thing in the GL and is fairly well documented in various forums.
    Not saying it IS your issue, but sure wouldn't discount it either.
  4. #3
    60+ Posts
    Apr 2016
    Monroe, NC , Union
    Quote Originally Posted by trike tech View Post
    I have not tried the rpm matching. I considered the alternator as comparing it to my truck that had an alternator whine, it was the bearings. Replacing it took care of the issue. Thanks for this info, I will give it a try.
  5. #4
    Sep 2012
    Lakeland, FL
    Yes, quite possibly the dreaded beginning ADG failure, search this forum for ADG, that will give you some 'start' information.
  6. #5
    30+ Posts EC145Pilot's Avatar
    Aug 2013
    Mount Dora, FL
    Did you have/own/ride it before the kit was added?
    Did it make this noise before the kit was added?
    Have you checked to see if it is a Honda genuine OEM alternator?
    All the alternators make a little noise, but the aftermarket ones can get really noisy. I had the OEM one go out on a trip last year and could not find a OEM replacement, so the shop I stopped at installed an aftermarket. It lasted almost 2000 miles before I replaced it. It was still producing power but was making so much noise you could here it over everything else, with a full face helmet and ear buds. Found a shop in Utah that got me an OEM and that stopped the noise.
    Yours being a 2008, it should have the improved ADG, I think they started swapping those around 2006, not sure. Check around the internet and you should find videos of ADG failures with lots of noise.
    Sid
    CW4 U.S.Army (Retired)
    2010 Honda Goldwing w/Roadsmith conversion, Caliente Red
    60+ Posts
    Apr 2016
    Monroe, NC , Union
    Quote Originally Posted by EC145Pilot View Post
    First off, Thank you sir for your service to our country.
    I bought this bike already triked from a Roadsmith dealer here in NC. It was a consignment sale, the shop did not do this conversion. I did test ride it on rainy day up and down the side street the shop was located on and in parking lots. I was not able to get it out on the main street to get any speed up. Everything sounded just fine, no vibration and shifted nice getting up to about 35mph. This is my second trike, first Goldwing based.
    As for the Honda OEM, I will check today.
    I will search ADG, but what is ADG an acronym for?
    Thank you,
    Aug 2013
    Mount Dora, FL
    Default ADG
    ADG = Alternator Drive Gear
    Sid
    60+ Posts
    Apr 2016
    Monroe, NC , Union
    yes sir, did the You Tube thing, I am glad that I can rule this out. This noise is more noticeable with a full helmet on. Matching rpm when drive-line not engaged does not produce the whine. Maybe I just need to get use to the noises a GL makes? I am going to try heavier gear lube as some of what we are hearing does appear to be coming from the rear differential. Checking the rear drive and axles with no weight on them did not show any signs of bearing noise or slop in the bearings. More investigation will take place.
  10. Roadsmith banner
  11. #9
    Just Killing Time...
    paws's Avatar
    Kerrville, TX U.S.A
    Perhaps the Shop you purchased it from would have another Gold Wing trike or bike to compare it to before you take it to a Honda dealer.
  12. #10
    60+ Posts
    Apr 2016
    Monroe, NC , Union
    Quote Originally Posted by paws View Post
    paws,
    I was able to ride another GL trike this weekend, it was a 2012 with a CSC kit. Certainly not an exact comparison but was able to match the engine noise at idle. His pipes had a bit deeper tone and a little louder so it was tuff to hear any differential noise. He claims the pipes are OEM, they did sound good. My alternator does have a slight out board bearing noise at idle. It goes away at high rpm. I used a stethoscope to hear this. I am ruling out the alternator. The R/S shop I bought mine at suggested I try heavier gear lube. This will be changed this week.
    Thanks,
  13. #11
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Lucas and Wynns makes a gear lube additive . 2-3 oz added to gear oil should quiet the gears. I use it in the trans of my 91 FLH.
  14. #12
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    The 1st thing I do on a new to me vehicle is replacing all fluids, unless you have proof it was done.
    You just don't know how old they are. It's a good starting point & great peace of mind.
  15. #13
    60+ Posts
    Apr 2016
    Monroe, NC , Union
    Yes sir, I do this and did. I just went from 80/90 gear lube to 140w. The noise is not as loud but still there. I did not notice this noise on my Lehman trike with the Ford differential. But then again, the pipes are louder. I suppose from here, we get used to it or just wait and see if it gets worst and then really start digging?
  16. Roadsmith banner
  17. #14
    10+ Posts Wind Therapy's Avatar
    Jul 2018
    Fredericksburg, VA, USA
    Default GL1800's have timing chains . . .
    GL1500's have timing belts . . . GL1800's have timing chains (at least that's what I'm told).
    My 07 GL1800 with a 2018 Road Smith 1800HTS kit has an assortment of noises that I have become accustomed to; one of which is what I perceive as timing chain noise. You might want to touch your stethoscope to the timing chain cover on the front of your engine and see what that sounds like.
    Best of luck . . .
    Wind Therapy
    Dave Calahan
    Fredericksburg, VA
    triketalk
  18. #15
    60+ Posts
    Apr 2016
    Monroe, NC , Union
    Quote Originally Posted by camplejeune View Post
    Hello everyone,
    Figure I would update this post. The high pitch whine noise did get worst, it became a knocking noise sound at low speeds. It is all in the thread I started titled Differential Knocking Noise. The gears were chipped, the diff. was sent back to Roadsmith to be rebuilt. $1,700 total for my R/S dealer to remove and send it to the R/S factory, they gave me a 12 month warranty - pars and labor.
    No more high pitched whine between 55 and 70 mph.
  19. #16
    Sep 2016
    Springfield, Mass. USA
    Camp,
    I just read this post this morning (1/16/22) glad to hear that R/S figured out your problem..........Now the questions is ::: What cause a chipped tooth in the gears??
    Now this is just a question here only: Did you by any chance, pop your bike in gear while it was rolling back in neutral??? (I read about a gent, that pop'ed it into gear while rolling back and he did the same thing/broke a tooth gear....
    1/16/22
  1. High pitch whine
    By sddarkwing in forum Honda Trikes
    Last Post: 10-22-2016, 03:42 PM
  2. Alternator whine
    By Konrad in forum Honda Trikes
    Last Post: 11-04-2013, 08:21 PM
  3. Anyone have an alternator whine?
    By kb9osl in forum Honda Trikes
    Last Post: 10-30-2013, 09:05 PM
  4. High-pitched whine in tachometer
    By Muleskinner in forum Honda Trikes
    Last Post: 07-27-2010, 11:49 PM
